585,997 active members*
5,042 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Lynx220LSY Sinumerik 828d TLM
    Jan 2018
    Hello,
    I'm working with Doosan Lynx 220LSY with siemens Sinumerik 828d.
    I'm trying to start up Tool load monitor (TLM) but it seems like it doesn't work or work how it should be.
    I recorded dimensions, selected proper axis on each tool that needs to be monitored and recorded current.
    Later when TLM starts to monitor things, it detects broken tool even before machine starts to cut working area, so I lowered the min. tolerance then it goes ok.
    But it doesn't detect realy broken tool (I tried cutting with broken insert and TLM does nothing) I even adjusted Max tolerance and so far no good.
    Does anyone have some instructions or advice how to use it properly?
    Sep 2008
    87
    Re: Doosan Lynx220LSY Sinumerik 828d TLM
    on the fanuc control you need to put M200 (TLM off) at the beginning of the program. Put in M201 right at the cut and M200 again to turn it off.
    Here is a link to the manual I found: Operation Manual DOOSAN Tool load Monitor for Turning Centers (DTML) Release Version 3.X Under-load detect version - PDF
  1. Sinumerik 828D, join several MPF programs
    By Martynas2 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-19-2016, 01:02 PM
  2. Replies: 0
    Last Post: 12-31-2014, 11:25 PM
  3. Sinumerik 828D Network Setup (Siemens)
    By Darkphoenix in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-18-2014, 05:08 PM
  4. g-code for sinumerik 828d problem
    By xray34 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-28-2014, 01:23 AM
  5. g-code for sinumerik 828d problem
    By xray34 in forum G-Code Programing
    Last Post: 09-17-2012, 09:51 PM
