585,925 active members*
3,362 visitors online*
    Jan 2018
    new cnc lathe build
    hello i need some help ,i have nima 23stepper motor 10kg torque can i use it to build cnc lathe i have mach 3 and arduino controller also which will be best
    Sent from my m2 using Tapatalk
    Sep 2017
    49
    Re: new cnc lathe build
    You could use nema 23 motors to build a lathe and mach3 would work best for a lathe from what i have tried arduino grbl isn’t supported turning.
    Jan 2018
    thanks
    Jan 2018
    help my laptop didn't support mach3 parrelel port so i want.to use grbl for laith
    Mar 2015
    409
    Quote Originally Posted by KyleWarren View Post
    I use nema17 steppers on my lathe (X,Z), a nema 23 or 24 for the spindle (C) and GRBL 1.1f for controller. Driving the spindle using a stepper makes it possible to use GRBL for threading, broaching knurling and a lot of other cool stuff.
    The whole CNC conversion cost less then $100 and it works very well!
    For information, documentation, pictures and drawings, have a look at: Welkom op www.mwt.messageboard.nl
  1. lathe build
    By brian257 in forum Uncategorised MetalWorking Machines
    Last Post: 07-12-2016, 09:35 PM
  2. New CNC Lathe build
    By sprinter in forum Taig Mills / Lathes
    Last Post: 02-04-2011, 03:27 PM
  3. Build Your Own Lathe
    By Drakkn in forum Mini Lathe
    Last Post: 01-08-2010, 02:12 PM
  4. build a lathe?
    By highhat in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2007, 04:13 AM
