585,902 active members*
4,150 visitors online*
    Dec 2017
    82
    Cnc4pc c62 Board help please
    Hello
    I use c62 board and I am very happy with that.
    my question is
    all my inputs set to be activate with 24 volt .
    all jumpers set for that and when I connect the
    input to 24 volt green led in mach turn on.
    my problem is that
    I got a tool setter sensor and it works with 5 volt.
    I can use the output of c62 for 5 volt.
    The sensor will activate when it sink to common I guess it has to connect to
    zero volt.
    how I have to change the input 5 port 1 only to
    work with that. I want all other inputs still activate with
    +24 volt.
    which jumpers I have to change ?
    how can I do that ?
    please Help.
    Dec 2017
    82
    Re: Cnc4pc c62 Board help please
    Still waiting .
    Any help please ?
    Yes, all I/Os have jumpers to select the operating voltage for each pin. This is the same for inputs or outputs.
    Let me know if it is clear.
    Arturo Duncan
    http://cnc4pc.com
    Apr 2003
    540
    Original message removed. Sorry for jumping in with incorrect advice Arturod, I didn't realize each input pin had it's own jumper! Makes it simple, like you said he just needs to set the jumper for the sensor input pin to 5v.
    Yes, you can. You do have a jumper to set the common to be used for each group of I/Os, and there are independent jumpers for each pin to select if that pin would use +5vdc or +12/24vdc logic. I know the way we set it up may be a little unconventional, but it allows wiring I/Os without having to use external pull-up/down or in-line resistors. So you can wire common industrial sensors, relays or other devices using TTL signals.
    Arturo Duncan
    http://cnc4pc.com
  1. ESS with C52 Board from CNC4PC
    By ballistic42 in forum Benchtop Machines
    Last Post: 11-09-2015, 04:15 PM
  2. CNC4PC C17 master control board: is anyone using this board
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 11:51 PM
  3. Hobbycnc ez and cnc4pc C11 board
    By Lasr Da Vinci in forum Controller Cards
    Last Post: 10-29-2012, 04:31 PM
  4. CNC4PC C1 Board
    By BTS in forum CNC Machine Related Electronics
    Last Post: 06-07-2011, 09:22 PM
  5. 320's and cnc4pc multifunction board
    By dewme5 in forum Gecko Drives
    Last Post: 08-16-2006, 04:22 PM
