Greetings to all,
let me tell you my story. My first CNC machine was a Chinese 6040. My thoughts when purchasing the machine on eBay ( that can not be so hard to program such machine-like print and go. What a big disappointment
I was jogging the machine and had no clue what am I doing. When I found a G-code on the internet I uploaded it to the machine and pushed start the machine speeds to the end (no limit switches so you can imagine how that ended).
Then came the year 2015 and the idea to make a low budget machine, I started to buy really cheap parts and with the time I wanted more and more quality components. But if the base is poor also good quality components will not help.
The base is on extruded aluminum profiles, I use linear rails on all axis and ball screw. At first, i wanted to control the CNC machine with PLanet CNC motion board, but I had some troubles so I switched to the CS-LAB CSMIO/M controller.
One of the best decisions in a long time. Anyhow then I bought a Mikron WF3 and changed the motors and controller (also cs lab) that took me about two and a half year and still not the result I wanted.
And now my project the CNC MK3 the specs :
- Construction is a fixed table and moving gantry.
-Construction is welded profiles 80x80x10mm
-The construction is baked (i don't know the correct expression)
-The important surfaces are machined and grinded (for rail, motor mounting)
- Rails 35 on the x-axis and 25 on y and z-axis.
-servo motors 750w 3000 rpm
-automatic tool change
-magazine for 12 tools
-the spindle is from Mechatrone
-coolant and mist system
-Build in 3d sensor for centering
-automatic lubrication system
-working area 400x400x300mm
The machine will be for machining aluminum parts and engraving in metal.
Attachment 385106
I have most of the parts at home just waiting for a bearing to continue the build,
I can upload some pictures if anyone is interested.
Best regards
