585,712 active members*
4,038 visitors online*
    Jun 2004
    6618
    Plasma cutting metals other than steel.
    I realize this is a really ignorant question. I have actually done many searches trying to find an answer. I have owned several different types of welders. I used to own a wire feed welder that could weld aluminum using different wire and (argon?) gas. I never actually used it for anything but steel.
    Do I need a gas other than compressed air to plasma cut aluminum?
    My router does pretty well cutting thin aluminum, but I was just curious. Also if there are other gases needed to cut other metals, where would I find something that tells me what gas for what metal?
    I like some of the things (artwork) I've seen made from copper. I guess they are flame kissed afterward with an OA or OP torch to get the coloring.
    Lee
    You can cut aluminum, copper, bronze, and brass as well with plasma.
    Some people will use a gas mixture with aluminum instead of just compressed air to get a better cut quality as aluminum can have a pretty bad cut quality if not done properly.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Jun 2004
    6618
    Thanks, Mike.
    I thought that was the case, but never saw it nailed up to read anywhere.
    Lee
    Feb 2006
    1260
    I have heard of inert gasses (nitrogen maybe) mentioned. But I think the topic for the discussion was about keeping moisture & oil away from plasma.
    If it works.....Don't fix it!
  1. Basic plasma troubleshooting - 1/4" steel
    By meerkatguy in forum Waterjet General Topics
    Last Post: 01-20-2007, 08:23 PM
  2. Speeds for cutting metals relating to pulley size?
    By ZipSnipe in forum Mechanical Calculations/Engineering Design
    Last Post: 06-16-2006, 02:11 AM
  3. Plasma cutter for 3mm mild steel
    By DEEDEE in forum Waterjet General Topics
    Last Post: 01-20-2006, 12:25 AM
  4. Cutting stainless steel
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-25-2005, 11:14 PM
  5. cnc plasma or oxy for 5/8" steel
    By tltaylor in forum Waterjet General Topics
    Last Post: 01-07-2005, 06:50 AM
