585,927 active members*
3,931 visitors online*
Results 1 to 7 of 7
    Apr 2017
    77
    Mach3 X and Y Zero
    Hi
    im currently using grbl and planning on moving to mach3 but can anyone help me use the same method of zeroing x and y as i do in grbl? Heres how i do it at the moment.
    https://www.youtube.com/watch?v=p5u0CKWpAUk
    Re: Mach3 X and Y Zero
    Look two threads above this one.
    http://www.cnczone.com/forums/mach-w...-software.html
    If you haven't yet bought any Mach3 specific hardware, consider UCCNC. Very similar to Mach3, but less buggy, more modern, and still supported and developed. Cheaper, too.
    Apr 2017
    77
    GRBL uses the tool diameter as well in the config. Im just about to upgrade to the Geko 540 Drivers. would i require a UNCNC licence or just the Parallel to USB adaptor?
    It's not a parallel to USB adapter. Are you referring to the UC100, or some other device?
    To use UCCNC, you need a UCCNC license, which is $60, and a CNC Drive motion controller, like a UC100, UC400ETH, or UC300ETH.
    Apr 2017
    77
    thats correct. thank you for the info.
    Does UCCNC have the edge finder zeroing function or does it work same as mach3 using scripts?
    Apr 2017
    77
    Ive had a look at the UCCNC 2017 screen set and it looks awesome and had corner zeroing.
    Can i set the two offsets on my plate ( x = 9.46 and y 10.08) within the screen set?
    Also using the geko 540 can i wire 6 limit switches and a x y z probe using uccnc?
    No, you'd need to edit the macros to do that.
    I'm currently in the early stages of redoing the entire screen, and will add that to my todo list. It's going to be a few months before it's finished, though.
  1. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  2. To mach3 or not mach3, opinions requested
    By KenCameron in forum HURCO
    Last Post: 10-07-2014, 10:05 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  4. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
