584,871 active members*
5,427 visitors online*
    Oct 2016
    16
    LaserDRW How to Calibrate Wrong Cut Size?
    Hey Guys,
    I just engraved a 15cm long line and the real length is 13.8cm.
    I read how to fix this but none of the example was for LaserDRW which is (I think) the only program (which I prefer not to change) that works with my machine.
    Any ideas how to fix this?
    Roy
    Mar 2016
    94
    Re: LaserDRW How to Calibrate Wrong Cut Size?
    HI
    DRW always imports the wrong size just select the object an set the size in the right hand size bo
    Oct 2016
    16
    I just realized the problem, it did it only on straight lines and not on squares and turns out that the width of a straight line there is not really clear...
    Anyway I don't use lines only simple squares...
  1. Using KL5056 drivers and MACH3 trying to calibrate axis somethings wrong...
    By truckeic in forum Mach Software (ArtSoft software)
    Last Post: 03-26-2017, 10:36 PM
  2. wrong cut size
    By poorman56 in forum Machines running Mach Software
    Last Post: 02-10-2015, 03:58 AM
  3. Slightly wrong size end result
    By matt3o in forum MadCAM
    Last Post: 09-08-2014, 07:43 AM
  4. Wrong Ballscrew Size?
    By ozzie34231 in forum Linear and Rotary Motion
    Last Post: 01-04-2008, 06:23 PM
