585,996 active members*
4,154 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Looking for CNC Lathe With Manual Capabilities
Results 1 to 15 of 15
    Jan 2016
    32
    Hi All. I've been a member for a couple years, but have mainly lurked here, trying to soak up as much as I can.
    I presently have a South Bend Heavy 10 lathe--nice machine, built in 1943...and still accurate, but I want to get something that will allow me to turn tapers and other features on parts, etc., and also do metric threading.
    I took some courses in NC programming in college in the late 70s, and managed a machine shop for the Army for a couple years, and wrote the purchasing specs for the DMG Moriseiki 5 axis lathes and VMCs in the shop, so I'm not totally ignorant on CNC.
    I'd like to find a 1340 or 1440 sized lathe that had CNC capability, but I could still operate manually. I've been looking at a fairly new (2014) CNC Masters 1440, but it's a ways away and the brand has had problems with reliability--primarily limit switches, but also with the CNC system.
    I know it's a Chinese lathe, but that doesn't bother me too much since I'm only getting it for hobby work, tinkering, a little gunsmithing, etc.
    I wonder if I'd be better served by buying a decent quality 1440 lathe, such as one of the Taiwanese models, or a Precision Matthews, etc. then installing a CNC system on it.
    I'd appreciate some input on that course of action, and also an idea of what it would cost me for the CNC components if I do the work.
    Thanks in advance for your assistance.
    Utah Smitty
    Dec 2013
    5717
    Re: Looking for CNC Lathe With Manual Capabilities
    This is the only used one that I know of https://portland.craigslist.org/mlt/...412527108.html
    Manual/CNC lathes are pretty rare. I thought about converting my 1340 to CNC and still keep full manual capability with instant switchover. Basically overlay the CNC over the manual. But I dropped the idea after I got a CNC lathe.
    As far as cost, it depends on the degree of sophistication you want. It could be a few hundred to several thousand.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2016
    32
    Thanks for the information, Jim. Chevalier makes nice machines, and I didn't realize they made a combination lathe like that. But, it's too big for my work area and over my budget.
    Regards,
    Smitty
    Dec 2013
    5717
    It's pretty easy to convert a manual lathe to CNC, the real challenge is to convert and keep the manual capability, even harder to make it a quick changeover (under a minute). You have to use a ball screw on the cross slide, but it is possible to use the longitudinal rack & pinion for the Z axis rather than installing a ball screw. That way you don't disturb the lead screw and quick change gearbox to keep that manual operation. It took me almost a year to figure out the best way to approach that to eliminate the backlash.
    I would look for a older Jet gear head Taiwan built lathe (1980s), that would be a good platform to start with. Then start adding bits & pieces as you can afford it. Nothing wrong with a PM lathe either if you want to buy new. Matt sells good equipment and has excellent customer service.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2017
    411
    I found this on Craigslist yesterday. They say it has never been used... https://richmond.craigslist.org/tls/...438621263.html
    Jan 2016
    32
    Quote Originally Posted by maxspongebob View Post
    I would say it hasn't been used... and a good price. But, unfortunately, I don't see any manual controls on it...
    Smitty
    Jan 2016
    32
    Thanks, Jim...I'll keep my eye out for one.
    So, what did you do to eliminate backlash on the Z axis?
    Smitty
    Dec 2013
    5717
    Use an air spring to tension the carriage/motor, the same way I'm doing it for quill on my mill. The air cylinder stroke only needs to be half the length of the carriage travel with a 2:1 pulley ratio on the cable.
    On the mill I'm using a 1:1 ratio, but the stroke is only 5 inches.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2016
    32
    Okay, that makes sense.
    Oct 2015
    24
    Here are 2 companies that offer CNC lathes that allow manual operation thru electronic hand wheels.
    Fryer Machine Systems Inc. - CNC toolroom lathes milling machines machining centers
    Southwestern Industries, Inc.
    All you need to do is find one that's used and in your price range
    Mar 2004
    413
    Quote Originally Posted by MO Metal View Post
    Here are 2 companies that offer CNC lathes that allow manual operation thru electronic hand wheels......
    Pretty sure ProtoTrak is another. In fact, I believe you can grab a hand wheel even with the machine running to back off from a cut or approach to a cut and the controller will re-correct from any position and keep running.
    Kind of neat when you are running a job for the first time as you can be there and back off of any next move upon approach. If it doesn't look right, you can feedhold and figure it out.
    Chris L
    Oct 2015
    24
    Quote Originally Posted by datac View Post
    Yes, the second link is for the ProtoTrak, we have one in our shop. You can use it manually with the hand wheels, program it on screen with canned cycles or direct moves, or load a g-code file. When you want to slowly run a program to check for any problems you can use the "Trak" mode as datac described. Instead of "run program", you can select Trak mode and turn the hand wheel to run thru your program, tool moves when handle turns, stops when hand wheel stops, backs up on program when cranked back on hand wheels. If it looks OK you can stop Trak mode and switch to Auto from where ever you are in program.
    Thats my 1-1/2 cents of it.
    Aug 2013
    35
    I am currently looking at used Haas TL-1 machines. I think they had handwheels prior to 2015.
    Mar 2006
    51
    I have been using the CNC Masters 1440 lathe for 6 years. It has been a great machine for me. The contact with their office is always direct and willing to listen. There was a problem with the G83 drilling cycle after I upgraded to the new controller. It no longer worked most Fanuc machines have this problem). Omar explained that the old controller allowed a work around that is no longer available after the upgrade. But he is interested in all feed back I give him. His programmer made a new wizard for drilling that included a full retract check box.and it also included a parting and grooving wizard that has great control. Earlier this year I mentioned the thread wizard would be better if there was a spring pass added. It took about 3 weeks for both of these suggestions and I got an updated programs that addressed all of my suggestions. Wow acompany that listens to the customer here in America.
    Feb 2020
    11
    I converted a gearbox Chinese 13-40 to CNC. It really improves the lathe and I love it, but it isn't as good as a full on CNC lathe because it flexes like crazy when you increase the feed rates. I too love the idea of a manual/ CNC combo. I recommend doing it, but make sure you start out with a really stout machine.
  1. B-Axis Lathe Capabilities
    By John Field in forum Employment Opportunity
    Last Post: 09-14-2005, 09:24 PM
  2. C Axis lathe capabilities....
    By Chris D in forum Haas Mills
    Last Post: 06-24-2005, 02:31 PM
  3. 7x mini lathe capabilities???
    By Dan S in forum Mini Lathe
    Last Post: 04-01-2005, 12:57 PM
