585,925 active members*
3,518 visitors online*
    Oct 2017
    40
    G-Code Modal and non-modal
    I can not find in any way what are the current g code(On the screen of the program)
    For example: G61 or G64
    I would also like to ask about the tool
    can i use: T1-T3 .... (with length and diameter parameters) offset G40 G41 G42
    P.S. Need a manual on the available G code
    24221
    Re: G-Code Modal and non-modal
    Obtain the book CNC Programming by Peter Smid.
    Al.
    Albert E.
    15362
    Quote Originally Posted by R2D3 View Post
    You can find anything you want to learn about G-Code on the internet
    First to help with the G-Code, what control are you using , not all G-Codes are supported, some controls use different G-Codes, and format
    T1 - T3 is correct normally used like this if you have a tool changer T1M6
    Work off sets are G54 to G59 Etc depending on the control
    G40 G41 G42 is for cutter compensation this is not used to set tool offsets
    Tool offsets are set in your tool table ? tool offset page in your control
    Mactec54
    Oct 2017
    40
    I know what they mean
    I do not see them on the machine control panel
    24221
    Albert E.
  1. DX-32 G17, G18, and G19 Modal?
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 09-29-2011, 04:59 PM
  2. G61.1 modal G code in mazatrol
    By kendo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-23-2011, 11:12 AM
  3. MODAL IS OUT OF G80 ERROR
    By erdemkaraman in forum Uncategorised MetalWorking Machines
    Last Post: 03-25-2008, 02:10 PM
  4. Non-modal G00,G01...G03
    By cncuser1 in forum Mastercam
    Last Post: 05-30-2007, 07:39 PM
  5. Post Processor (ISO G-Code - Non Modal)
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2005, 02:32 PM
