Hello!
I am new here and hope i ended up in the right place.
Totally new to laser engraving but want to dive right in, i need a small simple machine yet powerful enough for smaller fine engravings in harder materials, even for engraving/etching in metal if possible..
Have been looking at the small and cheap engravers from 'NEJE', perfect size for my needs, but all models are to weak (300mw - 1500mw).
Found a replacement board through another forum that will work with this unit and add GRBL, think i saw in a comment somewhere that it supports a 2.5 watt laser, but i could have misinterpreted since i had to Google translate the text.. but it would be great if it did, and maybe then even higher ones like 5 or 5.5 watt!
Since i don't know **** from cheese right now regarding this subject i hope you guys can help me figure out if this mod is even possible..
This is the 'NEJE' unit.
https://www.aliexpress.com/item/NEJE...ceBeautifyAB=5
This is the board i am thinking about using.
https://www.aliexpress.com/item/circ....e2483a9aIsPNe
Any thoughts and ideas are more than welcome, would really appreciate help with this.
