585,932 active members*
3,802 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > What inverter to use for a 2 phase spindle?
Results 1 to 10 of 10
    Aug 2015
    142
    I have bough an 2 phase spindle from ebay , precise 750w , and i realy didn't find too much information about 2 phase motors .
    If there are some people that are willing to help me with this issue i will be w happy .
    Thanks.
    May 2013
    480
    Re: What inverter to use for a 2 phase spindle?
    i highly doubt you have a 2 phase spindle.
    link?
    Aug 2015
    142
    https://www.ebay.de/itm/Precise-SC52...4AAOSwnsRaU01i
    as u see it exist , and have 4 wire 2 windings .
    May 2013
    480
    have you measured the resistance of the two coils, found them to be the same, and verified there is no continuity between the two sets of coils?
    Aug 2015
    142
    Yes. There are 5 wires from motor , 2 have 1.3 ohm and the other two have about 1.28 ohm . The other one is gnd.
    15362
    Quote Originally Posted by Andreiir View Post
    These Spindles have there own special drive, there may be some VFD drives that will run it, but might not be such a good idea, contact the manufacture, these are spendy spindles and need the drive that is made for them
    Mactec54
    24221
    Two phase motor requires at least 3 conductors, two phases and a neutral with the right phase angle (90deg). or 4 cond. 2 for each phase.
    A 2 phase drive is required. also 10krpm minimum for that motor.
    Al.
    Albert E.
    Aug 2015
    142
    Ok i get this , and i know there is need of a 2 phase inverter , but where i can buy one?
    From the spindle manufacturer.
    Aug 2015
    142
    I have bought an original inverter and all seems ok , but i saw there is a way with "SCOTT transformer" to adapt the windings form 3 phase to 2 phase motor , so when somebody else hawe same problem , maibe this will hep out .
  1. 3 Phase or single phase inverter
    By richaevans in forum CNC Machine Related Electronics
    Last Post: 08-12-2017, 03:46 AM
  2. Replies: 0
    Last Post: 08-28-2014, 01:51 AM
  3. how to connect single phase spindle motor with 3 phase inverter
    By pdsherathia in forum Benchtop Machines
    Last Post: 01-19-2014, 07:15 PM
  4. Can Mach2 control my phase inverter
    By MrBean in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2004, 01:20 AM
