About to finish my machine. Still need to decide on a couple things. This will be for hobby purpose, occasional use. I'll be cutting aluminum parts and carbon fiber sheets. We all know carbon fiber is hazardous and needs to be dealt with but I'm wondering if just using a milling bath would simplify my setup rather than needing a loud vacuum, boot around the cutter, tubing for the vacuum, etc. Just seems like a milling bath would be so much easier and probably even more effective. I realize the water gets nasty pretty quick, but like I said this is hobby use. Might cut a few carbon pieces a month or so. What about the aluminum? I'm assuming you don't use vacuum for that right? I do plan to build a diy fogbuster type setup for milling the aluminum.
What would you guys do in my case?
