5x10 Portable CNC Plasma Cutter for Cut 20mm with 120AMP Plasma Power
Brief:This sheet metal portable cnc plasma cutter EagleTec EA-P1530PL is adopted man carried construction, 120amp plasma power source and 5x10 working size. A portable design enables the cnc plasma cutter can be placed in different places as needed. For example, we have a 12 meter long sheet metal that needs to be cut, and a plate of this size is not easy to move. So we can carry the portable cnc plasma cutter and put it on the sheet metal, and then we can start cutting. It is a good solution for large metal cut. Suggested cut thickness is 20mm maximum because it is equipped with 120a plasma.
Learn More, please click: https://www.eaglecnctec.com/products...ma-cutter.html
