585,932 active members*
3,693 visitors online*
    Sep 2016
    10
    VF5 TABLE PROBE CALIBRATION
    I am trying to do a table probe calibration. before i do probe calibration. I have everything setup and when i try to mdi the calibration it goes up and doesn't touch of on the probe. does anyone have any idea what the issue is??
    Jun 2016
    184
    Re: VF5 TABLE PROBE CALIBRATION
    See this video for good overview on how to calibrate probe:
    Jun 2016
    184
    Also, make sure you calibrate probe tip so it runs true otherwise your measurements with the probe will be off.
    Apr 2004
    45
    That video is on a next gen control. If you have an older Haas it won't work. Check your batteries on both tool presetter and spindle probe. Search youtube for haas automation probe troubleshooting.
    Feb 2010
    1184
    This manual should help you out better.
    Good luck!
  1. Passive Probe Calibration
    By Concepts_Design in forum Tormach Personal CNC Mill
    Last Post: 12-27-2015, 08:28 PM
  2. Calibration of cylinder probe
    By shadowparks in forum Calibration / Measurement
    Last Post: 10-05-2010, 03:13 PM
  3. ?? Probe lost calibration ??
    By behindpropeller in forum Haas Mills
    Last Post: 08-18-2010, 02:36 AM
  4. Probe calibration
    By kprice1658 in forum Tormach Personal CNC Mill
    Last Post: 10-25-2009, 09:56 PM
  5. Work Probe Calibration
    By JWB_Machining in forum Haas Mills
    Last Post: 10-27-2008, 03:42 PM
