Originally Posted by
64dodge
It has about 25% anti freeze in water. It wasnt frozen, pump was flowing a good stream.
Water was really cold from the single digit low teens night time temps of the past week.
When I got in from work this evening went back thru parameters again, all were set as before.
Hit the run button heard buzzing of the spindle but it wasnt turning, turned it by hand and it spun right up.
Left the pump off to see if it would build some heat. After about 5+ minutes it got up to around
70+ deg, inside shop was mid 30's. Check voltages at vfd R & S 125V U 170 V195 W170 does these seem alright?
Stopped it then start again it rocked back & forth then spun up in reverse. Stopped it quickly.
One thing i noticed the rotation led wasnt on when running but i dont know if it was before.
