585,752 active members*
4,105 visitors online*
    Jan 2018
    Sinumerik 828D. SNCK not initialized for simulation.
    Hi everyone.
    I have problem with initializing simulation. It's started after I tried to create new subprogram. Unfortunately I picked wrong name for it, which started from 2 digits - 30DEG.SPF. At the moment file no longer exist in NC data->Cycles->User cycles folder, however systems stills see that file (I think).
    I'm getting following errors and I can't run simulation:
    12080 - Channel 1: Block N1 syntax error in text
    15175 - Channel 1: Block program _N_30DEG_SPF. Interfaces could not be build
    Thanks for any help.
    Re: Sinumerik 828D. SNCK not initialized for simulation.
    I have the same problem. Started after I added a subprogram to the custom cycles folder. No clue how its related, but I guess it must be somehow. Anyone got a clue?
    Jan 2018
    I solved this by reseting simulation. [Menu select]->[HMI]->(>> - more options)->[Reset simulation].
    Thank you! This fixed everything. Still not sure what went wrong in the first place. Not going to complain though. Thanks again!
  1. Sinumerik 828D postprocessor Mill Solidcam
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-26-2021, 06:21 PM
  2. Sinumerik 828D, join several MPF programs
    By Martynas2 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-19-2016, 01:02 PM
  3. Sinumerik 828D Network Setup (Siemens)
    By Darkphoenix in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-18-2014, 05:08 PM
  4. g-code for sinumerik 828d problem
    By xray34 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-28-2014, 01:23 AM
  5. g-code for sinumerik 828d problem
    By xray34 in forum G-Code Programing
    Last Post: 09-17-2012, 09:51 PM
