Re: 1980 wells index 805 cnc "rebuild" and update
Originally Posted by
Clayforrey
Some of my questions ...
The drives get 30a each for a total of 90 without the 3hp motor? Holy **** is this Right?
30 amps is the max momentary output of the drives. In operation they won't draw anywhere near that much power. 30 amps of 230V, 3 phase should be more than enough for the entire machine.
My 3 phase power has a wild leg,hot let, stinger leg, hi leg or whatever you want to call it, should I address this?
The only time this would become an issue is if you are splitting off 120V power using the neutral, then you would need to make sure that you are not using the wild leg. Between the phases, you will have 230V.
Nice looking machine. :cheers:
Jim Dawson
Sandy, Oregon, USA
