585,728 active members*
4,002 visitors online*
Thread: file to pdf
Results 1 to 7 of 7
    Feb 2017
    4
    file to pdf
    is there a way to convert a 3d mcx to pdf ? what is the mcx file saved as to be converted?
    thanks
    May 2006
    803
    Re: file to pdf
    just download and install a pdf printer
    i use "Cute PDF Writer"
    And do B/W print for everything before going to paper.
    Feb 2017
    4
    Re: file to pdf
    i can't make the cute pdf work if i put the file on here can someone convert it please thank you.
    Dec 2008
    3109
    Re: file to pdf
    Quote Originally Posted by greenxman72 View Post
    thanks
    Technically, no ..... you cannot convert a Mastercam file to PDF
    You can do a print of the screen view using a PDF printer server
    Other data exchange formats :-
    DXF ==== good for 2D & 3D wireframe items ( ie lines, arcs, splines, dimensions, points and the like
    STEP === very good for sold models
    IGES === very good for solid models
    STL ....... no good for accurate models, OK for rendered shapes, ( tolerances can alter the shape ie a shere ends up looking like a polygon with triangle faces )
    Sep 2008
    87
    Re: file to pdf
    thanks
    I think he wants a 3D PDF. Yes there is such a thing, and it works well. What you need to do is download the free verisurf plug in. Then there is an option to export as 3D PDF.
    This is awesome stuff. Everyone should have them loaded.
    https://www.emastercam.com/forums/to...ools-for-2018/
    Apr 2003
    3578
    Re: file to pdf
    It maters on what version of Mastercam you are running but as Avongil suggested there is a free tool called Verisurf tools that offers the 3D pdf printing. but it is not available for all versions so this why I ask. the link that he shared will get you say the last two version for 2017 and 2018. I do have the installs for many version before on my servers.
    Hope you got this worked out.
    Cadcam
    Sep 2020
    Re: file to pdf
    Hi there, have you found any solutions for the pdf files? To be honest it is a big problem. You know I'm working as a secretary in a company which is selling different pieces for different car marks. So every day I have to work with documents in pdf and sometimes our clients need a different format and I have to work again and so on. The great thing is that my boss has recently discovered this pdf-ocr.com site. There I have the possibility to convert the pdf files into online documents for free and very easily. I like it 'cause like this, I work quickly and make my boss happy hehe.
  1. How to Merge Init file with external buttons file.
    By amitkumar171 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-19-2017, 07:14 PM
  2. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  3. Windows x64 text file splitter that goes by lines, not file size?
    By Galane in forum Uncategorised CAM Discussion
    Last Post: 04-06-2015, 12:26 AM
  4. How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 01-25-2015, 08:37 PM
  5. using a data file for both 3D printer and CNC router , Converting file or ???
    Last Post: 12-17-2014, 01:32 AM
