585,902 active members*
4,548 visitors online*
Thread: Mach 3
    Dec 2017
    18
    Mach 3
    Hi Everyone,
    I purchased a china zone cnc and of course mach 3 came with it but it is a pirate copy. I do have a legal copy mach3 ,but it is for parallel port and my machine is usb. So is there a way to convert a copy of mach3 from a parallel port to a usb.
    A Big thank You in Advance.
    Dennis Killian
    Apr 2013
    1899
    Re: Mach 3
    Mach3 works with USB as well but you need to get the plugin for your machine from the seller. As far as I remember, you can find some plugins on Mach3 site, but generally that should have been delivered on the CD you got with your machine. Check with the seller or just try to copy the contents of the pirated plugin folder into the legitimate plugin folder.
    Dec 2017
    82
    Re: Mach 3
    Hello
    I can help you to startup your machine.
    where are you located ?
    contact me by [email protected]
  1. Mach 3 parts counter and hour meter mach...
    By [email protected] in forum Mach Software (ArtSoft software)
    Last Post: 01-31-2015, 04:18 AM
  2. Mach 3 - Driver Test results VMWare player (XP -> Mach 3)
    By itolond in forum Machines running Mach Software
    Last Post: 04-07-2014, 01:32 PM
  3. Mach 3 + G540 + UC100 + WJ200 = Can't run spindle from Mach 3?
    By zer0fighter in forum Benchtop Machines
    Last Post: 09-08-2013, 10:54 PM
  4. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
