pls, is there an X axis break on lb3000ex2 ?
hello when driling on a lathe, by rotating the spindle ( thus feed only among Z ), is there a break on the X axis ?
i know that there is a break on the Y axis ( at least i was told so, but i never saw it ), but is it also a break on X ?
i was told that if i code long hand, instead of using default cycles, i may avoid engaging the X axis break / however, the one who told me that was not reffering to LB3000ex2, but he was generally speaking
or the servos momentum increases, like when setting the C axis momentum depending on chuck size ?
kindly
