585,567 active members*
3,446 visitors online*
Results 1 to 20 of 20
    Dec 2017
    11
    need some help
    To make a long story short I replaced the motor on my Paxton Patterson CNC training mill. I took several photos as I went along to help with the reassembly and the photos were deleted from the camera. I figured out where every wire plugs into the speed controller but two; the back and white wires that feed to the back of the mill and connect to a relay. Anyone have an idea where they connect.
    Model: HP MIll
    Serial # 00578.
    Feb 2007
    4553
    Re: need some help
    Bison 330,
    Look around for the male spade connectors that are not attracted to anything.
    It would help if you posted images of other components that are in the general proximity.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2017
    11
    Re: need some help
    There are two on the speed controller (F+ F-) but I don't want to hook up the incorrect one. The black wire has 120V and I don't want to destroy the board
    Feb 2007
    4553
    Re: need some help
    Something must be wrong with my eyes, I don't see the images of the board you are referring to.
    Jun 2004
    6618
    Re: need some help
    If they go to a speed control board, then most of those that I have seen are clearly labeled.
    Take a snap shot of the circuit board and we will give it a look.
    Lee
    Dec 2017
    11
    Re: need some help
    I hope these images help
    Attached Thumbnails Attached Thumbnails KIMG0378.jpg   KIMG0385.jpg   KIMG0387.jpg
    Jun 2004
    6618
    Re: need some help
    The only spade terminal that I saw was on the back of the toggle switch. I don't think one wire goes there.
    Do you notice any other spade terminals anywhere?
    Lee
    Dec 2017
    11
    Re: need some help
    There are two spade terminals on the speed controller. F+ and F-.
    Jun 2004
    6618
    Re: need some help
    This looks like the sheet for your drive.
    http://www.galco.com/techdoc/kb/kbic-120_dat.pdf
    I am not sure, but I doubt you would be using the Field coils. F+ or F-.
    How many wires does your motor have? Does it have two brushes or none?
    Lee
    Feb 2007
    4553
    Re: need some help
    Where do the unconnected wires currently lead or attach to?
    Dec 2017
    11
    Re: need some help
    Jun 2004
    6618
    Re: need some help
    What does that relay control?
    Can you read the points on the relay that it is connected to?
    Trying to determine if these are voltage side or control side of the relay.
    Lee
    Dec 2017
    11
    Re: need some help
    LeeWay,
    I have no idea what the relays control.
    Jun 2004
    6618
    Re: need some help
    Do you have a multimeter?
    Lee
    Dec 2017
    11
    Re: need some help
    Yes, I have a meter
    Jun 2004
    6618
    Re: need some help
    Check the black and white wire to see if it is getting 120 VAC across them when power is turned on.
    Lee
    Dec 2017
    11
    Re: need some help
    Yes I am reading 120 from the black wire
    Jun 2004
    6618
    Re: need some help
    Then that wire should be power something with AC voltage. Something that is using a relay to switch on and off. Do you have a coolant pump, dust collector etc?
    Lee
    Dec 2017
    11
    Re: need some help
    No pump of dust collector.....Thank you for all of your help
    Jan 2006
    7
    Re: need some help
    Hate to zombify the thread, but here is the info I have on the motor speed controller you are trying to connect. The schematic I created from my current mill, and wire colors seem to vary greatly between these machines. I hope the attached pictures and pdf are clear enough to help you.
