585,908 active members*
3,676 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Thread with Helical Interpolation Milling on Mach3
    Feb 2013
    33
    Hello everybody.
    I'm working in a simple software to generate G-Code for Helical Interpolation for milling a threading on Mach3.
    It runs in a windows terminal.
    You can do internal and external thread.
    Can do it in a single or more than one pass: you enter the max step-over of the tool, and the finishing step-over. And the software calculates how many passes is necessary.
    You can do: Right-hand and Left-hand thread.
    And you can enter the initial angle of thread. I think it is "scroll angle"?
    Some screens / prints of the software:
    Attachment 384848
    Attachment 384850
    Attachment 384852
    Attachment 384822
    Video of my Sieg X2 milling a threading using a helical interpolation on Mach3:
    https://youtu.be/A975VlSB3Zw
    If someone think it's useful and wanna to help me translating the software, let me know.
    Download:
    https://www.dropbox.com/s/quikoeaesn...glish.zip?dl=1
    OUTPUT FILE GENERATED BY SOFTWARE:
    Code:
    ;Df-Major Diameter: 30.00 [mm]
    ;Da-Finishing Diameter: 29.00 [mm]
    ;Di-Minor Diameter: 27.00 [mm]
    ;pl-Tool Step-over: 1.00 [mm]
    ;pl-Tool Finishing Step-over: 0.50 [mm]
    ;np-Number of passes of the thread: 2
    ;step-over pass: 0 diameter: 27.000 [mm]
    ;step-over pass: 1 diameter: 29.000 [mm]
    ;step-over pass: 2 diameter: 30.000 [mm]
    ;Depth 'L' of the thread: 15.00 [mm]
    ;p-Lead Thread: 4.00 [mm]
    ;n-Total number of pitches of thread: 3.75 fios
    ;Initial Angle Scroll: 0.0 [graus] -> Right
    ;Final Angle Scroll: 270.0 [graus]
    ;Thread [INTERNAL] [Right-hand >> Clockwise]
    ;Tool Diameter: 10.00 mm
    ;Precision of step: 0.148 mm
    ;Time: 0.6 minutos
    ;RPM S: 1000 rpm
    ;Feed-Rate (fn): 800.0 [mm / min]
    g00 z3
    g00 x0 y0
    M3
    S1000
    G04 P3
    f800
    g00 x9.500 y-0.000
    ;step-over pass: 1 - pitch pass N: 1
    ;diameter: 29.000 [mm]
    g01 x9.499 y-0.166 z-0.011
    g01 x9.494 y-0.332 z-0.022
    g01 x9.487 y-0.497 z-0.033
    g01 x9.477 y-0.663 z-0.044
    g01 x9.464 y-0.828 z-0.056
    g01 x9.448 y-0.993 z-0.067
    g01 x9.429 y-1.158 z-0.078
    g01 x9.408 y-1.322 z-0.089
    g01 x9.383 y-1.486 z-0.100
    g01 x9.356 y-1.650 z-0.111
    g01 x9.325 y-1.813 z-0.122
    g01 x9.292 y-1.975 z-0.133
    g01 x9.257 y-2.137 z-0.144
    g01 x9.218 y-2.298 z-0.156
    g01 x9.176 y-2.459 z-0.167
    g01 x9.132 y-2.619 z-0.178
    g01 x9.085 y-2.778 z-0.189
    g01 x9.035 y-2.936 z-0.200
    g01 x8.982 y-3.093 z-0.211
    g01 x8.927 y-3.249 z-0.222
    g01 x8.869 y-3.404 z-0.233
    g01 x8.808 y-3.559 z-0.244
    g01 x8.745 y-3.712 z-0.256
    g01 x8.679 y-3.864 z-0.267
    g01 x8.610 y-4.015 z-0.278
    g01 x8.539 y-4.165 z-0.289
    g01 x8.465 y-4.313 z-0.300
    g01 x8.388 y-4.460 z-0.311
    g01 x8.309 y-4.606 z-0.322
    g01 x8.227 y-4.750 z-0.333
    g01 x8.143 y-4.893 z-0.344
    g01 x8.056 y-5.034 z-0.356
    g01 x7.967 y-5.174 z-0.367
    g01 x7.876 y-5.312 z-0.378
    g01 x7.782 y-5.449 z-0.389
    g01 x7.686 y-5.584 z-0.400
    g01 x7.587 y-5.717 z-0.411
    g01 x7.486 y-5.849 z-0.422
    g01 x7.383 y-5.979 z-0.433
    g01 x7.277 y-6.106 z-0.444
    g01 x7.170 y-6.233 z-0.456
    g01 x7.060 y-6.357 z-0.467
    g01 x6.948 y-6.479 z-0.478
    g01 x6.834 y-6.599 z-0.489
    g01 x6.718 y-6.718 z-0.500
    g01 x6.599 y-6.834 z-0.511
    g01 x6.479 y-6.948 z-0.522
    g01 x6.357 y-7.060 z-0.533
    g01 x6.233 y-7.170 z-0.544
    g01 x6.106 y-7.277 z-0.556
    g01 x5.979 y-7.383 z-0.567
    g01 x5.849 y-7.486 z-0.578
    g01 x5.717 y-7.587 z-0.589
    g01 x5.584 y-7.686 z-0.600
    g01 x5.449 y-7.782 z-0.611
    g01 x5.312 y-7.876 z-0.622
    g01 x5.174 y-7.967 z-0.633
    g01 x5.034 y-8.056 z-0.644
    g01 x4.893 y-8.143 z-0.656
    g01 x4.750 y-8.227 z-0.667
    g01 x4.606 y-8.309 z-0.678
    g01 x4.460 y-8.388 z-0.689
    g01 x4.313 y-8.465 z-0.700
    g01 x4.165 y-8.539 z-0.711
    g01 x4.015 y-8.610 z-0.722
    g01 x3.864 y-8.679 z-0.733
    g01 x3.712 y-8.745 z-0.744
    g01 x3.559 y-8.808 z-0.756
    g01 x3.404 y-8.869 z-0.767
    g01 x3.249 y-8.927 z-0.778
    g01 x3.093 y-8.982 z-0.789
    g01 x2.936 y-9.035 z-0.800
    g01 x2.778 y-9.085 z-0.811
    g01 x2.619 y-9.132 z-0.822
    g01 x2.459 y-9.176 z-0.833
    g01 x2.298 y-9.218 z-0.844
    g01 x2.137 y-9.257 z-0.856
    g01 x1.975 y-9.292 z-0.867
    g01 x1.813 y-9.325 z-0.878
    g01 x1.650 y-9.356 z-0.889
    g01 x1.486 y-9.383 z-0.900
    g01 x1.322 y-9.408 z-0.911
    g01 x1.158 y-9.429 z-0.922
    g01 x0.993 y-9.448 z-0.933
    g01 x0.828 y-9.464 z-0.944
    g01 x0.663 y-9.477 z-0.956
    g01 x0.497 y-9.487 z-0.967
    g01 x0.332 y-9.494 z-0.978
    g01 x0.166 y-9.499 z-0.989
    g01 x0.000 y-9.500 z-1.000
    g01 x-0.166 y-9.499 z-1.011
    g01 x-0.332 y-9.494 z-1.022
    g01 x-0.497 y-9.487 z-1.033
    g01 x-0.663 y-9.477 z-1.044
    g01 x-0.828 y-9.464 z-1.056
    g01 x-0.993 y-9.448 z-1.067
    g01 x-1.158 y-9.429 z-1.078
    g01 x-1.322 y-9.408 z-1.089
    g01 x-1.486 y-9.383 z-1.100
    g01 x-1.650 y-9.356 z-1.111
    g01 x-1.813 y-9.325 z-1.122
    g01 x-1.975 y-9.292 z-1.133
    g01 x-2.137 y-9.257 z-1.144
    g01 x-2.298 y-9.218 z-1.156
    g01 x-2.459 y-9.176 z-1.167
    g01 x-2.619 y-9.132 z-1.178
    g01 x-2.778 y-9.085 z-1.189
    g01 x-2.936 y-9.035 z-1.200
    g01 x-3.093 y-8.982 z-1.211
    g01 x-3.249 y-8.927 z-1.222
    g01 x-3.404 y-8.869 z-1.233
    g01 x-3.559 y-8.808 z-1.244
    g01 x-3.712 y-8.745 z-1.256
    g01 x-3.864 y-8.679 z-1.267
    g01 x-4.015 y-8.610 z-1.278
    g01 x-4.165 y-8.539 z-1.289
    g01 x-4.313 y-8.465 z-1.300
    g01 x-4.460 y-8.388 z-1.311
    g01 x-4.606 y-8.309 z-1.322
    g01 x-4.750 y-8.227 z-1.333
    g01 x-4.893 y-8.143 z-1.344
    g01 x-5.034 y-8.056 z-1.356
    g01 x-5.174 y-7.967 z-1.367
    g01 x-5.312 y-7.876 z-1.378
    g01 x-5.449 y-7.782 z-1.389
    g01 x-5.584 y-7.686 z-1.400
    g01 x-5.717 y-7.587 z-1.411
    g01 x-5.849 y-7.486 z-1.422
    g01 x-5.979 y-7.383 z-1.433
    g01 x-6.106 y-7.277 z-1.444
    g01 x-6.233 y-7.170 z-1.456
    g01 x-6.357 y-7.060 z-1.467
    g01 x-6.479 y-6.948 z-1.478
    g01 x-6.599 y-6.834 z-1.489
    g01 x-6.718 y-6.718 z-1.500
    g01 x-6.834 y-6.599 z-1.511
    g01 x-6.948 y-6.479 z-1.522
    g01 x-7.060 y-6.357 z-1.533
    g01 x-7.170 y-6.233 z-1.544
    g01 x-7.277 y-6.106 z-1.556
    g01 x-7.383 y-5.979 z-1.567
    g01 x-7.486 y-5.849 z-1.578
    g01 x-7.587 y-5.717 z-1.589
    g01 x-7.686 y-5.584 z-1.600
    g01 x-7.782 y-5.449 z-1.611
    g01 x-7.876 y-5.312 z-1.622
    g01 x-7.967 y-5.174 z-1.633
    g01 x-8.056 y-5.034 z-1.644
    g01 x-8.143 y-4.893 z-1.656
    g01 x-8.227 y-4.750 z-1.667
    g01 x-8.309 y-4.606 z-1.678
    g01 x-8.388 y-4.460 z-1.689
    g01 x-8.465 y-4.313 z-1.700
    g01 x-8.539 y-4.165 z-1.711
    g01 x-8.610 y-4.015 z-1.722
    g01 x-8.679 y-3.864 z-1.733
    g01 x-8.745 y-3.712 z-1.744
    g01 x-8.808 y-3.559 z-1.756
    g01 x-8.869 y-3.404 z-1.767
    g01 x-8.927 y-3.249 z-1.778
    g01 x-8.982 y-3.093 z-1.789
    g01 x-9.035 y-2.936 z-1.800
    g01 x-9.085 y-2.778 z-1.811
    g01 x-9.132 y-2.619 z-1.822
    g01 x-9.176 y-2.459 z-1.833
    g01 x-9.218 y-2.298 z-1.844
    g01 x-9.257 y-2.137 z-1.856
    g01 x-9.292 y-1.975 z-1.867
    g01 x-9.325 y-1.813 z-1.878
    g01 x-9.356 y-1.650 z-1.889
    g01 x-9.383 y-1.486 z-1.900
    g01 x-9.408 y-1.322 z-1.911
    g01 x-9.429 y-1.158 z-1.922
    g01 x-9.448 y-0.993 z-1.933
    g01 x-9.464 y-0.828 z-1.944
    g01 x-9.477 y-0.663 z-1.956
    g01 x-9.487 y-0.497 z-1.967
    g01 x-9.494 y-0.332 z-1.978
    g01 x-9.499 y-0.166 z-1.989
    g01 x-9.500 y-0.000 z-2.000
    g01 x-9.499 y0.166 z-2.011
    g01 x-9.494 y0.332 z-2.022
    g01 x-9.487 y0.497 z-2.033
    g01 x-9.477 y0.663 z-2.044
    g01 x-9.464 y0.828 z-2.056
    g01 x-9.448 y0.993 z-2.067
    g01 x-9.429 y1.158 z-2.078
    g01 x-9.408 y1.322 z-2.089
    g01 x-9.383 y1.486 z-2.100
    g01 x-9.356 y1.650 z-2.111
    g01 x-9.325 y1.813 z-2.122
    g01 x-9.292 y1.975 z-2.133
    g01 x-9.257 y2.137 z-2.144
    g01 x-9.218 y2.298 z-2.156
    g01 x-9.176 y2.459 z-2.167
    g01 x-9.132 y2.619 z-2.178
    g01 x-9.085 y2.778 z-2.189
    g01 x-9.035 y2.936 z-2.200
    g01 x-8.982 y3.093 z-2.211
    g01 x-8.927 y3.249 z-2.222
    g01 x-8.869 y3.404 z-2.233
    g01 x-8.808 y3.559 z-2.244
    g01 x-8.745 y3.712 z-2.256
    g01 x-8.679 y3.864 z-2.267
    g01 x-8.610 y4.015 z-2.278
    g01 x-8.539 y4.165 z-2.289
    g01 x-8.465 y4.313 z-2.300
    g01 x-8.388 y4.460 z-2.311
    g01 x-8.309 y4.606 z-2.322
    g01 x-8.227 y4.750 z-2.333
    g01 x-8.143 y4.893 z-2.344
    g01 x-8.056 y5.034 z-2.356
    g01 x-7.967 y5.174 z-2.367
    g01 x-7.876 y5.312 z-2.378
    g01 x-7.782 y5.449 z-2.389
    g01 x-7.686 y5.584 z-2.400
    g01 x-7.587 y5.717 z-2.411
    g01 x-7.486 y5.849 z-2.422
    g01 x-7.383 y5.979 z-2.433
    g01 x-7.277 y6.106 z-2.444
    g01 x-7.170 y6.233 z-2.456
    g01 x-7.060 y6.357 z-2.467
    g01 x-6.948 y6.479 z-2.478
    g01 x-6.834 y6.599 z-2.489
    g01 x-6.718 y6.718 z-2.500
    g01 x-6.599 y6.834 z-2.511
    g01 x-6.479 y6.948 z-2.522
    g01 x-6.357 y7.060 z-2.533
    g01 x-6.233 y7.170 z-2.544
    g01 x-6.106 y7.277 z-2.556
    g01 x-5.979 y7.383 z-2.567
    g01 x-5.849 y7.486 z-2.578
    g01 x-5.717 y7.587 z-2.589
    g01 x-5.584 y7.686 z-2.600
    g01 x-5.449 y7.782 z-2.611
    g01 x-5.312 y7.876 z-2.622
    g01 x-5.174 y7.967 z-2.633
    g01 x-5.034 y8.056 z-2.644
    g01 x-4.893 y8.143 z-2.656
    g01 x-4.750 y8.227 z-2.667
    g01 x-4.606 y8.309 z-2.678
    g01 x-4.460 y8.388 z-2.689
    g01 x-4.313 y8.465 z-2.700
    g01 x-4.165 y8.539 z-2.711
    g01 x-4.015 y8.610 z-2.722
    g01 x-3.864 y8.679 z-2.733
    g01 x-3.712 y8.745 z-2.744
    g01 x-3.559 y8.808 z-2.756
    g01 x-3.404 y8.869 z-2.767
    g01 x-3.249 y8.927 z-2.778
    g01 x-3.093 y8.982 z-2.789
    g01 x-2.936 y9.035 z-2.800
    g01 x-2.778 y9.085 z-2.811
    g01 x-2.619 y9.132 z-2.822
    g01 x-2.459 y9.176 z-2.833
    g01 x-2.298 y9.218 z-2.844
    g01 x-2.137 y9.257 z-2.856
    g01 x-1.975 y9.292 z-2.867
    g01 x-1.813 y9.325 z-2.878
    g01 x-1.650 y9.356 z-2.889
    g01 x-1.486 y9.383 z-2.900
    g01 x-1.322 y9.408 z-2.911
    g01 x-1.158 y9.429 z-2.922
    g01 x-0.993 y9.448 z-2.933
    g01 x-0.828 y9.464 z-2.944
    g01 x-0.663 y9.477 z-2.956
    g01 x-0.497 y9.487 z-2.967
    g01 x-0.332 y9.494 z-2.978
    g01 x-0.166 y9.499 z-2.989
    g01 x-0.000 y9.500 z-3.000
    g01 x0.166 y9.499 z-3.011
    g01 x0.332 y9.494 z-3.022
    g01 x0.497 y9.487 z-3.033
    g01 x0.663 y9.477 z-3.044
    g01 x0.828 y9.464 z-3.056
    g01 x0.993 y9.448 z-3.067
    g01 x1.158 y9.429 z-3.078
    g01 x1.322 y9.408 z-3.089
    g01 x1.486 y9.383 z-3.100
    g01 x1.650 y9.356 z-3.111
    g01 x1.813 y9.325 z-3.122
    g01 x1.975 y9.292 z-3.133
    g01 x2.137 y9.257 z-3.144
    g01 x2.298 y9.218 z-3.156
    g01 x2.459 y9.176 z-3.167
    g01 x2.619 y9.132 z-3.178
    g01 x2.778 y9.085 z-3.189
    g01 x2.936 y9.035 z-3.200
    g01 x3.093 y8.982 z-3.211
    g01 x3.249 y8.927 z-3.222
    g01 x3.404 y8.869 z-3.233
    g01 x3.559 y8.808 z-3.244
    g01 x3.712 y8.745 z-3.256
    g01 x3.864 y8.679 z-3.267
    g01 x4.015 y8.610 z-3.278
    g01 x4.165 y8.539 z-3.289
    g01 x4.313 y8.465 z-3.300
    g01 x4.460 y8.388 z-3.311
    g01 x4.606 y8.309 z-3.322
    g01 x4.750 y8.227 z-3.333
    g01 x4.893 y8.143 z-3.344
    g01 x5.034 y8.056 z-3.356
    g01 x5.174 y7.967 z-3.367
    g01 x5.312 y7.876 z-3.378
    g01 x5.449 y7.782 z-3.389
    g01 x5.584 y7.686 z-3.400
    g01 x5.717 y7.587 z-3.411
    g01 x5.849 y7.486 z-3.422
    g01 x5.979 y7.383 z-3.433
    g01 x6.106 y7.277 z-3.444
    g01 x6.233 y7.170 z-3.456
    g01 x6.357 y7.060 z-3.467
    g01 x6.479 y6.948 z-3.478
    g01 x6.599 y6.834 z-3.489
    g01 x6.718 y6.718 z-3.500
    g01 x6.834 y6.599 z-3.511
    g01 x6.948 y6.479 z-3.522
    g01 x7.060 y6.357 z-3.533
    g01 x7.170 y6.233 z-3.544
    g01 x7.277 y6.106 z-3.556
    g01 x7.383 y5.979 z-3.567
    g01 x7.486 y5.849 z-3.578
    g01 x7.587 y5.717 z-3.589
    g01 x7.686 y5.584 z-3.600
    g01 x7.782 y5.449 z-3.611
    g01 x7.876 y5.312 z-3.622
    g01 x7.967 y5.174 z-3.633
    g01 x8.056 y5.034 z-3.644
    g01 x8.143 y4.893 z-3.656
    g01 x8.227 y4.750 z-3.667
    g01 x8.309 y4.606 z-3.678
    g01 x8.388 y4.460 z-3.689
    g01 x8.465 y4.313 z-3.700
    g01 x8.539 y4.165 z-3.711
    g01 x8.610 y4.015 z-3.722
    g01 x8.679 y3.864 z-3.733
    g01 x8.745 y3.712 z-3.744
    g01 x8.808 y3.559 z-3.756
    g01 x8.869 y3.404 z-3.767
    g01 x8.927 y3.249 z-3.778
    g01 x8.982 y3.093 z-3.789
    g01 x9.035 y2.936 z-3.800
    g01 x9.085 y2.778 z-3.811
    g01 x9.132 y2.619 z-3.822
    g01 x9.176 y2.459 z-3.833
    g01 x9.218 y2.298 z-3.844
    g01 x9.257 y2.137 z-3.856
    g01 x9.292 y1.975 z-3.867
    g01 x9.325 y1.813 z-3.878
    g01 x9.356 y1.650 z-3.889
    g01 x9.383 y1.486 z-3.900
    g01 x9.408 y1.322 z-3.911
    g01 x9.429 y1.158 z-3.922
    g01 x9.448 y0.993 z-3.933
    g01 x9.464 y0.828 z-3.944
    g01 x9.477 y0.663 z-3.956
    g01 x9.487 y0.497 z-3.967
    g01 x9.494 y0.332 z-3.978
    g01 x9.499 y0.166 z-3.989
    g01 x9.500 y0.000 z-4.000
    ;step-over pass: 1 - pitch pass N: 2
    g01 x9.499 y-0.166 z-4.011
    g01 x9.494 y-0.332 z-4.022
    g01 x9.487 y-0.497 z-4.033
    g01 x9.477 y-0.663 z-4.044
    g01 x9.464 y-0.828 z-4.056
    g01 x9.448 y-0.993 z-4.067
    g01 x9.429 y-1.158 z-4.078
    g01 x9.408 y-1.322 z-4.089
    g01 x9.383 y-1.486 z-4.100
    g01 x9.356 y-1.650 z-4.111
    g01 x9.325 y-1.813 z-4.122
    g01 x9.292 y-1.975 z-4.133
    g01 x9.257 y-2.137 z-4.144
    g01 x9.218 y-2.298 z-4.156
    g01 x9.176 y-2.459 z-4.167
    g01 x9.132 y-2.619 z-4.178
    g01 x9.085 y-2.778 z-4.189
    g01 x9.035 y-2.936 z-4.200
    g01 x8.982 y-3.093 z-4.211
    g01 x8.927 y-3.249 z-4.222
    g01 x8.869 y-3.404 z-4.233
    g01 x8.808 y-3.559 z-4.244
    g01 x8.745 y-3.712 z-4.256
    g01 x8.679 y-3.864 z-4.267
    g01 x8.610 y-4.015 z-4.278
    g01 x8.539 y-4.165 z-4.289
    g01 x8.465 y-4.313 z-4.300
    g01 x8.388 y-4.460 z-4.311
    g01 x8.309 y-4.606 z-4.322
    g01 x8.227 y-4.750 z-4.333
    g01 x8.143 y-4.893 z-4.344
    g01 x8.056 y-5.034 z-4.356
    g01 x7.967 y-5.174 z-4.367
    g01 x7.876 y-5.312 z-4.378
    g01 x7.782 y-5.449 z-4.389
    g01 x7.686 y-5.584 z-4.400
    g01 x7.587 y-5.717 z-4.411
    g01 x7.486 y-5.849 z-4.422
    g01 x7.383 y-5.979 z-4.433
    g01 x7.277 y-6.106 z-4.444
    g01 x7.170 y-6.233 z-4.456
    g01 x7.060 y-6.357 z-4.467
    g01 x6.948 y-6.479 z-4.478
    g01 x6.834 y-6.599 z-4.489
    g01 x6.718 y-6.718 z-4.500
    g01 x6.599 y-6.834 z-4.511
    g01 x6.479 y-6.948 z-4.522
    g01 x6.357 y-7.060 z-4.533
    g01 x6.233 y-7.170 z-4.544
    g01 x6.106 y-7.277 z-4.556
    g01 x5.979 y-7.383 z-4.567
    g01 x5.849 y-7.486 z-4.578
    g01 x5.717 y-7.587 z-4.589
    g01 x5.584 y-7.686 z-4.600
    g01 x5.449 y-7.782 z-4.611
    g01 x5.312 y-7.876 z-4.622
    g01 x5.174 y-7.967 z-4.633
    g01 x5.034 y-8.056 z-4.644
    g01 x4.893 y-8.143 z-4.656
    g01 x4.750 y-8.227 z-4.667
    g01 x4.606 y-8.309 z-4.678
    g01 x4.460 y-8.388 z-4.689
    g01 x4.313 y-8.465 z-4.700
    g01 x4.165 y-8.539 z-4.711
    g01 x4.015 y-8.610 z-4.722
    g01 x3.864 y-8.679 z-4.733
    g01 x3.712 y-8.745 z-4.744
    g01 x3.559 y-8.808 z-4.756
    g01 x3.404 y-8.869 z-4.767
    g01 x3.249 y-8.927 z-4.778
    g01 x3.093 y-8.982 z-4.789
    g01 x2.936 y-9.035 z-4.800
    g01 x2.778 y-9.085 z-4.811
    g01 x2.619 y-9.132 z-4.822
    g01 x2.459 y-9.176 z-4.833
    g01 x2.298 y-9.218 z-4.844
    g01 x2.137 y-9.257 z-4.856
    g01 x1.975 y-9.292 z-4.867
    g01 x1.813 y-9.325 z-4.878
    g01 x1.650 y-9.356 z-4.889
    g01 x1.486 y-9.383 z-4.900
    g01 x1.322 y-9.408 z-4.911
    g01 x1.158 y-9.429 z-4.922
    g01 x0.993 y-9.448 z-4.933
    g01 x0.828 y-9.464 z-4.944
    g01 x0.663 y-9.477 z-4.956
    g01 x0.497 y-9.487 z-4.967
    g01 x0.332 y-9.494 z-4.978
    g01 x0.166 y-9.499 z-4.989
    g01 x0.000 y-9.500 z-5.000
    g01 x-0.166 y-9.499 z-5.011
    g01 x-0.332 y-9.494 z-5.022
    g01 x-0.497 y-9.487 z-5.033
    g01 x-0.663 y-9.477 z-5.044
    g01 x-0.828 y-9.464 z-5.056
    g01 x-0.993 y-9.448 z-5.067
    g01 x-1.158 y-9.429 z-5.078
    g01 x-1.322 y-9.408 z-5.089
    g01 x-1.486 y-9.383 z-5.100
    g01 x-1.650 y-9.356 z-5.111
    g01 x-1.813 y-9.325 z-5.122
    g01 x-1.975 y-9.292 z-5.133
    g01 x-2.137 y-9.257 z-5.144
    g01 x-2.298 y-9.218 z-5.156
    g01 x-2.459 y-9.176 z-5.167
    g01 x-2.619 y-9.132 z-5.178
    g01 x-2.778 y-9.085 z-5.189
    g01 x-2.936 y-9.035 z-5.200
    g01 x-3.093 y-8.982 z-5.211
    g01 x-3.249 y-8.927 z-5.222
    g01 x-3.404 y-8.869 z-5.233
    g01 x-3.559 y-8.808 z-5.244
    g01 x-3.712 y-8.745 z-5.256
    g01 x-3.864 y-8.679 z-5.267
    g01 x-4.015 y-8.610 z-5.278
    g01 x-4.165 y-8.539 z-5.289
    g01 x-4.313 y-8.465 z-5.300
    g01 x-4.460 y-8.388 z-5.311
    g01 x-4.606 y-8.309 z-5.322
    g01 x-4.750 y-8.227 z-5.333
    g01 x-4.893 y-8.143 z-5.344
    g01 x-5.034 y-8.056 z-5.356
    g01 x-5.174 y-7.967 z-5.367
    g01 x-5.312 y-7.876 z-5.378
    g01 x-5.449 y-7.782 z-5.389
    g01 x-5.584 y-7.686 z-5.400
    g01 x-5.717 y-7.587 z-5.411
    g01 x-5.849 y-7.486 z-5.422
    g01 x-5.979 y-7.383 z-5.433
    g01 x-6.106 y-7.277 z-5.444
    g01 x-6.233 y-7.170 z-5.456
    g01 x-6.357 y-7.060 z-5.467
    g01 x-6.479 y-6.948 z-5.478
    g01 x-6.599 y-6.834 z-5.489
    g01 x-6.718 y-6.718 z-5.500
    g01 x-6.834 y-6.599 z-5.511
    g01 x-6.948 y-6.479 z-5.522
    g01 x-7.060 y-6.357 z-5.533
    g01 x-7.170 y-6.233 z-5.544
    g01 x-7.277 y-6.106 z-5.556
    g01 x-7.383 y-5.979 z-5.567
    g01 x-7.486 y-5.849 z-5.578
    g01 x-7.587 y-5.717 z-5.589
    g01 x-7.686 y-5.584 z-5.600
    g01 x-7.782 y-5.449 z-5.611
    g01 x-7.876 y-5.312 z-5.622
    g01 x-7.967 y-5.174 z-5.633
    g01 x-8.056 y-5.034 z-5.644
    g01 x-8.143 y-4.893 z-5.656
    g01 x-8.227 y-4.750 z-5.667
    g01 x-8.309 y-4.606 z-5.678
    g01 x-8.388 y-4.460 z-5.689
    g01 x-8.465 y-4.313 z-5.700
    g01 x-8.539 y-4.165 z-5.711
    g01 x-8.610 y-4.015 z-5.722
    g01 x-8.679 y-3.864 z-5.733
    g01 x-8.745 y-3.712 z-5.744
    g01 x-8.808 y-3.559 z-5.756
    g01 x-8.869 y-3.404 z-5.767
    g01 x-8.927 y-3.249 z-5.778
    g01 x-8.982 y-3.093 z-5.789
    g01 x-9.035 y-2.936 z-5.800
    g01 x-9.085 y-2.778 z-5.811
    g01 x-9.132 y-2.619 z-5.822
    g01 x-9.176 y-2.459 z-5.833
    g01 x-9.218 y-2.298 z-5.844
    g01 x-9.257 y-2.137 z-5.856
    g01 x-9.292 y-1.975 z-5.867
    g01 x-9.325 y-1.813 z-5.878
    g01 x-9.356 y-1.650 z-5.889
    g01 x-9.383 y-1.486 z-5.900
    g01 x-9.408 y-1.322 z-5.911
    g01 x-9.429 y-1.158 z-5.922
    g01 x-9.448 y-0.993 z-5.933
    g01 x-9.464 y-0.828 z-5.944
    g01 x-9.477 y-0.663 z-5.956
    g01 x-9.487 y-0.497 z-5.967
    g01 x-9.494 y-0.332 z-5.978
    g01 x-9.499 y-0.166 z-5.989
    g01 x-9.500 y-0.000 z-6.000
    g01 x-9.499 y0.166 z-6.011
    g01 x-9.494 y0.332 z-6.022
    g01 x-9.487 y0.497 z-6.033
    g01 x-9.477 y0.663 z-6.044
    g01 x-9.464 y0.828 z-6.056
    g01 x-9.448 y0.993 z-6.067
    g01 x-9.429 y1.158 z-6.078
    g01 x-9.408 y1.322 z-6.089
    g01 x-9.383 y1.486 z-6.100
    g01 x-9.356 y1.650 z-6.111
    g01 x-9.325 y1.813 z-6.122
    g01 x-9.292 y1.975 z-6.133
    g01 x-9.257 y2.137 z-6.144
    g01 x-9.218 y2.298 z-6.156
    g01 x-9.176 y2.459 z-6.167
    g01 x-9.132 y2.619 z-6.178
    g01 x-9.085 y2.778 z-6.189
    g01 x-9.035 y2.936 z-6.200
    g01 x-8.982 y3.093 z-6.211
    g01 x-8.927 y3.249 z-6.222
    g01 x-8.869 y3.404 z-6.233
    g01 x-8.808 y3.559 z-6.244
    g01 x-8.745 y3.712 z-6.256
    g01 x-8.679 y3.864 z-6.267
    g01 x-8.610 y4.015 z-6.278
    g01 x-8.539 y4.165 z-6.289
    g01 x-8.465 y4.313 z-6.300
    g01 x-8.388 y4.460 z-6.311
    g01 x-8.309 y4.606 z-6.322
    g01 x-8.227 y4.750 z-6.333
    g01 x-8.143 y4.893 z-6.344
    g01 x-8.056 y5.034 z-6.356
    g01 x-7.967 y5.174 z-6.367
    g01 x-7.876 y5.312 z-6.378
    g01 x-7.782 y5.449 z-6.389
    g01 x-7.686 y5.584 z-6.400
    g01 x-7.587 y5.717 z-6.411
    g01 x-7.486 y5.849 z-6.422
    g01 x-7.383 y5.979 z-6.433
    g01 x-7.277 y6.106 z-6.444
    g01 x-7.170 y6.233 z-6.456
    g01 x-7.060 y6.357 z-6.467
    g01 x-6.948 y6.479 z-6.478
    g01 x-6.834 y6.599 z-6.489
    g01 x-6.718 y6.718 z-6.500
    g01 x-6.599 y6.834 z-6.511
    g01 x-6.479 y6.948 z-6.522
    g01 x-6.357 y7.060 z-6.533
    g01 x-6.233 y7.170 z-6.544
    g01 x-6.106 y7.277 z-6.556
    g01 x-5.979 y7.383 z-6.567
    g01 x-5.849 y7.486 z-6.578
    g01 x-5.717 y7.587 z-6.589
    g01 x-5.584 y7.686 z-6.600
    g01 x-5.449 y7.782 z-6.611
    g01 x-5.312 y7.876 z-6.622
    g01 x-5.174 y7.967 z-6.633
    g01 x-5.034 y8.056 z-6.644
    g01 x-4.893 y8.143 z-6.656
    g01 x-4.750 y8.227 z-6.667
    g01 x-4.606 y8.309 z-6.678
    g01 x-4.460 y8.388 z-6.689
    g01 x-4.313 y8.465 z-6.700
    g01 x-4.165 y8.539 z-6.711
    g01 x-4.015 y8.610 z-6.722
    g01 x-3.864 y8.679 z-6.733
    g01 x-3.712 y8.745 z-6.744
    g01 x-3.559 y8.808 z-6.756
    g01 x-3.404 y8.869 z-6.767
    g01 x-3.249 y8.927 z-6.778
    g01 x-3.093 y8.982 z-6.789
    g01 x-2.936 y9.035 z-6.800
    g01 x-2.778 y9.085 z-6.811
    g01 x-2.619 y9.132 z-6.822
    g01 x-2.459 y9.176 z-6.833
    g01 x-2.298 y9.218 z-6.844
    g01 x-2.137 y9.257 z-6.856
    g01 x-1.975 y9.292 z-6.867
    g01 x-1.813 y9.325 z-6.878
    g01 x-1.650 y9.356 z-6.889
    g01 x-1.486 y9.383 z-6.900
    g01 x-1.322 y9.408 z-6.911
    g01 x-1.158 y9.429 z-6.922
    g01 x-0.993 y9.448 z-6.933
    g01 x-0.828 y9.464 z-6.944
    g01 x-0.663 y9.477 z-6.956
    g01 x-0.497 y9.487 z-6.967
    g01 x-0.332 y9.494 z-6.978
    g01 x-0.166 y9.499 z-6.989
    g01 x-0.000 y9.500 z-7.000
    g01 x0.166 y9.499 z-7.011
    g01 x0.332 y9.494 z-7.022
    g01 x0.497 y9.487 z-7.033
    g01 x0.663 y9.477 z-7.044
    g01 x0.828 y9.464 z-7.056
    g01 x0.993 y9.448 z-7.067
    g01 x1.158 y9.429 z-7.078
    g01 x1.322 y9.408 z-7.089
    g01 x1.486 y9.383 z-7.100
    g01 x1.650 y9.356 z-7.111
    g01 x1.813 y9.325 z-7.122
    g01 x1.975 y9.292 z-7.133
    g01 x2.137 y9.257 z-7.144
    g01 x2.298 y9.218 z-7.156
    g01 x2.459 y9.176 z-7.167
    g01 x2.619 y9.132 z-7.178
    g01 x2.778 y9.085 z-7.189
    g01 x2.936 y9.035 z-7.200
    g01 x3.093 y8.982 z-7.211
    g01 x3.249 y8.927 z-7.222
    g01 x3.404 y8.869 z-7.233
    g01 x3.559 y8.808 z-7.244
    g01 x3.712 y8.745 z-7.256
    g01 x3.864 y8.679 z-7.267
    g01 x4.015 y8.610 z-7.278
    g01 x4.165 y8.539 z-7.289
    g01 x4.313 y8.465 z-7.300
    g01 x4.460 y8.388 z-7.311
    g01 x4.606 y8.309 z-7.322
    g01 x4.750 y8.227 z-7.333
    g01 x4.893 y8.143 z-7.344
    g01 x5.034 y8.056 z-7.356
    g01 x5.174 y7.967 z-7.367
    g01 x5.312 y7.876 z-7.378
    g01 x5.449 y7.782 z-7.389
    g01 x5.584 y7.686 z-7.400
    g01 x5.717 y7.587 z-7.411
    g01 x5.849 y7.486 z-7.422
    g01 x5.979 y7.383 z-7.433
    g01 x6.106 y7.277 z-7.444
    g01 x6.233 y7.170 z-7.456
    g01 x6.357 y7.060 z-7.467
    g01 x6.479 y6.948 z-7.478
    g01 x6.599 y6.834 z-7.489
    g01 x6.718 y6.718 z-7.500
    g01 x6.834 y6.599 z-7.511
    g01 x6.948 y6.479 z-7.522
    g01 x7.060 y6.357 z-7.533
    g01 x7.170 y6.233 z-7.544
    g01 x7.277 y6.106 z-7.556
    g01 x7.383 y5.979 z-7.567
    g01 x7.486 y5.849 z-7.578
    g01 x7.587 y5.717 z-7.589
    g01 x7.686 y5.584 z-7.600
    g01 x7.782 y5.449 z-7.611
    g01 x7.876 y5.312 z-7.622
    g01 x7.967 y5.174 z-7.633
    g01 x8.056 y5.034 z-7.644
    g01 x8.143 y4.893 z-7.656
    g01 x8.227 y4.750 z-7.667
    g01 x8.309 y4.606 z-7.678
    g01 x8.388 y4.460 z-7.689
    g01 x8.465 y4.313 z-7.700
    g01 x8.539 y4.165 z-7.711
    g01 x8.610 y4.015 z-7.722
    g01 x8.679 y3.864 z-7.733
    g01 x8.745 y3.712 z-7.744
    g01 x8.808 y3.559 z-7.756
    g01 x8.869 y3.404 z-7.767
    g01 x8.927 y3.249 z-7.778
    g01 x8.982 y3.093 z-7.789
    g01 x9.035 y2.936 z-7.800
    g01 x9.085 y2.778 z-7.811
    g01 x9.132 y2.619 z-7.822
    g01 x9.176 y2.459 z-7.833
    g01 x9.218 y2.298 z-7.844
    g01 x9.257 y2.137 z-7.856
    g01 x9.292 y1.975 z-7.867
    g01 x9.325 y1.813 z-7.878
    g01 x9.356 y1.650 z-7.889
    g01 x9.383 y1.486 z-7.900
    g01 x9.408 y1.322 z-7.911
    g01 x9.429 y1.158 z-7.922
    g01 x9.448 y0.993 z-7.933
    g01 x9.464 y0.828 z-7.944
    g01 x9.477 y0.663 z-7.956
    g01 x9.487 y0.497 z-7.967
    g01 x9.494 y0.332 z-7.978
    g01 x9.499 y0.166 z-7.989
    g01 x9.500 y0.000 z-8.000
    ;step-over pass: 1 - pitch pass N: 3
    g01 x9.499 y-0.166 z-8.011
    g01 x9.494 y-0.332 z-8.022
    g01 x9.487 y-0.497 z-8.033
    g01 x9.477 y-0.663 z-8.044
    g01 x9.464 y-0.828 z-8.056
    g01 x9.448 y-0.993 z-8.067
    g01 x9.429 y-1.158 z-8.078
    g01 x9.408 y-1.322 z-8.089
    g01 x9.383 y-1.486 z-8.100
    g01 x9.356 y-1.650 z-8.111
    g01 x9.325 y-1.813 z-8.122
    g01 x9.292 y-1.975 z-8.133
    g01 x9.257 y-2.137 z-8.144
    g01 x9.218 y-2.298 z-8.156
    g01 x9.176 y-2.459 z-8.167
    g01 x9.132 y-2.619 z-8.178
    g01 x9.085 y-2.778 z-8.189
    g01 x9.035 y-2.936 z-8.200
    g01 x8.982 y-3.093 z-8.211
    g01 x8.927 y-3.249 z-8.222
    g01 x8.869 y-3.404 z-8.233
    g01 x8.808 y-3.559 z-8.244
    g01 x8.745 y-3.712 z-8.256
    g01 x8.679 y-3.864 z-8.267
    g01 x8.610 y-4.015 z-8.278
    g01 x8.539 y-4.165 z-8.289
    g01 x8.465 y-4.313 z-8.300
    g01 x8.388 y-4.460 z-8.311
    g01 x8.309 y-4.606 z-8.322
    g01 x8.227 y-4.750 z-8.333
    g01 x8.143 y-4.893 z-8.344
    g01 x8.056 y-5.034 z-8.356
    g01 x7.967 y-5.174 z-8.367
    g01 x7.876 y-5.312 z-8.378
    g01 x7.782 y-5.449 z-8.389
    g01 x7.686 y-5.584 z-8.400
    g01 x7.587 y-5.717 z-8.411
    g01 x7.486 y-5.849 z-8.422
    g01 x7.383 y-5.979 z-8.433
    g01 x7.277 y-6.106 z-8.444
    g01 x7.170 y-6.233 z-8.456
    g01 x7.060 y-6.357 z-8.467
    g01 x6.948 y-6.479 z-8.478
    g01 x6.834 y-6.599 z-8.489
    g01 x6.718 y-6.718 z-8.500
    g01 x6.599 y-6.834 z-8.511
    g01 x6.479 y-6.948 z-8.522
    g01 x6.357 y-7.060 z-8.533
    g01 x6.233 y-7.170 z-8.544
    g01 x6.106 y-7.277 z-8.556
    g01 x5.979 y-7.383 z-8.567
    g01 x5.849 y-7.486 z-8.578
    g01 x5.717 y-7.587 z-8.589
    g01 x5.584 y-7.686 z-8.600
    g01 x5.449 y-7.782 z-8.611
    g01 x5.312 y-7.876 z-8.622
    g01 x5.174 y-7.967 z-8.633
    g01 x5.034 y-8.056 z-8.644
    g01 x4.893 y-8.143 z-8.656
    g01 x4.750 y-8.227 z-8.667
    g01 x4.606 y-8.309 z-8.678
    g01 x4.460 y-8.388 z-8.689
    g01 x4.313 y-8.465 z-8.700
    g01 x4.165 y-8.539 z-8.711
    g01 x4.015 y-8.610 z-8.722
    g01 x3.864 y-8.679 z-8.733
    g01 x3.712 y-8.745 z-8.744
    g01 x3.559 y-8.808 z-8.756
    g01 x3.404 y-8.869 z-8.767
    g01 x3.249 y-8.927 z-8.778
    g01 x3.093 y-8.982 z-8.789
    g01 x2.936 y-9.035 z-8.800
    g01 x2.778 y-9.085 z-8.811
    g01 x2.619 y-9.132 z-8.822
    g01 x2.459 y-9.176 z-8.833
    g01 x2.298 y-9.218 z-8.844
    g01 x2.137 y-9.257 z-8.856
    g01 x1.975 y-9.292 z-8.867
    g01 x1.813 y-9.325 z-8.878
    g01 x1.650 y-9.356 z-8.889
    g01 x1.486 y-9.383 z-8.900
    g01 x1.322 y-9.408 z-8.911
    g01 x1.158 y-9.429 z-8.922
    g01 x0.993 y-9.448 z-8.933
    g01 x0.828 y-9.464 z-8.944
    g01 x0.663 y-9.477 z-8.956
    g01 x0.497 y-9.487 z-8.967
    g01 x0.332 y-9.494 z-8.978
    g01 x0.166 y-9.499 z-8.989
    g01 x0.000 y-9.500 z-9.000
    g01 x-0.166 y-9.499 z-9.011
    g01 x-0.332 y-9.494 z-9.022
    g01 x-0.497 y-9.487 z-9.033
    g01 x-0.663 y-9.477 z-9.044
    g01 x-0.828 y-9.464 z-9.056
    g01 x-0.993 y-9.448 z-9.067
    g01 x-1.158 y-9.429 z-9.078
    g01 x-1.322 y-9.408 z-9.089
    g01 x-1.486 y-9.383 z-9.100
    g01 x-1.650 y-9.356 z-9.111
    g01 x-1.813 y-9.325 z-9.122
    g01 x-1.975 y-9.292 z-9.133
    g01 x-2.137 y-9.257 z-9.144
    g01 x-2.298 y-9.218 z-9.156
    g01 x-2.459 y-9.176 z-9.167
    g01 x-2.619 y-9.132 z-9.178
    g01 x-2.778 y-9.085 z-9.189
    g01 x-2.936 y-9.035 z-9.200
    g01 x-3.093 y-8.982 z-9.211
    g01 x-3.249 y-8.927 z-9.222
    g01 x-3.404 y-8.869 z-9.233
    g01 x-3.559 y-8.808 z-9.244
    g01 x-3.712 y-8.745 z-9.256
    g01 x-3.864 y-8.679 z-9.267
    g01 x-4.015 y-8.610 z-9.278
    g01 x-4.165 y-8.539 z-9.289
    g01 x-4.313 y-8.465 z-9.300
    g01 x-4.460 y-8.388 z-9.311
    g01 x-4.606 y-8.309 z-9.322
    g01 x-4.750 y-8.227 z-9.333
    g01 x-4.893 y-8.143 z-9.344
    g01 x-5.034 y-8.056 z-9.356
    g01 x-5.174 y-7.967 z-9.367
    g01 x-5.312 y-7.876 z-9.378
    g01 x-5.449 y-7.782 z-9.389
    g01 x-5.584 y-7.686 z-9.400
    g01 x-5.717 y-7.587 z-9.411
    g01 x-5.849 y-7.486 z-9.422
    g01 x-5.979 y-7.383 z-9.433
    g01 x-6.106 y-7.277 z-9.444
    g01 x-6.233 y-7.170 z-9.456
    g01 x-6.357 y-7.060 z-9.467
    g01 x-6.479 y-6.948 z-9.478
    g01 x-6.599 y-6.834 z-9.489
    g01 x-6.718 y-6.718 z-9.500
    g01 x-6.834 y-6.599 z-9.511
    g01 x-6.948 y-6.479 z-9.522
    g01 x-7.060 y-6.357 z-9.533
    g01 x-7.170 y-6.233 z-9.544
    g01 x-7.277 y-6.106 z-9.556
    g01 x-7.383 y-5.979 z-9.567
    g01 x-7.486 y-5.849 z-9.578
    g01 x-7.587 y-5.717 z-9.589
    g01 x-7.686 y-5.584 z-9.600
    g01 x-7.782 y-5.449 z-9.611
    g01 x-7.876 y-5.312 z-9.622
    g01 x-7.967 y-5.174 z-9.633
    g01 x-8.056 y-5.034 z-9.644
    g01 x-8.143 y-4.893 z-9.656
    g01 x-8.227 y-4.750 z-9.667
    g01 x-8.309 y-4.606 z-9.678
    g01 x-8.388 y-4.460 z-9.689
    g01 x-8.465 y-4.313 z-9.700
    g01 x-8.539 y-4.165 z-9.711
    g01 x-8.610 y-4.015 z-9.722
    g01 x-8.679 y-3.864 z-9.733
    g01 x-8.745 y-3.712 z-9.744
    g01 x-8.808 y-3.559 z-9.756
    g01 x-8.869 y-3.404 z-9.767
    g01 x-8.927 y-3.249 z-9.778
    g01 x-8.982 y-3.093 z-9.789
    g01 x-9.035 y-2.936 z-9.800
    g01 x-9.085 y-2.778 z-9.811
    g01 x-9.132 y-2.619 z-9.822
    g01 x-9.176 y-2.459 z-9.833
    g01 x-9.218 y-2.298 z-9.844
    g01 x-9.257 y-2.137 z-9.856
    g01 x-9.292 y-1.975 z-9.867
    g01 x-9.325 y-1.813 z-9.878
    g01 x-9.356 y-1.650 z-9.889
    g01 x-9.383 y-1.486 z-9.900
    g01 x-9.408 y-1.322 z-9.911
    g01 x-9.429 y-1.158 z-9.922
    g01 x-9.448 y-0.993 z-9.933
    g01 x-9.464 y-0.828 z-9.944
    g01 x-9.477 y-0.663 z-9.956
    g01 x-9.487 y-0.497 z-9.967
    g01 x-9.494 y-0.332 z-9.978
    g01 x-9.499 y-0.166 z-9.989
    g01 x-9.500 y-0.000 z-10.000
    g01 x-9.499 y0.166 z-10.011
    g01 x-9.494 y0.332 z-10.022
    g01 x-9.487 y0.497 z-10.033
    g01 x-9.477 y0.663 z-10.044
    g01 x-9.464 y0.828 z-10.056
    g01 x-9.448 y0.993 z-10.067
    g01 x-9.429 y1.158 z-10.078
    g01 x-9.408 y1.322 z-10.089
    g01 x-9.383 y1.486 z-10.100
    g01 x-9.356 y1.650 z-10.111
    g01 x-9.325 y1.813 z-10.122
    g01 x-9.292 y1.975 z-10.133
    g01 x-9.257 y2.137 z-10.144
    g01 x-9.218 y2.298 z-10.156
    g01 x-9.176 y2.459 z-10.167
    g01 x-9.132 y2.619 z-10.178
    g01 x-9.085 y2.778 z-10.189
    g01 x-9.035 y2.936 z-10.200
    g01 x-8.982 y3.093 z-10.211
    g01 x-8.927 y3.249 z-10.222
    g01 x-8.869 y3.404 z-10.233
    g01 x-8.808 y3.559 z-10.244
    g01 x-8.745 y3.712 z-10.256
    g01 x-8.679 y3.864 z-10.267
    g01 x-8.610 y4.015 z-10.278
    g01 x-8.539 y4.165 z-10.289
    g01 x-8.465 y4.313 z-10.300
    g01 x-8.388 y4.460 z-10.311
    g01 x-8.309 y4.606 z-10.322
    g01 x-8.227 y4.750 z-10.333
    g01 x-8.143 y4.893 z-10.344
    g01 x-8.056 y5.034 z-10.356
    g01 x-7.967 y5.174 z-10.367
    g01 x-7.876 y5.312 z-10.378
    g01 x-7.782 y5.449 z-10.389
    g01 x-7.686 y5.584 z-10.400
    g01 x-7.587 y5.717 z-10.411
    g01 x-7.486 y5.849 z-10.422
    g01 x-7.383 y5.979 z-10.433
    g01 x-7.277 y6.106 z-10.444
    g01 x-7.170 y6.233 z-10.456
    g01 x-7.060 y6.357 z-10.467
    g01 x-6.948 y6.479 z-10.478
    g01 x-6.834 y6.599 z-10.489
    g01 x-6.718 y6.718 z-10.500
    g01 x-6.599 y6.834 z-10.511
    g01 x-6.479 y6.948 z-10.522
    g01 x-6.357 y7.060 z-10.533
    g01 x-6.233 y7.170 z-10.544
    g01 x-6.106 y7.277 z-10.556
    g01 x-5.979 y7.383 z-10.567
    g01 x-5.849 y7.486 z-10.578
    g01 x-5.717 y7.587 z-10.589
    g01 x-5.584 y7.686 z-10.600
    g01 x-5.449 y7.782 z-10.611
    g01 x-5.312 y7.876 z-10.622
    g01 x-5.174 y7.967 z-10.633
    g01 x-5.034 y8.056 z-10.644
    g01 x-4.893 y8.143 z-10.656
    g01 x-4.750 y8.227 z-10.667
    g01 x-4.606 y8.309 z-10.678
    g01 x-4.460 y8.388 z-10.689
    g01 x-4.313 y8.465 z-10.700
    g01 x-4.165 y8.539 z-10.711
    g01 x-4.015 y8.610 z-10.722
    g01 x-3.864 y8.679 z-10.733
    g01 x-3.712 y8.745 z-10.744
    g01 x-3.559 y8.808 z-10.756
    g01 x-3.404 y8.869 z-10.767
    g01 x-3.249 y8.927 z-10.778
    g01 x-3.093 y8.982 z-10.789
    g01 x-2.936 y9.035 z-10.800
    g01 x-2.778 y9.085 z-10.811
    g01 x-2.619 y9.132 z-10.822
    g01 x-2.459 y9.176 z-10.833
    g01 x-2.298 y9.218 z-10.844
    g01 x-2.137 y9.257 z-10.856
    g01 x-1.975 y9.292 z-10.867
    g01 x-1.813 y9.325 z-10.878
    g01 x-1.650 y9.356 z-10.889
    g01 x-1.486 y9.383 z-10.900
    g01 x-1.322 y9.408 z-10.911
    g01 x-1.158 y9.429 z-10.922
    g01 x-0.993 y9.448 z-10.933
    g01 x-0.828 y9.464 z-10.944
    g01 x-0.663 y9.477 z-10.956
    g01 x-0.497 y9.487 z-10.967
    g01 x-0.332 y9.494 z-10.978
    g01 x-0.166 y9.499 z-10.989
    g01 x-0.000 y9.500 z-11.000
    g01 x0.166 y9.499 z-11.011
    g01 x0.332 y9.494 z-11.022
    g01 x0.497 y9.487 z-11.033
    g01 x0.663 y9.477 z-11.044
    g01 x0.828 y9.464 z-11.056
    g01 x0.993 y9.448 z-11.067
    g01 x1.158 y9.429 z-11.078
    g01 x1.322 y9.408 z-11.089
    g01 x1.486 y9.383 z-11.100
    g01 x1.650 y9.356 z-11.111
    g01 x1.813 y9.325 z-11.122
    g01 x1.975 y9.292 z-11.133
    g01 x2.137 y9.257 z-11.144
    g01 x2.298 y9.218 z-11.156
    g01 x2.459 y9.176 z-11.167
    g01 x2.619 y9.132 z-11.178
    g01 x2.778 y9.085 z-11.189
    g01 x2.936 y9.035 z-11.200
    g01 x3.093 y8.982 z-11.211
    g01 x3.249 y8.927 z-11.222
    g01 x3.404 y8.869 z-11.233
    g01 x3.559 y8.808 z-11.244
    g01 x3.712 y8.745 z-11.256
    g01 x3.864 y8.679 z-11.267
    g01 x4.015 y8.610 z-11.278
    g01 x4.165 y8.539 z-11.289
    g01 x4.313 y8.465 z-11.300
    g01 x4.460 y8.388 z-11.311
    g01 x4.606 y8.309 z-11.322
    g01 x4.750 y8.227 z-11.333
    g01 x4.893 y8.143 z-11.344
    g01 x5.034 y8.056 z-11.356
    g01 x5.174 y7.967 z-11.367
    g01 x5.312 y7.876 z-11.378
    g01 x5.449 y7.782 z-11.389
    g01 x5.584 y7.686 z-11.400
    g01 x5.717 y7.587 z-11.411
    g01 x5.849 y7.486 z-11.422
    g01 x5.979 y7.383 z-11.433
    g01 x6.106 y7.277 z-11.444
    g01 x6.233 y7.170 z-11.456
    g01 x6.357 y7.060 z-11.467
    g01 x6.479 y6.948 z-11.478
    g01 x6.599 y6.834 z-11.489
    g01 x6.718 y6.718 z-11.500
    g01 x6.834 y6.599 z-11.511
    g01 x6.948 y6.479 z-11.522
    g01 x7.060 y6.357 z-11.533
    g01 x7.170 y6.233 z-11.544
    g01 x7.277 y6.106 z-11.556
    g01 x7.383 y5.979 z-11.567
    g01 x7.486 y5.849 z-11.578
    g01 x7.587 y5.717 z-11.589
    g01 x7.686 y5.584 z-11.600
    g01 x7.782 y5.449 z-11.611
    g01 x7.876 y5.312 z-11.622
    g01 x7.967 y5.174 z-11.633
    g01 x8.056 y5.034 z-11.644
    g01 x8.143 y4.893 z-11.656
    g01 x8.227 y4.750 z-11.667
    g01 x8.309 y4.606 z-11.678
    g01 x8.388 y4.460 z-11.689
    g01 x8.465 y4.313 z-11.700
    g01 x8.539 y4.165 z-11.711
    g01 x8.610 y4.015 z-11.722
    g01 x8.679 y3.864 z-11.733
    g01 x8.745 y3.712 z-11.744
    g01 x8.808 y3.559 z-11.756
    g01 x8.869 y3.404 z-11.767
    g01 x8.927 y3.249 z-11.778
    g01 x8.982 y3.093 z-11.789
    g01 x9.035 y2.936 z-11.800
    g01 x9.085 y2.778 z-11.811
    g01 x9.132 y2.619 z-11.822
    g01 x9.176 y2.459 z-11.833
    g01 x9.218 y2.298 z-11.844
    g01 x9.257 y2.137 z-11.856
    g01 x9.292 y1.975 z-11.867
    g01 x9.325 y1.813 z-11.878
    g01 x9.356 y1.650 z-11.889
    g01 x9.383 y1.486 z-11.900
    g01 x9.408 y1.322 z-11.911
    g01 x9.429 y1.158 z-11.922
    g01 x9.448 y0.993 z-11.933
    g01 x9.464 y0.828 z-11.944
    g01 x9.477 y0.663 z-11.956
    g01 x9.487 y0.497 z-11.967
    g01 x9.494 y0.332 z-11.978
    g01 x9.499 y0.166 z-11.989
    g01 x9.500 y0.000 z-12.000
    ;step-over pass: 1 - pitch pass N: 4
    g01 x9.499 y-0.166 z-12.011
    g01 x9.494 y-0.332 z-12.022
    g01 x9.487 y-0.497 z-12.033
    g01 x9.477 y-0.663 z-12.044
    g01 x9.464 y-0.828 z-12.056
    g01 x9.448 y-0.993 z-12.067
    g01 x9.429 y-1.158 z-12.078
    g01 x9.408 y-1.322 z-12.089
    g01 x9.383 y-1.486 z-12.100
    g01 x9.356 y-1.650 z-12.111
    g01 x9.325 y-1.813 z-12.122
    g01 x9.292 y-1.975 z-12.133
    g01 x9.257 y-2.137 z-12.144
    g01 x9.218 y-2.298 z-12.156
    g01 x9.176 y-2.459 z-12.167
    g01 x9.132 y-2.619 z-12.178
    g01 x9.085 y-2.778 z-12.189
    g01 x9.035 y-2.936 z-12.200
    g01 x8.982 y-3.093 z-12.211
    g01 x8.927 y-3.249 z-12.222
    g01 x8.869 y-3.404 z-12.233
    g01 x8.808 y-3.559 z-12.244
    g01 x8.745 y-3.712 z-12.256
    g01 x8.679 y-3.864 z-12.267
    g01 x8.610 y-4.015 z-12.278
    g01 x8.539 y-4.165 z-12.289
    g01 x8.465 y-4.313 z-12.300
    g01 x8.388 y-4.460 z-12.311
    g01 x8.309 y-4.606 z-12.322
    g01 x8.227 y-4.750 z-12.333
    g01 x8.143 y-4.893 z-12.344
    g01 x8.056 y-5.034 z-12.356
    g01 x7.967 y-5.174 z-12.367
    g01 x7.876 y-5.312 z-12.378
    g01 x7.782 y-5.449 z-12.389
    g01 x7.686 y-5.584 z-12.400
    g01 x7.587 y-5.717 z-12.411
    g01 x7.486 y-5.849 z-12.422
    g01 x7.383 y-5.979 z-12.433
    g01 x7.277 y-6.106 z-12.444
    g01 x7.170 y-6.233 z-12.456
    g01 x7.060 y-6.357 z-12.467
    g01 x6.948 y-6.479 z-12.478
    g01 x6.834 y-6.599 z-12.489
    g01 x6.718 y-6.718 z-12.500
    g01 x6.599 y-6.834 z-12.511
    g01 x6.479 y-6.948 z-12.522
    g01 x6.357 y-7.060 z-12.533
    g01 x6.233 y-7.170 z-12.544
    g01 x6.106 y-7.277 z-12.556
    g01 x5.979 y-7.383 z-12.567
    g01 x5.849 y-7.486 z-12.578
    g01 x5.717 y-7.587 z-12.589
    g01 x5.584 y-7.686 z-12.600
    g01 x5.449 y-7.782 z-12.611
    g01 x5.312 y-7.876 z-12.622
    g01 x5.174 y-7.967 z-12.633
    g01 x5.034 y-8.056 z-12.644
    g01 x4.893 y-8.143 z-12.656
    g01 x4.750 y-8.227 z-12.667
    g01 x4.606 y-8.309 z-12.678
    g01 x4.460 y-8.388 z-12.689
    g01 x4.313 y-8.465 z-12.700
    g01 x4.165 y-8.539 z-12.711
    g01 x4.015 y-8.610 z-12.722
    g01 x3.864 y-8.679 z-12.733
    g01 x3.712 y-8.745 z-12.744
    g01 x3.559 y-8.808 z-12.756
    g01 x3.404 y-8.869 z-12.767
    g01 x3.249 y-8.927 z-12.778
    g01 x3.093 y-8.982 z-12.789
    g01 x2.936 y-9.035 z-12.800
    g01 x2.778 y-9.085 z-12.811
    g01 x2.619 y-9.132 z-12.822
    g01 x2.459 y-9.176 z-12.833
    g01 x2.298 y-9.218 z-12.844
    g01 x2.137 y-9.257 z-12.856
    g01 x1.975 y-9.292 z-12.867
    g01 x1.813 y-9.325 z-12.878
    g01 x1.650 y-9.356 z-12.889
    g01 x1.486 y-9.383 z-12.900
    g01 x1.322 y-9.408 z-12.911
    g01 x1.158 y-9.429 z-12.922
    g01 x0.993 y-9.448 z-12.933
    g01 x0.828 y-9.464 z-12.944
    g01 x0.663 y-9.477 z-12.956
    g01 x0.497 y-9.487 z-12.967
    g01 x0.332 y-9.494 z-12.978
    g01 x0.166 y-9.499 z-12.989
    g01 x0.000 y-9.500 z-13.000
    g01 x-0.166 y-9.499 z-13.011
    g01 x-0.332 y-9.494 z-13.022
    g01 x-0.497 y-9.487 z-13.033
    g01 x-0.663 y-9.477 z-13.044
    g01 x-0.828 y-9.464 z-13.056
    g01 x-0.993 y-9.448 z-13.067
    g01 x-1.158 y-9.429 z-13.078
    g01 x-1.322 y-9.408 z-13.089
    g01 x-1.486 y-9.383 z-13.100
    g01 x-1.650 y-9.356 z-13.111
    g01 x-1.813 y-9.325 z-13.122
    g01 x-1.975 y-9.292 z-13.133
    g01 x-2.137 y-9.257 z-13.144
    g01 x-2.298 y-9.218 z-13.156
    g01 x-2.459 y-9.176 z-13.167
    g01 x-2.619 y-9.132 z-13.178
    g01 x-2.778 y-9.085 z-13.189
    g01 x-2.936 y-9.035 z-13.200
    g01 x-3.093 y-8.982 z-13.211
    g01 x-3.249 y-8.927 z-13.222
    g01 x-3.404 y-8.869 z-13.233
    g01 x-3.559 y-8.808 z-13.244
    g01 x-3.712 y-8.745 z-13.256
    g01 x-3.864 y-8.679 z-13.267
    g01 x-4.015 y-8.610 z-13.278
    g01 x-4.165 y-8.539 z-13.289
    g01 x-4.313 y-8.465 z-13.300
    g01 x-4.460 y-8.388 z-13.311
    g01 x-4.606 y-8.309 z-13.322
    g01 x-4.750 y-8.227 z-13.333
    g01 x-4.893 y-8.143 z-13.344
    g01 x-5.034 y-8.056 z-13.356
    g01 x-5.174 y-7.967 z-13.367
    g01 x-5.312 y-7.876 z-13.378
    g01 x-5.449 y-7.782 z-13.389
    g01 x-5.584 y-7.686 z-13.400
    g01 x-5.717 y-7.587 z-13.411
    g01 x-5.849 y-7.486 z-13.422
    g01 x-5.979 y-7.383 z-13.433
    g01 x-6.106 y-7.277 z-13.444
    g01 x-6.233 y-7.170 z-13.456
    g01 x-6.357 y-7.060 z-13.467
    g01 x-6.479 y-6.948 z-13.478
    g01 x-6.599 y-6.834 z-13.489
    g01 x-6.718 y-6.718 z-13.500
    g01 x-6.834 y-6.599 z-13.511
    g01 x-6.948 y-6.479 z-13.522
    g01 x-7.060 y-6.357 z-13.533
    g01 x-7.170 y-6.233 z-13.544
    g01 x-7.277 y-6.106 z-13.556
    g01 x-7.383 y-5.979 z-13.567
    g01 x-7.486 y-5.849 z-13.578
    g01 x-7.587 y-5.717 z-13.589
    g01 x-7.686 y-5.584 z-13.600
    g01 x-7.782 y-5.449 z-13.611
    g01 x-7.876 y-5.312 z-13.622
    g01 x-7.967 y-5.174 z-13.633
    g01 x-8.056 y-5.034 z-13.644
    g01 x-8.143 y-4.893 z-13.656
    g01 x-8.227 y-4.750 z-13.667
    g01 x-8.309 y-4.606 z-13.678
    g01 x-8.388 y-4.460 z-13.689
    g01 x-8.465 y-4.313 z-13.700
    g01 x-8.539 y-4.165 z-13.711
    g01 x-8.610 y-4.015 z-13.722
    g01 x-8.679 y-3.864 z-13.733
    g01 x-8.745 y-3.712 z-13.744
    g01 x-8.808 y-3.559 z-13.756
    g01 x-8.869 y-3.404 z-13.767
    g01 x-8.927 y-3.249 z-13.778
    g01 x-8.982 y-3.093 z-13.789
    g01 x-9.035 y-2.936 z-13.800
    g01 x-9.085 y-2.778 z-13.811
    g01 x-9.132 y-2.619 z-13.822
    g01 x-9.176 y-2.459 z-13.833
    g01 x-9.218 y-2.298 z-13.844
    g01 x-9.257 y-2.137 z-13.856
    g01 x-9.292 y-1.975 z-13.867
    g01 x-9.325 y-1.813 z-13.878
    g01 x-9.356 y-1.650 z-13.889
    g01 x-9.383 y-1.486 z-13.900
    g01 x-9.408 y-1.322 z-13.911
    g01 x-9.429 y-1.158 z-13.922
    g01 x-9.448 y-0.993 z-13.933
    g01 x-9.464 y-0.828 z-13.944
    g01 x-9.477 y-0.663 z-13.956
    g01 x-9.487 y-0.497 z-13.967
    g01 x-9.494 y-0.332 z-13.978
    g01 x-9.499 y-0.166 z-13.989
    g01 x-9.500 y-0.000 z-14.000
    g01 x-9.499 y0.166 z-14.011
    g01 x-9.494 y0.332 z-14.022
    g01 x-9.487 y0.497 z-14.033
    g01 x-9.477 y0.663 z-14.044
    g01 x-9.464 y0.828 z-14.056
    g01 x-9.448 y0.993 z-14.067
    g01 x-9.429 y1.158 z-14.078
    g01 x-9.408 y1.322 z-14.089
    g01 x-9.383 y1.486 z-14.100
    g01 x-9.356 y1.650 z-14.111
    g01 x-9.325 y1.813 z-14.122
    g01 x-9.292 y1.975 z-14.133
    g01 x-9.257 y2.137 z-14.144
    g01 x-9.218 y2.298 z-14.156
    g01 x-9.176 y2.459 z-14.167
    g01 x-9.132 y2.619 z-14.178
    g01 x-9.085 y2.778 z-14.189
    g01 x-9.035 y2.936 z-14.200
    g01 x-8.982 y3.093 z-14.211
    g01 x-8.927 y3.249 z-14.222
    g01 x-8.869 y3.404 z-14.233
    g01 x-8.808 y3.559 z-14.244
    g01 x-8.745 y3.712 z-14.256
    g01 x-8.679 y3.864 z-14.267
    g01 x-8.610 y4.015 z-14.278
    g01 x-8.539 y4.165 z-14.289
    g01 x-8.465 y4.313 z-14.300
    g01 x-8.388 y4.460 z-14.311
    g01 x-8.309 y4.606 z-14.322
    g01 x-8.227 y4.750 z-14.333
    g01 x-8.143 y4.893 z-14.344
    g01 x-8.056 y5.034 z-14.356
    g01 x-7.967 y5.174 z-14.367
    g01 x-7.876 y5.312 z-14.378
    g01 x-7.782 y5.449 z-14.389
    g01 x-7.686 y5.584 z-14.400
    g01 x-7.587 y5.717 z-14.411
    g01 x-7.486 y5.849 z-14.422
    g01 x-7.383 y5.979 z-14.433
    g01 x-7.277 y6.106 z-14.444
    g01 x-7.170 y6.233 z-14.456
    g01 x-7.060 y6.357 z-14.467
    g01 x-6.948 y6.479 z-14.478
    g01 x-6.834 y6.599 z-14.489
    g01 x-6.718 y6.718 z-14.500
    g01 x-6.599 y6.834 z-14.511
    g01 x-6.479 y6.948 z-14.522
    g01 x-6.357 y7.060 z-14.533
    g01 x-6.233 y7.170 z-14.544
    g01 x-6.106 y7.277 z-14.556
    g01 x-5.979 y7.383 z-14.567
    g01 x-5.849 y7.486 z-14.578
    g01 x-5.717 y7.587 z-14.589
    g01 x-5.584 y7.686 z-14.600
    g01 x-5.449 y7.782 z-14.611
    g01 x-5.312 y7.876 z-14.622
    g01 x-5.174 y7.967 z-14.633
    g01 x-5.034 y8.056 z-14.644
    g01 x-4.893 y8.143 z-14.656
    g01 x-4.750 y8.227 z-14.667
    g01 x-4.606 y8.309 z-14.678
    g01 x-4.460 y8.388 z-14.689
    g01 x-4.313 y8.465 z-14.700
    g01 x-4.165 y8.539 z-14.711
    g01 x-4.015 y8.610 z-14.722
    g01 x-3.864 y8.679 z-14.733
    g01 x-3.712 y8.745 z-14.744
    g01 x-3.559 y8.808 z-14.756
    g01 x-3.404 y8.869 z-14.767
    g01 x-3.249 y8.927 z-14.778
    g01 x-3.093 y8.982 z-14.789
    g01 x-2.936 y9.035 z-14.800
    g01 x-2.778 y9.085 z-14.811
    g01 x-2.619 y9.132 z-14.822
    g01 x-2.459 y9.176 z-14.833
    g01 x-2.298 y9.218 z-14.844
    g01 x-2.137 y9.257 z-14.856
    g01 x-1.975 y9.292 z-14.867
    g01 x-1.813 y9.325 z-14.878
    g01 x-1.650 y9.356 z-14.889
    g01 x-1.486 y9.383 z-14.900
    g01 x-1.322 y9.408 z-14.911
    g01 x-1.158 y9.429 z-14.922
    g01 x-0.993 y9.448 z-14.933
    g01 x-0.828 y9.464 z-14.944
    g01 x-0.663 y9.477 z-14.956
    g01 x-0.497 y9.487 z-14.967
    g01 x-0.332 y9.494 z-14.978
    g01 x-0.166 y9.499 z-14.989
    g01 x-0.000 y9.500 z-15.000
    g0 x0 y0
    g0 z5
    g00 x10.000 y-0.000
    ;step-over pass: 2 - pitch pass N: 1
    ;diameter: 30.000 [mm]
    g01 x9.998 y-0.175 z-0.011
    g01 x9.994 y-0.349 z-0.022
    g01 x9.986 y-0.523 z-0.033
    g01 x9.976 y-0.698 z-0.044
    g01 x9.962 y-0.872 z-0.056
    g01 x9.945 y-1.045 z-0.067
    g01 x9.925 y-1.219 z-0.078
    g01 x9.903 y-1.392 z-0.089
    g01 x9.877 y-1.564 z-0.100
    g01 x9.848 y-1.736 z-0.111
    g01 x9.816 y-1.908 z-0.122
    g01 x9.781 y-2.079 z-0.133
    g01 x9.744 y-2.250 z-0.144
    g01 x9.703 y-2.419 z-0.156
    g01 x9.659 y-2.588 z-0.167
    g01 x9.613 y-2.756 z-0.178
    g01 x9.563 y-2.924 z-0.189
    g01 x9.511 y-3.090 z-0.200
    g01 x9.455 y-3.256 z-0.211
    g01 x9.397 y-3.420 z-0.222
    g01 x9.336 y-3.584 z-0.233
    g01 x9.272 y-3.746 z-0.244
    g01 x9.205 y-3.907 z-0.256
    g01 x9.135 y-4.067 z-0.267
    g01 x9.063 y-4.226 z-0.278
    g01 x8.988 y-4.384 z-0.289
    g01 x8.910 y-4.540 z-0.300
    g01 x8.829 y-4.695 z-0.311
    g01 x8.746 y-4.848 z-0.322
    g01 x8.660 y-5.000 z-0.333
    g01 x8.572 y-5.150 z-0.344
    g01 x8.480 y-5.299 z-0.356
    g01 x8.387 y-5.446 z-0.367
    g01 x8.290 y-5.592 z-0.378
    g01 x8.192 y-5.736 z-0.389
    g01 x8.090 y-5.878 z-0.400
    g01 x7.986 y-6.018 z-0.411
    g01 x7.880 y-6.157 z-0.422
    g01 x7.771 y-6.293 z-0.433
    g01 x7.660 y-6.428 z-0.444
    g01 x7.547 y-6.561 z-0.456
    g01 x7.431 y-6.691 z-0.467
    g01 x7.314 y-6.820 z-0.478
    g01 x7.193 y-6.947 z-0.489
    g01 x7.071 y-7.071 z-0.500
    g01 x6.947 y-7.193 z-0.511
    g01 x6.820 y-7.314 z-0.522
    g01 x6.691 y-7.431 z-0.533
    g01 x6.561 y-7.547 z-0.544
    g01 x6.428 y-7.660 z-0.556
    g01 x6.293 y-7.771 z-0.567
    g01 x6.157 y-7.880 z-0.578
    g01 x6.018 y-7.986 z-0.589
    g01 x5.878 y-8.090 z-0.600
    g01 x5.736 y-8.192 z-0.611
    g01 x5.592 y-8.290 z-0.622
    g01 x5.446 y-8.387 z-0.633
    g01 x5.299 y-8.480 z-0.644
    g01 x5.150 y-8.572 z-0.656
    g01 x5.000 y-8.660 z-0.667
    g01 x4.848 y-8.746 z-0.678
    g01 x4.695 y-8.829 z-0.689
    g01 x4.540 y-8.910 z-0.700
    g01 x4.384 y-8.988 z-0.711
    g01 x4.226 y-9.063 z-0.722
    g01 x4.067 y-9.135 z-0.733
    g01 x3.907 y-9.205 z-0.744
    g01 x3.746 y-9.272 z-0.756
    g01 x3.584 y-9.336 z-0.767
    g01 x3.420 y-9.397 z-0.778
    g01 x3.256 y-9.455 z-0.789
    g01 x3.090 y-9.511 z-0.800
    g01 x2.924 y-9.563 z-0.811
    g01 x2.756 y-9.613 z-0.822
    g01 x2.588 y-9.659 z-0.833
    g01 x2.419 y-9.703 z-0.844
    g01 x2.250 y-9.744 z-0.856
    g01 x2.079 y-9.781 z-0.867
    g01 x1.908 y-9.816 z-0.878
    g01 x1.736 y-9.848 z-0.889
    g01 x1.564 y-9.877 z-0.900
    g01 x1.392 y-9.903 z-0.911
    g01 x1.219 y-9.925 z-0.922
    g01 x1.045 y-9.945 z-0.933
    g01 x0.872 y-9.962 z-0.944
    g01 x0.698 y-9.976 z-0.956
    g01 x0.523 y-9.986 z-0.967
    g01 x0.349 y-9.994 z-0.978
    g01 x0.175 y-9.998 z-0.989
    g01 x0.000 y-10.000 z-1.000
    g01 x-0.175 y-9.998 z-1.011
    g01 x-0.349 y-9.994 z-1.022
    g01 x-0.523 y-9.986 z-1.033
    g01 x-0.698 y-9.976 z-1.044
    g01 x-0.872 y-9.962 z-1.056
    g01 x-1.045 y-9.945 z-1.067
    g01 x-1.219 y-9.925 z-1.078
    g01 x-1.392 y-9.903 z-1.089
    g01 x-1.564 y-9.877 z-1.100
    g01 x-1.736 y-9.848 z-1.111
    g01 x-1.908 y-9.816 z-1.122
    g01 x-2.079 y-9.781 z-1.133
    g01 x-2.250 y-9.744 z-1.144
    g01 x-2.419 y-9.703 z-1.156
    g01 x-2.588 y-9.659 z-1.167
    g01 x-2.756 y-9.613 z-1.178
    g01 x-2.924 y-9.563 z-1.189
    g01 x-3.090 y-9.511 z-1.200
    g01 x-3.256 y-9.455 z-1.211
    g01 x-3.420 y-9.397 z-1.222
    g01 x-3.584 y-9.336 z-1.233
    g01 x-3.746 y-9.272 z-1.244
    g01 x-3.907 y-9.205 z-1.256
    g01 x-4.067 y-9.135 z-1.267
    g01 x-4.226 y-9.063 z-1.278
    g01 x-4.384 y-8.988 z-1.289
    g01 x-4.540 y-8.910 z-1.300
    g01 x-4.695 y-8.829 z-1.311
    g01 x-4.848 y-8.746 z-1.322
    g01 x-5.000 y-8.660 z-1.333
    g01 x-5.150 y-8.572 z-1.344
    g01 x-5.299 y-8.480 z-1.356
    g01 x-5.446 y-8.387 z-1.367
    g01 x-5.592 y-8.290 z-1.378
    g01 x-5.736 y-8.192 z-1.389
    g01 x-5.878 y-8.090 z-1.400
    g01 x-6.018 y-7.986 z-1.411
    g01 x-6.157 y-7.880 z-1.422
    g01 x-6.293 y-7.771 z-1.433
    g01 x-6.428 y-7.660 z-1.444
    g01 x-6.561 y-7.547 z-1.456
    g01 x-6.691 y-7.431 z-1.467
    g01 x-6.820 y-7.314 z-1.478
    g01 x-6.947 y-7.193 z-1.489
    g01 x-7.071 y-7.071 z-1.500
    g01 x-7.193 y-6.947 z-1.511
    g01 x-7.314 y-6.820 z-1.522
    g01 x-7.431 y-6.691 z-1.533
    g01 x-7.547 y-6.561 z-1.544
    g01 x-7.660 y-6.428 z-1.556
    g01 x-7.771 y-6.293 z-1.567
    g01 x-7.880 y-6.157 z-1.578
    g01 x-7.986 y-6.018 z-1.589
    g01 x-8.090 y-5.878 z-1.600
    g01 x-8.192 y-5.736 z-1.611
    g01 x-8.290 y-5.592 z-1.622
    g01 x-8.387 y-5.446 z-1.633
    g01 x-8.480 y-5.299 z-1.644
    g01 x-8.572 y-5.150 z-1.656
    g01 x-8.660 y-5.000 z-1.667
    g01 x-8.746 y-4.848 z-1.678
    g01 x-8.829 y-4.695 z-1.689
    g01 x-8.910 y-4.540 z-1.700
    g01 x-8.988 y-4.384 z-1.711
    g01 x-9.063 y-4.226 z-1.722
    g01 x-9.135 y-4.067 z-1.733
    g01 x-9.205 y-3.907 z-1.744
    g01 x-9.272 y-3.746 z-1.756
    g01 x-9.336 y-3.584 z-1.767
    g01 x-9.397 y-3.420 z-1.778
    g01 x-9.455 y-3.256 z-1.789
    g01 x-9.511 y-3.090 z-1.800
    g01 x-9.563 y-2.924 z-1.811
    g01 x-9.613 y-2.756 z-1.822
    g01 x-9.659 y-2.588 z-1.833
    g01 x-9.703 y-2.419 z-1.844
    g01 x-9.744 y-2.250 z-1.856
    g01 x-9.781 y-2.079 z-1.867
    g01 x-9.816 y-1.908 z-1.878
    g01 x-9.848 y-1.736 z-1.889
    g01 x-9.877 y-1.564 z-1.900
    g01 x-9.903 y-1.392 z-1.911
    g01 x-9.925 y-1.219 z-1.922
    g01 x-9.945 y-1.045 z-1.933
    g01 x-9.962 y-0.872 z-1.944
    g01 x-9.976 y-0.698 z-1.956
    g01 x-9.986 y-0.523 z-1.967
    g01 x-9.994 y-0.349 z-1.978
    g01 x-9.998 y-0.175 z-1.989
    g01 x-10.000 y-0.000 z-2.000
    g01 x-9.998 y0.175 z-2.011
    g01 x-9.994 y0.349 z-2.022
    g01 x-9.986 y0.523 z-2.033
    g01 x-9.976 y0.698 z-2.044
    g01 x-9.962 y0.872 z-2.056
    g01 x-9.945 y1.045 z-2.067
    g01 x-9.925 y1.219 z-2.078
    g01 x-9.903 y1.392 z-2.089
    g01 x-9.877 y1.564 z-2.100
    g01 x-9.848 y1.736 z-2.111
    g01 x-9.816 y1.908 z-2.122
    g01 x-9.781 y2.079 z-2.133
    g01 x-9.744 y2.250 z-2.144
    g01 x-9.703 y2.419 z-2.156
    g01 x-9.659 y2.588 z-2.167
    g01 x-9.613 y2.756 z-2.178
    g01 x-9.563 y2.924 z-2.189
    g01 x-9.511 y3.090 z-2.200
    g01 x-9.455 y3.256 z-2.211
    g01 x-9.397 y3.420 z-2.222
    g01 x-9.336 y3.584 z-2.233
    g01 x-9.272 y3.746 z-2.244
    g01 x-9.205 y3.907 z-2.256
    g01 x-9.135 y4.067 z-2.267
    g01 x-9.063 y4.226 z-2.278
    g01 x-8.988 y4.384 z-2.289
    g01 x-8.910 y4.540 z-2.300
    g01 x-8.829 y4.695 z-2.311
    g01 x-8.746 y4.848 z-2.322
    g01 x-8.660 y5.000 z-2.333
    g01 x-8.572 y5.150 z-2.344
    g01 x-8.480 y5.299 z-2.356
    g01 x-8.387 y5.446 z-2.367
    g01 x-8.290 y5.592 z-2.378
    g01 x-8.192 y5.736 z-2.389
    g01 x-8.090 y5.878 z-2.400
    g01 x-7.986 y6.018 z-2.411
    g01 x-7.880 y6.157 z-2.422
    g01 x-7.771 y6.293 z-2.433
    g01 x-7.660 y6.428 z-2.444
    g01 x-7.547 y6.561 z-2.456
    g01 x-7.431 y6.691 z-2.467
    g01 x-7.314 y6.820 z-2.478
    g01 x-7.193 y6.947 z-2.489
    g01 x-7.071 y7.071 z-2.500
    g01 x-6.947 y7.193 z-2.511
    g01 x-6.820 y7.314 z-2.522
    g01 x-6.691 y7.431 z-2.533
    g01 x-6.561 y7.547 z-2.544
    g01 x-6.428 y7.660 z-2.556
    g01 x-6.293 y7.771 z-2.567
    g01 x-6.157 y7.880 z-2.578
    g01 x-6.018 y7.986 z-2.589
    g01 x-5.878 y8.090 z-2.600
    g01 x-5.736 y8.192 z-2.611
    g01 x-5.592 y8.290 z-2.622
    g01 x-5.446 y8.387 z-2.633
    g01 x-5.299 y8.480 z-2.644
    g01 x-5.150 y8.572 z-2.656
    g01 x-5.000 y8.660 z-2.667
    g01 x-4.848 y8.746 z-2.678
    g01 x-4.695 y8.829 z-2.689
    g01 x-4.540 y8.910 z-2.700
    g01 x-4.384 y8.988 z-2.711
    g01 x-4.226 y9.063 z-2.722
    g01 x-4.067 y9.135 z-2.733
    g01 x-3.907 y9.205 z-2.744
    g01 x-3.746 y9.272 z-2.756
    g01 x-3.584 y9.336 z-2.767
    g01 x-3.420 y9.397 z-2.778
    g01 x-3.256 y9.455 z-2.789
    g01 x-3.090 y9.511 z-2.800
    g01 x-2.924 y9.563 z-2.811
    g01 x-2.756 y9.613 z-2.822
    g01 x-2.588 y9.659 z-2.833
    g01 x-2.419 y9.703 z-2.844
    g01 x-2.250 y9.744 z-2.856
    g01 x-2.079 y9.781 z-2.867
    g01 x-1.908 y9.816 z-2.878
    g01 x-1.736 y9.848 z-2.889
    g01 x-1.564 y9.877 z-2.900
    g01 x-1.392 y9.903 z-2.911
    g01 x-1.219 y9.925 z-2.922
    g01 x-1.045 y9.945 z-2.933
    g01 x-0.872 y9.962 z-2.944
    g01 x-0.698 y9.976 z-2.956
    g01 x-0.523 y9.986 z-2.967
    g01 x-0.349 y9.994 z-2.978
    g01 x-0.175 y9.998 z-2.989
    g01 x-0.000 y10.000 z-3.000
    g01 x0.175 y9.998 z-3.011
    g01 x0.349 y9.994 z-3.022
    g01 x0.523 y9.986 z-3.033
    g01 x0.698 y9.976 z-3.044
    g01 x0.872 y9.962 z-3.056
    g01 x1.045 y9.945 z-3.067
    g01 x1.219 y9.925 z-3.078
    g01 x1.392 y9.903 z-3.089
    g01 x1.564 y9.877 z-3.100
    g01 x1.736 y9.848 z-3.111
    g01 x1.908 y9.816 z-3.122
    g01 x2.079 y9.781 z-3.133
    g01 x2.250 y9.744 z-3.144
    g01 x2.419 y9.703 z-3.156
    g01 x2.588 y9.659 z-3.167
    g01 x2.756 y9.613 z-3.178
    g01 x2.924 y9.563 z-3.189
    g01 x3.090 y9.511 z-3.200
    g01 x3.256 y9.455 z-3.211
    g01 x3.420 y9.397 z-3.222
    g01 x3.584 y9.336 z-3.233
    g01 x3.746 y9.272 z-3.244
    g01 x3.907 y9.205 z-3.256
    g01 x4.067 y9.135 z-3.267
    g01 x4.226 y9.063 z-3.278
    g01 x4.384 y8.988 z-3.289
    g01 x4.540 y8.910 z-3.300
    g01 x4.695 y8.829 z-3.311
    g01 x4.848 y8.746 z-3.322
    g01 x5.000 y8.660 z-3.333
    g01 x5.150 y8.572 z-3.344
    g01 x5.299 y8.480 z-3.356
    g01 x5.446 y8.387 z-3.367
    g01 x5.592 y8.290 z-3.378
    g01 x5.736 y8.192 z-3.389
    g01 x5.878 y8.090 z-3.400
    g01 x6.018 y7.986 z-3.411
    g01 x6.157 y7.880 z-3.422
    g01 x6.293 y7.771 z-3.433
    g01 x6.428 y7.660 z-3.444
    g01 x6.561 y7.547 z-3.456
    g01 x6.691 y7.431 z-3.467
    g01 x6.820 y7.314 z-3.478
    g01 x6.947 y7.193 z-3.489
    g01 x7.071 y7.071 z-3.500
    g01 x7.193 y6.947 z-3.511
    g01 x7.314 y6.820 z-3.522
    g01 x7.431 y6.691 z-3.533
    g01 x7.547 y6.561 z-3.544
    g01 x7.660 y6.428 z-3.556
    g01 x7.771 y6.293 z-3.567
    g01 x7.880 y6.157 z-3.578
    g01 x7.986 y6.018 z-3.589
    g01 x8.090 y5.878 z-3.600
    g01 x8.192 y5.736 z-3.611
    g01 x8.290 y5.592 z-3.622
    g01 x8.387 y5.446 z-3.633
    g01 x8.480 y5.299 z-3.644
    g01 x8.572 y5.150 z-3.656
    g01 x8.660 y5.000 z-3.667
    g01 x8.746 y4.848 z-3.678
    g01 x8.829 y4.695 z-3.689
    g01 x8.910 y4.540 z-3.700
    g01 x8.988 y4.384 z-3.711
    g01 x9.063 y4.226 z-3.722
    g01 x9.135 y4.067 z-3.733
    g01 x9.205 y3.907 z-3.744
    g01 x9.272 y3.746 z-3.756
    g01 x9.336 y3.584 z-3.767
    g01 x9.397 y3.420 z-3.778
    g01 x9.455 y3.256 z-3.789
    g01 x9.511 y3.090 z-3.800
    g01 x9.563 y2.924 z-3.811
    g01 x9.613 y2.756 z-3.822
    g01 x9.659 y2.588 z-3.833
    g01 x9.703 y2.419 z-3.844
    g01 x9.744 y2.250 z-3.856
    g01 x9.781 y2.079 z-3.867
    g01 x9.816 y1.908 z-3.878
    g01 x9.848 y1.736 z-3.889
    g01 x9.877 y1.564 z-3.900
    g01 x9.903 y1.392 z-3.911
    g01 x9.925 y1.219 z-3.922
    g01 x9.945 y1.045 z-3.933
    g01 x9.962 y0.872 z-3.944
    g01 x9.976 y0.698 z-3.956
    g01 x9.986 y0.523 z-3.967
    g01 x9.994 y0.349 z-3.978
    g01 x9.998 y0.175 z-3.989
    g01 x10.000 y0.000 z-4.000
    ;step-over pass: 2 - pitch pass N: 2
    g01 x9.998 y-0.175 z-4.011
    g01 x9.994 y-0.349 z-4.022
    g01 x9.986 y-0.523 z-4.033
    g01 x9.976 y-0.698 z-4.044
    g01 x9.962 y-0.872 z-4.056
    g01 x9.945 y-1.045 z-4.067
    g01 x9.925 y-1.219 z-4.078
    g01 x9.903 y-1.392 z-4.089
    g01 x9.877 y-1.564 z-4.100
    g01 x9.848 y-1.736 z-4.111
    g01 x9.816 y-1.908 z-4.122
    g01 x9.781 y-2.079 z-4.133
    g01 x9.744 y-2.250 z-4.144
    g01 x9.703 y-2.419 z-4.156
    g01 x9.659 y-2.588 z-4.167
    g01 x9.613 y-2.756 z-4.178
    g01 x9.563 y-2.924 z-4.189
    g01 x9.511 y-3.090 z-4.200
    g01 x9.455 y-3.256 z-4.211
    g01 x9.397 y-3.420 z-4.222
    g01 x9.336 y-3.584 z-4.233
    g01 x9.272 y-3.746 z-4.244
    g01 x9.205 y-3.907 z-4.256
    g01 x9.135 y-4.067 z-4.267
    g01 x9.063 y-4.226 z-4.278
    g01 x8.988 y-4.384 z-4.289
    g01 x8.910 y-4.540 z-4.300
    g01 x8.829 y-4.695 z-4.311
    g01 x8.746 y-4.848 z-4.322
    g01 x8.660 y-5.000 z-4.333
    g01 x8.572 y-5.150 z-4.344
    g01 x8.480 y-5.299 z-4.356
    g01 x8.387 y-5.446 z-4.367
    g01 x8.290 y-5.592 z-4.378
    g01 x8.192 y-5.736 z-4.389
    g01 x8.090 y-5.878 z-4.400
    g01 x7.986 y-6.018 z-4.411
    g01 x7.880 y-6.157 z-4.422
    g01 x7.771 y-6.293 z-4.433
    g01 x7.660 y-6.428 z-4.444
    g01 x7.547 y-6.561 z-4.456
    g01 x7.431 y-6.691 z-4.467
    g01 x7.314 y-6.820 z-4.478
    g01 x7.193 y-6.947 z-4.489
    g01 x7.071 y-7.071 z-4.500
    g01 x6.947 y-7.193 z-4.511
    g01 x6.820 y-7.314 z-4.522
    g01 x6.691 y-7.431 z-4.533
    g01 x6.561 y-7.547 z-4.544
    g01 x6.428 y-7.660 z-4.556
    g01 x6.293 y-7.771 z-4.567
    g01 x6.157 y-7.880 z-4.578
    g01 x6.018 y-7.986 z-4.589
    g01 x5.878 y-8.090 z-4.600
    g01 x5.736 y-8.192 z-4.611
    g01 x5.592 y-8.290 z-4.622
    g01 x5.446 y-8.387 z-4.633
    g01 x5.299 y-8.480 z-4.644
    g01 x5.150 y-8.572 z-4.656
    g01 x5.000 y-8.660 z-4.667
    g01 x4.848 y-8.746 z-4.678
    g01 x4.695 y-8.829 z-4.689
    g01 x4.540 y-8.910 z-4.700
    g01 x4.384 y-8.988 z-4.711
    g01 x4.226 y-9.063 z-4.722
    g01 x4.067 y-9.135 z-4.733
    g01 x3.907 y-9.205 z-4.744
    g01 x3.746 y-9.272 z-4.756
    g01 x3.584 y-9.336 z-4.767
    g01 x3.420 y-9.397 z-4.778
    g01 x3.256 y-9.455 z-4.789
    g01 x3.090 y-9.511 z-4.800
    g01 x2.924 y-9.563 z-4.811
    g01 x2.756 y-9.613 z-4.822
    g01 x2.588 y-9.659 z-4.833
    g01 x2.419 y-9.703 z-4.844
    g01 x2.250 y-9.744 z-4.856
    g01 x2.079 y-9.781 z-4.867
    g01 x1.908 y-9.816 z-4.878
    g01 x1.736 y-9.848 z-4.889
    g01 x1.564 y-9.877 z-4.900
    g01 x1.392 y-9.903 z-4.911
    g01 x1.219 y-9.925 z-4.922
    g01 x1.045 y-9.945 z-4.933
    g01 x0.872 y-9.962 z-4.944
    g01 x0.698 y-9.976 z-4.956
    g01 x0.523 y-9.986 z-4.967
    g01 x0.349 y-9.994 z-4.978
    g01 x0.175 y-9.998 z-4.989
    g01 x0.000 y-10.000 z-5.000
    g01 x-0.175 y-9.998 z-5.011
    g01 x-0.349 y-9.994 z-5.022
    g01 x-0.523 y-9.986 z-5.033
    g01 x-0.698 y-9.976 z-5.044
    g01 x-0.872 y-9.962 z-5.056
    g01 x-1.045 y-9.945 z-5.067
    g01 x-1.219 y-9.925 z-5.078
    g01 x-1.392 y-9.903 z-5.089
    g01 x-1.564 y-9.877 z-5.100
    g01 x-1.736 y-9.848 z-5.111
    g01 x-1.908 y-9.816 z-5.122
    g01 x-2.079 y-9.781 z-5.133
    g01 x-2.250 y-9.744 z-5.144
    g01 x-2.419 y-9.703 z-5.156
    g01 x-2.588 y-9.659 z-5.167
    g01 x-2.756 y-9.613 z-5.178
    g01 x-2.924 y-9.563 z-5.189
    g01 x-3.090 y-9.511 z-5.200
    g01 x-3.256 y-9.455 z-5.211
    g01 x-3.420 y-9.397 z-5.222
    g01 x-3.584 y-9.336 z-5.233
    g01 x-3.746 y-9.272 z-5.244
    g01 x-3.907 y-9.205 z-5.256
    g01 x-4.067 y-9.135 z-5.267
    g01 x-4.226 y-9.063 z-5.278
    g01 x-4.384 y-8.988 z-5.289
    g01 x-4.540 y-8.910 z-5.300
    g01 x-4.695 y-8.829 z-5.311
    g01 x-4.848 y-8.746 z-5.322
    g01 x-5.000 y-8.660 z-5.333
    g01 x-5.150 y-8.572 z-5.344
    g01 x-5.299 y-8.480 z-5.356
    g01 x-5.446 y-8.387 z-5.367
    g01 x-5.592 y-8.290 z-5.378
    g01 x-5.736 y-8.192 z-5.389
    g01 x-5.878 y-8.090 z-5.400
    g01 x-6.018 y-7.986 z-5.411
    g01 x-6.157 y-7.880 z-5.422
    g01 x-6.293 y-7.771 z-5.433
    g01 x-6.428 y-7.660 z-5.444
    g01 x-6.561 y-7.547 z-5.456
    g01 x-6.691 y-7.431 z-5.467
    g01 x-6.820 y-7.314 z-5.478
    g01 x-6.947 y-7.193 z-5.489
    g01 x-7.071 y-7.071 z-5.500
    g01 x-7.193 y-6.947 z-5.511
    g01 x-7.314 y-6.820 z-5.522
    g01 x-7.431 y-6.691 z-5.533
    g01 x-7.547 y-6.561 z-5.544
    g01 x-7.660 y-6.428 z-5.556
    g01 x-7.771 y-6.293 z-5.567
    g01 x-7.880 y-6.157 z-5.578
    g01 x-7.986 y-6.018 z-5.589
    g01 x-8.090 y-5.878 z-5.600
    g01 x-8.192 y-5.736 z-5.611
    g01 x-8.290 y-5.592 z-5.622
    g01 x-8.387 y-5.446 z-5.633
    g01 x-8.480 y-5.299 z-5.644
    g01 x-8.572 y-5.150 z-5.656
    g01 x-8.660 y-5.000 z-5.667
    g01 x-8.746 y-4.848 z-5.678
    g01 x-8.829 y-4.695 z-5.689
    g01 x-8.910 y-4.540 z-5.700
    g01 x-8.988 y-4.384 z-5.711
    g01 x-9.063 y-4.226 z-5.722
    g01 x-9.135 y-4.067 z-5.733
    g01 x-9.205 y-3.907 z-5.744
    g01 x-9.272 y-3.746 z-5.756
    g01 x-9.336 y-3.584 z-5.767
    g01 x-9.397 y-3.420 z-5.778
    g01 x-9.455 y-3.256 z-5.789
    g01 x-9.511 y-3.090 z-5.800
    g01 x-9.563 y-2.924 z-5.811
    g01 x-9.613 y-2.756 z-5.822
    g01 x-9.659 y-2.588 z-5.833
    g01 x-9.703 y-2.419 z-5.844
    g01 x-9.744 y-2.250 z-5.856
    g01 x-9.781 y-2.079 z-5.867
    g01 x-9.816 y-1.908 z-5.878
    g01 x-9.848 y-1.736 z-5.889
    g01 x-9.877 y-1.564 z-5.900
    g01 x-9.903 y-1.392 z-5.911
    g01 x-9.925 y-1.219 z-5.922
    g01 x-9.945 y-1.045 z-5.933
    g01 x-9.962 y-0.872 z-5.944
    g01 x-9.976 y-0.698 z-5.956
    g01 x-9.986 y-0.523 z-5.967
    g01 x-9.994 y-0.349 z-5.978
    g01 x-9.998 y-0.175 z-5.989
    g01 x-10.000 y-0.000 z-6.000
    g01 x-9.998 y0.175 z-6.011
    g01 x-9.994 y0.349 z-6.022
    g01 x-9.986 y0.523 z-6.033
    g01 x-9.976 y0.698 z-6.044
    g01 x-9.962 y0.872 z-6.056
    g01 x-9.945 y1.045 z-6.067
    g01 x-9.925 y1.219 z-6.078
    g01 x-9.903 y1.392 z-6.089
    g01 x-9.877 y1.564 z-6.100
    g01 x-9.848 y1.736 z-6.111
    g01 x-9.816 y1.908 z-6.122
    g01 x-9.781 y2.079 z-6.133
    g01 x-9.744 y2.250 z-6.144
    g01 x-9.703 y2.419 z-6.156
    g01 x-9.659 y2.588 z-6.167
    g01 x-9.613 y2.756 z-6.178
    g01 x-9.563 y2.924 z-6.189
    g01 x-9.511 y3.090 z-6.200
    g01 x-9.455 y3.256 z-6.211
    g01 x-9.397 y3.420 z-6.222
    g01 x-9.336 y3.584 z-6.233
    g01 x-9.272 y3.746 z-6.244
    g01 x-9.205 y3.907 z-6.256
    g01 x-9.135 y4.067 z-6.267
    g01 x-9.063 y4.226 z-6.278
    g01 x-8.988 y4.384 z-6.289
    g01 x-8.910 y4.540 z-6.300
    g01 x-8.829 y4.695 z-6.311
    g01 x-8.746 y4.848 z-6.322
    g01 x-8.660 y5.000 z-6.333
    g01 x-8.572 y5.150 z-6.344
    g01 x-8.480 y5.299 z-6.356
    g01 x-8.387 y5.446 z-6.367
    g01 x-8.290 y5.592 z-6.378
    g01 x-8.192 y5.736 z-6.389
    g01 x-8.090 y5.878 z-6.400
    g01 x-7.986 y6.018 z-6.411
    g01 x-7.880 y6.157 z-6.422
    g01 x-7.771 y6.293 z-6.433
    g01 x-7.660 y6.428 z-6.444
    g01 x-7.547 y6.561 z-6.456
    g01 x-7.431 y6.691 z-6.467
    g01 x-7.314 y6.820 z-6.478
    g01 x-7.193 y6.947 z-6.489
    g01 x-7.071 y7.071 z-6.500
    g01 x-6.947 y7.193 z-6.511
    g01 x-6.820 y7.314 z-6.522
    g01 x-6.691 y7.431 z-6.533
    g01 x-6.561 y7.547 z-6.544
    g01 x-6.428 y7.660 z-6.556
    g01 x-6.293 y7.771 z-6.567
    g01 x-6.157 y7.880 z-6.578
    g01 x-6.018 y7.986 z-6.589
    g01 x-5.878 y8.090 z-6.600
    g01 x-5.736 y8.192 z-6.611
    g01 x-5.592 y8.290 z-6.622
    g01 x-5.446 y8.387 z-6.633
    g01 x-5.299 y8.480 z-6.644
    g01 x-5.150 y8.572 z-6.656
    g01 x-5.000 y8.660 z-6.667
    g01 x-4.848 y8.746 z-6.678
    g01 x-4.695 y8.829 z-6.689
    g01 x-4.540 y8.910 z-6.700
    g01 x-4.384 y8.988 z-6.711
    g01 x-4.226 y9.063 z-6.722
    g01 x-4.067 y9.135 z-6.733
    g01 x-3.907 y9.205 z-6.744
    g01 x-3.746 y9.272 z-6.756
    g01 x-3.584 y9.336 z-6.767
    g01 x-3.420 y9.397 z-6.778
    g01 x-3.256 y9.455 z-6.789
    g01 x-3.090 y9.511 z-6.800
    g01 x-2.924 y9.563 z-6.811
    g01 x-2.756 y9.613 z-6.822
    g01 x-2.588 y9.659 z-6.833
    g01 x-2.419 y9.703 z-6.844
    g01 x-2.250 y9.744 z-6.856
    g01 x-2.079 y9.781 z-6.867
    g01 x-1.908 y9.816 z-6.878
    g01 x-1.736 y9.848 z-6.889
    g01 x-1.564 y9.877 z-6.900
    g01 x-1.392 y9.903 z-6.911
    g01 x-1.219 y9.925 z-6.922
    g01 x-1.045 y9.945 z-6.933
    g01 x-0.872 y9.962 z-6.944
    g01 x-0.698 y9.976 z-6.956
    g01 x-0.523 y9.986 z-6.967
    g01 x-0.349 y9.994 z-6.978
    g01 x-0.175 y9.998 z-6.989
    g01 x-0.000 y10.000 z-7.000
    g01 x0.175 y9.998 z-7.011
    g01 x0.349 y9.994 z-7.022
    g01 x0.523 y9.986 z-7.033
    g01 x0.698 y9.976 z-7.044
    g01 x0.872 y9.962 z-7.056
    g01 x1.045 y9.945 z-7.067
    g01 x1.219 y9.925 z-7.078
    g01 x1.392 y9.903 z-7.089
    g01 x1.564 y9.877 z-7.100
    g01 x1.736 y9.848 z-7.111
    g01 x1.908 y9.816 z-7.122
    g01 x2.079 y9.781 z-7.133
    g01 x2.250 y9.744 z-7.144
    g01 x2.419 y9.703 z-7.156
    g01 x2.588 y9.659 z-7.167
    g01 x2.756 y9.613 z-7.178
    g01 x2.924 y9.563 z-7.189
    g01 x3.090 y9.511 z-7.200
    g01 x3.256 y9.455 z-7.211
    g01 x3.420 y9.397 z-7.222
    g01 x3.584 y9.336 z-7.233
    g01 x3.746 y9.272 z-7.244
    g01 x3.907 y9.205 z-7.256
    g01 x4.067 y9.135 z-7.267
    g01 x4.226 y9.063 z-7.278
    g01 x4.384 y8.988 z-7.289
    g01 x4.540 y8.910 z-7.300
    g01 x4.695 y8.829 z-7.311
    g01 x4.848 y8.746 z-7.322
    g01 x5.000 y8.660 z-7.333
    g01 x5.150 y8.572 z-7.344
    g01 x5.299 y8.480 z-7.356
    g01 x5.446 y8.387 z-7.367
    g01 x5.592 y8.290 z-7.378
    g01 x5.736 y8.192 z-7.389
    g01 x5.878 y8.090 z-7.400
    g01 x6.018 y7.986 z-7.411
    g01 x6.157 y7.880 z-7.422
    g01 x6.293 y7.771 z-7.433
    g01 x6.428 y7.660 z-7.444
    g01 x6.561 y7.547 z-7.456
    g01 x6.691 y7.431 z-7.467
    g01 x6.820 y7.314 z-7.478
    g01 x6.947 y7.193 z-7.489
    g01 x7.071 y7.071 z-7.500
    g01 x7.193 y6.947 z-7.511
    g01 x7.314 y6.820 z-7.522
    g01 x7.431 y6.691 z-7.533
    g01 x7.547 y6.561 z-7.544
    g01 x7.660 y6.428 z-7.556
    g01 x7.771 y6.293 z-7.567
    g01 x7.880 y6.157 z-7.578
    g01 x7.986 y6.018 z-7.589
    g01 x8.090 y5.878 z-7.600
    g01 x8.192 y5.736 z-7.611
    g01 x8.290 y5.592 z-7.622
    g01 x8.387 y5.446 z-7.633
    g01 x8.480 y5.299 z-7.644
    g01 x8.572 y5.150 z-7.656
    g01 x8.660 y5.000 z-7.667
    g01 x8.746 y4.848 z-7.678
    g01 x8.829 y4.695 z-7.689
    g01 x8.910 y4.540 z-7.700
    g01 x8.988 y4.384 z-7.711
    g01 x9.063 y4.226 z-7.722
    g01 x9.135 y4.067 z-7.733
    g01 x9.205 y3.907 z-7.744
    g01 x9.272 y3.746 z-7.756
    g01 x9.336 y3.584 z-7.767
    g01 x9.397 y3.420 z-7.778
    g01 x9.455 y3.256 z-7.789
    g01 x9.511 y3.090 z-7.800
    g01 x9.563 y2.924 z-7.811
    g01 x9.613 y2.756 z-7.822
    g01 x9.659 y2.588 z-7.833
    g01 x9.703 y2.419 z-7.844
    g01 x9.744 y2.250 z-7.856
    g01 x9.781 y2.079 z-7.867
    g01 x9.816 y1.908 z-7.878
    g01 x9.848 y1.736 z-7.889
    g01 x9.877 y1.564 z-7.900
    g01 x9.903 y1.392 z-7.911
    g01 x9.925 y1.219 z-7.922
    g01 x9.945 y1.045 z-7.933
    g01 x9.962 y0.872 z-7.944
    g01 x9.976 y0.698 z-7.956
    g01 x9.986 y0.523 z-7.967
    g01 x9.994 y0.349 z-7.978
    g01 x9.998 y0.175 z-7.989
    g01 x10.000 y0.000 z-8.000
    ;step-over pass: 2 - pitch pass N: 3
    g01 x9.998 y-0.175 z-8.011
    g01 x9.994 y-0.349 z-8.022
    g01 x9.986 y-0.523 z-8.033
    g01 x9.976 y-0.698 z-8.044
    g01 x9.962 y-0.872 z-8.056
    g01 x9.945 y-1.045 z-8.067
    g01 x9.925 y-1.219 z-8.078
    g01 x9.903 y-1.392 z-8.089
    g01 x9.877 y-1.564 z-8.100
    g01 x9.848 y-1.736 z-8.111
    g01 x9.816 y-1.908 z-8.122
    g01 x9.781 y-2.079 z-8.133
    g01 x9.744 y-2.250 z-8.144
    g01 x9.703 y-2.419 z-8.156
    g01 x9.659 y-2.588 z-8.167
    g01 x9.613 y-2.756 z-8.178
    g01 x9.563 y-2.924 z-8.189
    g01 x9.511 y-3.090 z-8.200
    g01 x9.455 y-3.256 z-8.211
    g01 x9.397 y-3.420 z-8.222
    g01 x9.336 y-3.584 z-8.233
    g01 x9.272 y-3.746 z-8.244
    g01 x9.205 y-3.907 z-8.256
    g01 x9.135 y-4.067 z-8.267
    g01 x9.063 y-4.226 z-8.278
    g01 x8.988 y-4.384 z-8.289
    g01 x8.910 y-4.540 z-8.300
    g01 x8.829 y-4.695 z-8.311
    g01 x8.746 y-4.848 z-8.322
    g01 x8.660 y-5.000 z-8.333
    g01 x8.572 y-5.150 z-8.344
    g01 x8.480 y-5.299 z-8.356
    g01 x8.387 y-5.446 z-8.367
    g01 x8.290 y-5.592 z-8.378
    g01 x8.192 y-5.736 z-8.389
    g01 x8.090 y-5.878 z-8.400
    g01 x7.986 y-6.018 z-8.411
    g01 x7.880 y-6.157 z-8.422
    g01 x7.771 y-6.293 z-8.433
    g01 x7.660 y-6.428 z-8.444
    g01 x7.547 y-6.561 z-8.456
    g01 x7.431 y-6.691 z-8.467
    g01 x7.314 y-6.820 z-8.478
    g01 x7.193 y-6.947 z-8.489
    g01 x7.071 y-7.071 z-8.500
    g01 x6.947 y-7.193 z-8.511
    g01 x6.820 y-7.314 z-8.522
    g01 x6.691 y-7.431 z-8.533
    g01 x6.561 y-7.547 z-8.544
    g01 x6.428 y-7.660 z-8.556
    g01 x6.293 y-7.771 z-8.567
    g01 x6.157 y-7.880 z-8.578
    g01 x6.018 y-7.986 z-8.589
    g01 x5.878 y-8.090 z-8.600
    g01 x5.736 y-8.192 z-8.611
    g01 x5.592 y-8.290 z-8.622
    g01 x5.446 y-8.387 z-8.633
    g01 x5.299 y-8.480 z-8.644
    g01 x5.150 y-8.572 z-8.656
    g01 x5.000 y-8.660 z-8.667
    g01 x4.848 y-8.746 z-8.678
    g01 x4.695 y-8.829 z-8.689
    g01 x4.540 y-8.910 z-8.700
    g01 x4.384 y-8.988 z-8.711
    g01 x4.226 y-9.063 z-8.722
    g01 x4.067 y-9.135 z-8.733
    g01 x3.907 y-9.205 z-8.744
    g01 x3.746 y-9.272 z-8.756
    g01 x3.584 y-9.336 z-8.767
    g01 x3.420 y-9.397 z-8.778
    g01 x3.256 y-9.455 z-8.789
    g01 x3.090 y-9.511 z-8.800
    g01 x2.924 y-9.563 z-8.811
    g01 x2.756 y-9.613 z-8.822
    g01 x2.588 y-9.659 z-8.833
    g01 x2.419 y-9.703 z-8.844
    g01 x2.250 y-9.744 z-8.856
    g01 x2.079 y-9.781 z-8.867
    g01 x1.908 y-9.816 z-8.878
    g01 x1.736 y-9.848 z-8.889
    g01 x1.564 y-9.877 z-8.900
    g01 x1.392 y-9.903 z-8.911
    g01 x1.219 y-9.925 z-8.922
    g01 x1.045 y-9.945 z-8.933
    g01 x0.872 y-9.962 z-8.944
    g01 x0.698 y-9.976 z-8.956
    g01 x0.523 y-9.986 z-8.967
    g01 x0.349 y-9.994 z-8.978
    g01 x0.175 y-9.998 z-8.989
    g01 x0.000 y-10.000 z-9.000
    g01 x-0.175 y-9.998 z-9.011
    g01 x-0.349 y-9.994 z-9.022
    g01 x-0.523 y-9.986 z-9.033
    g01 x-0.698 y-9.976 z-9.044
    g01 x-0.872 y-9.962 z-9.056
    g01 x-1.045 y-9.945 z-9.067
    g01 x-1.219 y-9.925 z-9.078
    g01 x-1.392 y-9.903 z-9.089
    g01 x-1.564 y-9.877 z-9.100
    g01 x-1.736 y-9.848 z-9.111
    g01 x-1.908 y-9.816 z-9.122
    g01 x-2.079 y-9.781 z-9.133
    g01 x-2.250 y-9.744 z-9.144
    g01 x-2.419 y-9.703 z-9.156
    g01 x-2.588 y-9.659 z-9.167
    g01 x-2.756 y-9.613 z-9.178
    g01 x-2.924 y-9.563 z-9.189
    g01 x-3.090 y-9.511 z-9.200
    g01 x-3.256 y-9.455 z-9.211
    g01 x-3.420 y-9.397 z-9.222
    g01 x-3.584 y-9.336 z-9.233
    g01 x-3.746 y-9.272 z-9.244
    g01 x-3.907 y-9.205 z-9.256
    g01 x-4.067 y-9.135 z-9.267
    g01 x-4.226 y-9.063 z-9.278
    g01 x-4.384 y-8.988 z-9.289
    g01 x-4.540 y-8.910 z-9.300
    g01 x-4.695 y-8.829 z-9.311
    g01 x-4.848 y-8.746 z-9.322
    g01 x-5.000 y-8.660 z-9.333
    g01 x-5.150 y-8.572 z-9.344
    g01 x-5.299 y-8.480 z-9.356
    g01 x-5.446 y-8.387 z-9.367
    g01 x-5.592 y-8.290 z-9.378
    g01 x-5.736 y-8.192 z-9.389
    g01 x-5.878 y-8.090 z-9.400
    g01 x-6.018 y-7.986 z-9.411
    g01 x-6.157 y-7.880 z-9.422
    g01 x-6.293 y-7.771 z-9.433
    g01 x-6.428 y-7.660 z-9.444
    g01 x-6.561 y-7.547 z-9.456
    g01 x-6.691 y-7.431 z-9.467
    g01 x-6.820 y-7.314 z-9.478
    g01 x-6.947 y-7.193 z-9.489
    g01 x-7.071 y-7.071 z-9.500
    g01 x-7.193 y-6.947 z-9.511
    g01 x-7.314 y-6.820 z-9.522
    g01 x-7.431 y-6.691 z-9.533
    g01 x-7.547 y-6.561 z-9.544
    g01 x-7.660 y-6.428 z-9.556
    g01 x-7.771 y-6.293 z-9.567
    g01 x-7.880 y-6.157 z-9.578
    g01 x-7.986 y-6.018 z-9.589
    g01 x-8.090 y-5.878 z-9.600
    g01 x-8.192 y-5.736 z-9.611
    g01 x-8.290 y-5.592 z-9.622
    g01 x-8.387 y-5.446 z-9.633
    g01 x-8.480 y-5.299 z-9.644
    g01 x-8.572 y-5.150 z-9.656
    g01 x-8.660 y-5.000 z-9.667
    g01 x-8.746 y-4.848 z-9.678
    g01 x-8.829 y-4.695 z-9.689
    g01 x-8.910 y-4.540 z-9.700
    g01 x-8.988 y-4.384 z-9.711
    g01 x-9.063 y-4.226 z-9.722
    g01 x-9.135 y-4.067 z-9.733
    g01 x-9.205 y-3.907 z-9.744
    g01 x-9.272 y-3.746 z-9.756
    g01 x-9.336 y-3.584 z-9.767
    g01 x-9.397 y-3.420 z-9.778
    g01 x-9.455 y-3.256 z-9.789
    g01 x-9.511 y-3.090 z-9.800
    g01 x-9.563 y-2.924 z-9.811
    g01 x-9.613 y-2.756 z-9.822
    g01 x-9.659 y-2.588 z-9.833
    g01 x-9.703 y-2.419 z-9.844
    g01 x-9.744 y-2.250 z-9.856
    g01 x-9.781 y-2.079 z-9.867
    g01 x-9.816 y-1.908 z-9.878
    g01 x-9.848 y-1.736 z-9.889
    g01 x-9.877 y-1.564 z-9.900
    g01 x-9.903 y-1.392 z-9.911
    g01 x-9.925 y-1.219 z-9.922
    g01 x-9.945 y-1.045 z-9.933
    g01 x-9.962 y-0.872 z-9.944
    g01 x-9.976 y-0.698 z-9.956
    g01 x-9.986 y-0.523 z-9.967
    g01 x-9.994 y-0.349 z-9.978
    g01 x-9.998 y-0.175 z-9.989
    g01 x-10.000 y-0.000 z-10.000
    g01 x-9.998 y0.175 z-10.011
    g01 x-9.994 y0.349 z-10.022
    g01 x-9.986 y0.523 z-10.033
    g01 x-9.976 y0.698 z-10.044
    g01 x-9.962 y0.872 z-10.056
    g01 x-9.945 y1.045 z-10.067
    g01 x-9.925 y1.219 z-10.078
    g01 x-9.903 y1.392 z-10.089
    g01 x-9.877 y1.564 z-10.100
    g01 x-9.848 y1.736 z-10.111
    g01 x-9.816 y1.908 z-10.122
    g01 x-9.781 y2.079 z-10.133
    g01 x-9.744 y2.250 z-10.144
    g01 x-9.703 y2.419 z-10.156
    g01 x-9.659 y2.588 z-10.167
    g01 x-9.613 y2.756 z-10.178
    g01 x-9.563 y2.924 z-10.189
    g01 x-9.511 y3.090 z-10.200
    g01 x-9.455 y3.256 z-10.211
    g01 x-9.397 y3.420 z-10.222
    g01 x-9.336 y3.584 z-10.233
    g01 x-9.272 y3.746 z-10.244
    g01 x-9.205 y3.907 z-10.256
    g01 x-9.135 y4.067 z-10.267
    g01 x-9.063 y4.226 z-10.278
    g01 x-8.988 y4.384 z-10.289
    g01 x-8.910 y4.540 z-10.300
    g01 x-8.829 y4.695 z-10.311
    g01 x-8.746 y4.848 z-10.322
    g01 x-8.660 y5.000 z-10.333
    g01 x-8.572 y5.150 z-10.344
    g01 x-8.480 y5.299 z-10.356
    g01 x-8.387 y5.446 z-10.367
    g01 x-8.290 y5.592 z-10.378
    g01 x-8.192 y5.736 z-10.389
    g01 x-8.090 y5.878 z-10.400
    g01 x-7.986 y6.018 z-10.411
    g01 x-7.880 y6.157 z-10.422
    g01 x-7.771 y6.293 z-10.433
    g01 x-7.660 y6.428 z-10.444
    g01 x-7.547 y6.561 z-10.456
    g01 x-7.431 y6.691 z-10.467
    g01 x-7.314 y6.820 z-10.478
    g01 x-7.193 y6.947 z-10.489
    g01 x-7.071 y7.071 z-10.500
    g01 x-6.947 y7.193 z-10.511
    g01 x-6.820 y7.314 z-10.522
    g01 x-6.691 y7.431 z-10.533
    g01 x-6.561 y7.547 z-10.544
    g01 x-6.428 y7.660 z-10.556
    g01 x-6.293 y7.771 z-10.567
    g01 x-6.157 y7.880 z-10.578
    g01 x-6.018 y7.986 z-10.589
    g01 x-5.878 y8.090 z-10.600
    g01 x-5.736 y8.192 z-10.611
    g01 x-5.592 y8.290 z-10.622
    g01 x-5.446 y8.387 z-10.633
    g01 x-5.299 y8.480 z-10.644
    g01 x-5.150 y8.572 z-10.656
    g01 x-5.000 y8.660 z-10.667
    g01 x-4.848 y8.746 z-10.678
    g01 x-4.695 y8.829 z-10.689
    g01 x-4.540 y8.910 z-10.700
    g01 x-4.384 y8.988 z-10.711
    g01 x-4.226 y9.063 z-10.722
    g01 x-4.067 y9.135 z-10.733
    g01 x-3.907 y9.205 z-10.744
    g01 x-3.746 y9.272 z-10.756
    g01 x-3.584 y9.336 z-10.767
    g01 x-3.420 y9.397 z-10.778
    g01 x-3.256 y9.455 z-10.789
    g01 x-3.090 y9.511 z-10.800
    g01 x-2.924 y9.563 z-10.811
    g01 x-2.756 y9.613 z-10.822
    g01 x-2.588 y9.659 z-10.833
    g01 x-2.419 y9.703 z-10.844
    g01 x-2.250 y9.744 z-10.856
    g01 x-2.079 y9.781 z-10.867
    g01 x-1.908 y9.816 z-10.878
    g01 x-1.736 y9.848 z-10.889
    g01 x-1.564 y9.877 z-10.900
    g01 x-1.392 y9.903 z-10.911
    g01 x-1.219 y9.925 z-10.922
    g01 x-1.045 y9.945 z-10.933
    g01 x-0.872 y9.962 z-10.944
    g01 x-0.698 y9.976 z-10.956
    g01 x-0.523 y9.986 z-10.967
    g01 x-0.349 y9.994 z-10.978
    g01 x-0.175 y9.998 z-10.989
    g01 x-0.000 y10.000 z-11.000
    g01 x0.175 y9.998 z-11.011
    g01 x0.349 y9.994 z-11.022
    g01 x0.523 y9.986 z-11.033
    g01 x0.698 y9.976 z-11.044
    g01 x0.872 y9.962 z-11.056
    g01 x1.045 y9.945 z-11.067
    g01 x1.219 y9.925 z-11.078
    g01 x1.392 y9.903 z-11.089
    g01 x1.564 y9.877 z-11.100
    g01 x1.736 y9.848 z-11.111
    g01 x1.908 y9.816 z-11.122
    g01 x2.079 y9.781 z-11.133
    g01 x2.250 y9.744 z-11.144
    g01 x2.419 y9.703 z-11.156
    g01 x2.588 y9.659 z-11.167
    g01 x2.756 y9.613 z-11.178
    g01 x2.924 y9.563 z-11.189
    g01 x3.090 y9.511 z-11.200
    g01 x3.256 y9.455 z-11.211
    g01 x3.420 y9.397 z-11.222
    g01 x3.584 y9.336 z-11.233
    g01 x3.746 y9.272 z-11.244
    g01 x3.907 y9.205 z-11.256
    g01 x4.067 y9.135 z-11.267
    g01 x4.226 y9.063 z-11.278
    g01 x4.384 y8.988 z-11.289
    g01 x4.540 y8.910 z-11.300
    g01 x4.695 y8.829 z-11.311
    g01 x4.848 y8.746 z-11.322
    g01 x5.000 y8.660 z-11.333
    g01 x5.150 y8.572 z-11.344
    g01 x5.299 y8.480 z-11.356
    g01 x5.446 y8.387 z-11.367
    g01 x5.592 y8.290 z-11.378
    g01 x5.736 y8.192 z-11.389
    g01 x5.878 y8.090 z-11.400
    g01 x6.018 y7.986 z-11.411
    g01 x6.157 y7.880 z-11.422
    g01 x6.293 y7.771 z-11.433
    g01 x6.428 y7.660 z-11.444
    g01 x6.561 y7.547 z-11.456
    g01 x6.691 y7.431 z-11.467
    g01 x6.820 y7.314 z-11.478
    g01 x6.947 y7.193 z-11.489
    g01 x7.071 y7.071 z-11.500
    g01 x7.193 y6.947 z-11.511
    g01 x7.314 y6.820 z-11.522
    g01 x7.431 y6.691 z-11.533
    g01 x7.547 y6.561 z-11.544
    g01 x7.660 y6.428 z-11.556
    g01 x7.771 y6.293 z-11.567
    g01 x7.880 y6.157 z-11.578
    g01 x7.986 y6.018 z-11.589
    g01 x8.090 y5.878 z-11.600
    g01 x8.192 y5.736 z-11.611
    g01 x8.290 y5.592 z-11.622
    g01 x8.387 y5.446 z-11.633
    g01 x8.480 y5.299 z-11.644
    g01 x8.572 y5.150 z-11.656
    g01 x8.660 y5.000 z-11.667
    g01 x8.746 y4.848 z-11.678
    g01 x8.829 y4.695 z-11.689
    g01 x8.910 y4.540 z-11.700
    g01 x8.988 y4.384 z-11.711
    g01 x9.063 y4.226 z-11.722
    g01 x9.135 y4.067 z-11.733
    g01 x9.205 y3.907 z-11.744
    g01 x9.272 y3.746 z-11.756
    g01 x9.336 y3.584 z-11.767
    g01 x9.397 y3.420 z-11.778
    g01 x9.455 y3.256 z-11.789
    g01 x9.511 y3.090 z-11.800
    g01 x9.563 y2.924 z-11.811
    g01 x9.613 y2.756 z-11.822
    g01 x9.659 y2.588 z-11.833
    g01 x9.703 y2.419 z-11.844
    g01 x9.744 y2.250 z-11.856
    g01 x9.781 y2.079 z-11.867
    g01 x9.816 y1.908 z-11.878
    g01 x9.848 y1.736 z-11.889
    g01 x9.877 y1.564 z-11.900
    g01 x9.903 y1.392 z-11.911
    g01 x9.925 y1.219 z-11.922
    g01 x9.945 y1.045 z-11.933
    g01 x9.962 y0.872 z-11.944
    g01 x9.976 y0.698 z-11.956
    g01 x9.986 y0.523 z-11.967
    g01 x9.994 y0.349 z-11.978
    g01 x9.998 y0.175 z-11.989
    g01 x10.000 y0.000 z-12.000
    ;step-over pass: 2 - pitch pass N: 4
    g01 x9.998 y-0.175 z-12.011
    g01 x9.994 y-0.349 z-12.022
    g01 x9.986 y-0.523 z-12.033
    g01 x9.976 y-0.698 z-12.044
    g01 x9.962 y-0.872 z-12.056
    g01 x9.945 y-1.045 z-12.067
    g01 x9.925 y-1.219 z-12.078
    g01 x9.903 y-1.392 z-12.089
    g01 x9.877 y-1.564 z-12.100
    g01 x9.848 y-1.736 z-12.111
    g01 x9.816 y-1.908 z-12.122
    g01 x9.781 y-2.079 z-12.133
    g01 x9.744 y-2.250 z-12.144
    g01 x9.703 y-2.419 z-12.156
    g01 x9.659 y-2.588 z-12.167
    g01 x9.613 y-2.756 z-12.178
    g01 x9.563 y-2.924 z-12.189
    g01 x9.511 y-3.090 z-12.200
    g01 x9.455 y-3.256 z-12.211
    g01 x9.397 y-3.420 z-12.222
    g01 x9.336 y-3.584 z-12.233
    g01 x9.272 y-3.746 z-12.244
    g01 x9.205 y-3.907 z-12.256
    g01 x9.135 y-4.067 z-12.267
    g01 x9.063 y-4.226 z-12.278
    g01 x8.988 y-4.384 z-12.289
    g01 x8.910 y-4.540 z-12.300
    g01 x8.829 y-4.695 z-12.311
    g01 x8.746 y-4.848 z-12.322
    g01 x8.660 y-5.000 z-12.333
    g01 x8.572 y-5.150 z-12.344
    g01 x8.480 y-5.299 z-12.356
    g01 x8.387 y-5.446 z-12.367
    g01 x8.290 y-5.592 z-12.378
    g01 x8.192 y-5.736 z-12.389
    g01 x8.090 y-5.878 z-12.400
    g01 x7.986 y-6.018 z-12.411
    g01 x7.880 y-6.157 z-12.422
    g01 x7.771 y-6.293 z-12.433
    g01 x7.660 y-6.428 z-12.444
    g01 x7.547 y-6.561 z-12.456
    g01 x7.431 y-6.691 z-12.467
    g01 x7.314 y-6.820 z-12.478
    g01 x7.193 y-6.947 z-12.489
    g01 x7.071 y-7.071 z-12.500
    g01 x6.947 y-7.193 z-12.511
    g01 x6.820 y-7.314 z-12.522
    g01 x6.691 y-7.431 z-12.533
    g01 x6.561 y-7.547 z-12.544
    g01 x6.428 y-7.660 z-12.556
    g01 x6.293 y-7.771 z-12.567
    g01 x6.157 y-7.880 z-12.578
    g01 x6.018 y-7.986 z-12.589
    g01 x5.878 y-8.090 z-12.600
    g01 x5.736 y-8.192 z-12.611
    g01 x5.592 y-8.290 z-12.622
    g01 x5.446 y-8.387 z-12.633
    g01 x5.299 y-8.480 z-12.644
    g01 x5.150 y-8.572 z-12.656
    g01 x5.000 y-8.660 z-12.667
    g01 x4.848 y-8.746 z-12.678
    g01 x4.695 y-8.829 z-12.689
    g01 x4.540 y-8.910 z-12.700
    g01 x4.384 y-8.988 z-12.711
    g01 x4.226 y-9.063 z-12.722
    g01 x4.067 y-9.135 z-12.733
    g01 x3.907 y-9.205 z-12.744
    g01 x3.746 y-9.272 z-12.756
    g01 x3.584 y-9.336 z-12.767
    g01 x3.420 y-9.397 z-12.778
    g01 x3.256 y-9.455 z-12.789
    g01 x3.090 y-9.511 z-12.800
    g01 x2.924 y-9.563 z-12.811
    g01 x2.756 y-9.613 z-12.822
    g01 x2.588 y-9.659 z-12.833
    g01 x2.419 y-9.703 z-12.844
    g01 x2.250 y-9.744 z-12.856
    g01 x2.079 y-9.781 z-12.867
    g01 x1.908 y-9.816 z-12.878
    g01 x1.736 y-9.848 z-12.889
    g01 x1.564 y-9.877 z-12.900
    g01 x1.392 y-9.903 z-12.911
    g01 x1.219 y-9.925 z-12.922
    g01 x1.045 y-9.945 z-12.933
    g01 x0.872 y-9.962 z-12.944
    g01 x0.698 y-9.976 z-12.956
    g01 x0.523 y-9.986 z-12.967
    g01 x0.349 y-9.994 z-12.978
    g01 x0.175 y-9.998 z-12.989
    g01 x0.000 y-10.000 z-13.000
    g01 x-0.175 y-9.998 z-13.011
    g01 x-0.349 y-9.994 z-13.022
    g01 x-0.523 y-9.986 z-13.033
    g01 x-0.698 y-9.976 z-13.044
    g01 x-0.872 y-9.962 z-13.056
    g01 x-1.045 y-9.945 z-13.067
    g01 x-1.219 y-9.925 z-13.078
    g01 x-1.392 y-9.903 z-13.089
    g01 x-1.564 y-9.877 z-13.100
    g01 x-1.736 y-9.848 z-13.111
    g01 x-1.908 y-9.816 z-13.122
    g01 x-2.079 y-9.781 z-13.133
    g01 x-2.250 y-9.744 z-13.144
    g01 x-2.419 y-9.703 z-13.156
    g01 x-2.588 y-9.659 z-13.167
    g01 x-2.756 y-9.613 z-13.178
    g01 x-2.924 y-9.563 z-13.189
    g01 x-3.090 y-9.511 z-13.200
    g01 x-3.256 y-9.455 z-13.211
    g01 x-3.420 y-9.397 z-13.222
    g01 x-3.584 y-9.336 z-13.233
    g01 x-3.746 y-9.272 z-13.244
    g01 x-3.907 y-9.205 z-13.256
    g01 x-4.067 y-9.135 z-13.267
    g01 x-4.226 y-9.063 z-13.278
    g01 x-4.384 y-8.988 z-13.289
    g01 x-4.540 y-8.910 z-13.300
    g01 x-4.695 y-8.829 z-13.311
    g01 x-4.848 y-8.746 z-13.322
    g01 x-5.000 y-8.660 z-13.333
    g01 x-5.150 y-8.572 z-13.344
    g01 x-5.299 y-8.480 z-13.356
    g01 x-5.446 y-8.387 z-13.367
    g01 x-5.592 y-8.290 z-13.378
    g01 x-5.736 y-8.192 z-13.389
    g01 x-5.878 y-8.090 z-13.400
    g01 x-6.018 y-7.986 z-13.411
    g01 x-6.157 y-7.880 z-13.422
    g01 x-6.293 y-7.771 z-13.433
    g01 x-6.428 y-7.660 z-13.444
    g01 x-6.561 y-7.547 z-13.456
    g01 x-6.691 y-7.431 z-13.467
    g01 x-6.820 y-7.314 z-13.478
    g01 x-6.947 y-7.193 z-13.489
    g01 x-7.071 y-7.071 z-13.500
    g01 x-7.193 y-6.947 z-13.511
    g01 x-7.314 y-6.820 z-13.522
    g01 x-7.431 y-6.691 z-13.533
    g01 x-7.547 y-6.561 z-13.544
    g01 x-7.660 y-6.428 z-13.556
    g01 x-7.771 y-6.293 z-13.567
    g01 x-7.880 y-6.157 z-13.578
    g01 x-7.986 y-6.018 z-13.589
    g01 x-8.090 y-5.878 z-13.600
    g01 x-8.192 y-5.736 z-13.611
    g01 x-8.290 y-5.592 z-13.622
    g01 x-8.387 y-5.446 z-13.633
    g01 x-8.480 y-5.299 z-13.644
    g01 x-8.572 y-5.150 z-13.656
    g01 x-8.660 y-5.000 z-13.667
    g01 x-8.746 y-4.848 z-13.678
    g01 x-8.829 y-4.695 z-13.689
    g01 x-8.910 y-4.540 z-13.700
    g01 x-8.988 y-4.384 z-13.711
    g01 x-9.063 y-4.226 z-13.722
    g01 x-9.135 y-4.067 z-13.733
    g01 x-9.205 y-3.907 z-13.744
    g01 x-9.272 y-3.746 z-13.756
    g01 x-9.336 y-3.584 z-13.767
    g01 x-9.397 y-3.420 z-13.778
    g01 x-9.455 y-3.256 z-13.789
    g01 x-9.511 y-3.090 z-13.800
    g01 x-9.563 y-2.924 z-13.811
    g01 x-9.613 y-2.756 z-13.822
    g01 x-9.659 y-2.588 z-13.833
    g01 x-9.703 y-2.419 z-13.844
    g01 x-9.744 y-2.250 z-13.856
    g01 x-9.781 y-2.079 z-13.867
    g01 x-9.816 y-1.908 z-13.878
    g01 x-9.848 y-1.736 z-13.889
    g01 x-9.877 y-1.564 z-13.900
    g01 x-9.903 y-1.392 z-13.911
    g01 x-9.925 y-1.219 z-13.922
    g01 x-9.945 y-1.045 z-13.933
    g01 x-9.962 y-0.872 z-13.944
    g01 x-9.976 y-0.698 z-13.956
    g01 x-9.986 y-0.523 z-13.967
    g01 x-9.994 y-0.349 z-13.978
    g01 x-9.998 y-0.175 z-13.989
    g01 x-10.000 y-0.000 z-14.000
    g01 x-9.998 y0.175 z-14.011
    g01 x-9.994 y0.349 z-14.022
    g01 x-9.986 y0.523 z-14.033
    g01 x-9.976 y0.698 z-14.044
    g01 x-9.962 y0.872 z-14.056
    g01 x-9.945 y1.045 z-14.067
    g01 x-9.925 y1.219 z-14.078
    g01 x-9.903 y1.392 z-14.089
    g01 x-9.877 y1.564 z-14.100
    g01 x-9.848 y1.736 z-14.111
    g01 x-9.816 y1.908 z-14.122
    g01 x-9.781 y2.079 z-14.133
    g01 x-9.744 y2.250 z-14.144
    g01 x-9.703 y2.419 z-14.156
    g01 x-9.659 y2.588 z-14.167
    g01 x-9.613 y2.756 z-14.178
    g01 x-9.563 y2.924 z-14.189
    g01 x-9.511 y3.090 z-14.200
    g01 x-9.455 y3.256 z-14.211
    g01 x-9.397 y3.420 z-14.222
    g01 x-9.336 y3.584 z-14.233
    g01 x-9.272 y3.746 z-14.244
    g01 x-9.205 y3.907 z-14.256
    g01 x-9.135 y4.067 z-14.267
    g01 x-9.063 y4.226 z-14.278
    g01 x-8.988 y4.384 z-14.289
    g01 x-8.910 y4.540 z-14.300
    g01 x-8.829 y4.695 z-14.311
    g01 x-8.746 y4.848 z-14.322
    g01 x-8.660 y5.000 z-14.333
    g01 x-8.572 y5.150 z-14.344
    g01 x-8.480 y5.299 z-14.356
    g01 x-8.387 y5.446 z-14.367
    g01 x-8.290 y5.592 z-14.378
    g01 x-8.192 y5.736 z-14.389
    g01 x-8.090 y5.878 z-14.400
    g01 x-7.986 y6.018 z-14.411
    g01 x-7.880 y6.157 z-14.422
    g01 x-7.771 y6.293 z-14.433
    g01 x-7.660 y6.428 z-14.444
    g01 x-7.547 y6.561 z-14.456
    g01 x-7.431 y6.691 z-14.467
    g01 x-7.314 y6.820 z-14.478
    g01 x-7.193 y6.947 z-14.489
    g01 x-7.071 y7.071 z-14.500
    g01 x-6.947 y7.193 z-14.511
    g01 x-6.820 y7.314 z-14.522
    g01 x-6.691 y7.431 z-14.533
    g01 x-6.561 y7.547 z-14.544
    g01 x-6.428 y7.660 z-14.556
    g01 x-6.293 y7.771 z-14.567
    g01 x-6.157 y7.880 z-14.578
    g01 x-6.018 y7.986 z-14.589
    g01 x-5.878 y8.090 z-14.600
    g01 x-5.736 y8.192 z-14.611
    g01 x-5.592 y8.290 z-14.622
    g01 x-5.446 y8.387 z-14.633
    g01 x-5.299 y8.480 z-14.644
    g01 x-5.150 y8.572 z-14.656
    g01 x-5.000 y8.660 z-14.667
    g01 x-4.848 y8.746 z-14.678
    g01 x-4.695 y8.829 z-14.689
    g01 x-4.540 y8.910 z-14.700
    g01 x-4.384 y8.988 z-14.711
    g01 x-4.226 y9.063 z-14.722
    g01 x-4.067 y9.135 z-14.733
    g01 x-3.907 y9.205 z-14.744
    g01 x-3.746 y9.272 z-14.756
    g01 x-3.584 y9.336 z-14.767
    g01 x-3.420 y9.397 z-14.778
    g01 x-3.256 y9.455 z-14.789
    g01 x-3.090 y9.511 z-14.800
    g01 x-2.924 y9.563 z-14.811
    g01 x-2.756 y9.613 z-14.822
    g01 x-2.588 y9.659 z-14.833
    g01 x-2.419 y9.703 z-14.844
    g01 x-2.250 y9.744 z-14.856
    g01 x-2.079 y9.781 z-14.867
    g01 x-1.908 y9.816 z-14.878
    g01 x-1.736 y9.848 z-14.889
    g01 x-1.564 y9.877 z-14.900
    g01 x-1.392 y9.903 z-14.911
    g01 x-1.219 y9.925 z-14.922
    g01 x-1.045 y9.945 z-14.933
    g01 x-0.872 y9.962 z-14.944
    g01 x-0.698 y9.976 z-14.956
    g01 x-0.523 y9.986 z-14.967
    g01 x-0.349 y9.994 z-14.978
    g01 x-0.175 y9.998 z-14.989
    g01 x-0.000 y10.000 z-15.000
    g0 x0 y0
    g0 z5
    M5
    M30
    Mar 2007
    304
    Re: Thread with Helical Interpolation Milling on Mach3
    Hi- I'd be interested in trying this software- could you please re-post to the dropbox?
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Feb 2013
    33
    Hello Jon.
    Thanks for your answer.
    I have done some improvements in my program but Portuguese version.
    I have just made a rapid translation for English. There is a lot of mistakes that if you want you can help me to translate.
    This video shows my new milling machine running my G-Code generated by this software.
    DOWNLOAD LINK:
    http://www.m1automacao.com.br/suport...erpolation.zip
    I have got more Wizards to generate G-Code for drilling, conical milling...
    You can add me: 55 11 99431-8558 whatsapp
    Feb 2013
    33
  1. thread milling without helical interpolation?
    By mjb71 in forum Mori Seiki lathes
    Last Post: 07-03-2023, 09:59 PM
  2. helical interpolation help.
    By albeens in forum Uncategorised CAD Discussion
    Last Post: 07-14-2014, 11:52 AM
  3. helical thread milling
    By seanagel in forum CNC Swiss Screw Machines
    Last Post: 05-16-2013, 04:43 PM
  4. Helical Interpolation
    By eliot15 in forum GibbsCAM
    Last Post: 09-18-2011, 03:40 PM
  5. MV 35/40 Helical Interpolation
    By Millem in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 03:54 PM
