585,763 active members*
4,302 visitors online*
Results 1 to 3 of 3
    Jan 2018
    3
    Can a 5000 mW or 7000 mW diode laser cut this stuff?
    Hi everyone,
    does anyone know if a 5000 mW or 7000 mW diode laser can cut 8mm cellulose acetate? Or cut it at all?
    Thanks.
    Re: Can a 5000 mW or 7000 mW diode laser cut this stuff?
    Hi there,
    You can try your luck, I've seen a 2500mW diode laser cut a 1mm thick glass after several rounds of slicing with the laser.
    Cellulose Acetate sheets have a melting point of about 225F.
    You might need to cut back and forth more times, or your movement with the laser should be slower as you cut through to allow more heat.
    Let me know how this works for you.
    Thanks.
    Jan 2018
    3
    Thanks for that ArtHeatDesign,
    in the meantime I purchased a 50W CO2 laser, which does the job superbly!
  1. fitting a laser diode to my cnc
    By anthony1973 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-12-2016, 06:59 AM
  2. Diode Laser on/off
    By Kammo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-17-2016, 11:35 AM
  3. Replies: 0
    Last Post: 06-13-2010, 04:03 AM
  4. laser diode
    By zoltan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-21-2007, 07:40 AM
