585,962 active members*
3,832 visitors online*
    Nov 2017
    4
    Mach3 and -gcode problem!!
    Hello guys! .
    Im new in cnc world- learning stuff step by step-.
    i did build router and now learning how things works with mach3 and Fusion360
    The problem i cant solve it:
    In Fusion i did made simple box with couple holles 10 pcs - and in fusion360 cam fixed to 2d adaptive cleaning, - in fusion all was fine, simulation ect without problems
    The GCode i got from fusion and load it to mach3- problem.!!!
    Mach3 shows only 1 or 2 holes and not all like need to be in code.
    Did run program to see what will happens... one hole was cutted like need to be.. second one start to work and on half programs end.
    Same problem i have also with 2d pocket-
    Any sugestion what i have any wrong setup- something wrong im doing in fusion?
    Thanks for help.
    Re: Mach3 and -gcode problem!!
    Without a license, Mach3 in Demo mode will only display 500 lines of g-code. This is likely the issue that you are seeing.
    Nov 2017
    4
    Problem solved... Licence file isnt on right place .. thanks- Ger21
  1. Precix running with Mach3 gcode, problem in edges and corners
    By FABLABBARCELONA in forum Commercial CNC Wood Routers
    Last Post: 12-29-2014, 05:49 PM
  2. gcode problem with mach3 (jogging works fine)
    By gurasha in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2014, 01:05 AM
  3. Mach3 and gcode from HSMexpress
    By zerodegreec in forum Mach Mill
    Last Post: 01-22-2013, 05:01 PM
  4. why does mach3 alter my gcode?
    By turbothis in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2010, 11:08 PM
  5. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
