I’m about to attempt to build a CNC Mill/Router table that can effectively cut wood and soft metals (I.e. aluminum). I plan to make the frame out of 80/20 extrusion (I’ve purchased 2 72” 1030 beams and 1 58” 3030 beam. I would like to get as much table Area & Z travel as I can without sacrificing reliability or causing flex. What are realistic dimensions I could have? (I bought NEMA 34 (607 Oz-in) for the Z and a NEMA 23 with a gearbox for the X. I will probably use 2 NEMA 23s on lead screws with ballscrews for the Y. I’m thinking linear rails for the X and supported rails for the Y and Z. Any ideas?
