585,676 active members*
4,004 visitors online*
    Apr 2015
    5
    miiling chmfer on difrent level serfes
    Hello
    i try to mill a 45D chamfer on a profil that has difrent hight level.
    what should be the best way?
    Mar 2017
    411
    Re: miiling chmfer on difrent level serfes
    If you only have 3 Axis, then you would need to do it in 3 operations. Chamfer the top at the highest Z level, then turn the part on it's side to finish the cutout part that had the lower level Z position where the slot is. This would give you a perfect chamfer depth and angle all the way around the circumference.
    Apr 2015
    5
    Thank you
    Is there no way to use the HSM miiling to do it??
    Jun 2003
    1365
    Use HSS user defined projection. Select the surface, select the upper or lower curve and a tool big enough to do it. I usually use a ball mill for chamfers like that.
    Oct 2016
    23
    There's a contour 3d operation that worked pretty well when I needed to do a variable level chamfer.
  1. reducing effort for compensation miiling :)
    By deadlykitten in forum Okuma
    Last Post: 10-11-2016, 03:40 PM
  2. Z Level Rough Vs Z Level Finish
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-19-2016, 03:37 AM
