585,954 active members*
4,650 visitors online*
    Jan 2018
    Arrow 750 boot issues
    Have an arrow 750 with boot issues. First problem is servo board fails during start up diagnostics. Second problem getting page fault error System fail. Also comes up with SEV_SYSTEM_FAIL_CHANNEL_ID, Application error Application timeout. The exe name is pgm.exe and SEV16.DLL error. Have tried switching DV5 board and two different hard drives. All come up with exact errors. No failure lights on bridge board either.
    Any help would be appreciated.
    Mar 2011
    462
    You may have multiple issues, but at a minimum, your servo fail is caused by a lack of communication with the RT board. Most likely cause is RT Bios, but could also be WS BIOS. Send me a PM with WS and RT part numbers. I should be able to send you a WS setup config, but the RT board likely needs to be reflashed.
    Jun 2018
    maverlck,
    I have an Arrow 1250 that seems to need RT flash (Servo Board not configured)3-424-2379A02, but I don't know how to send PM to you.
  1. Arrow 500 touch screen boot up problem
    By midworld08 in forum Cincinnati CNC
    Last Post: 05-13-2017, 01:51 AM
  2. Boot up issues
    By Ken_Shea in forum Haas Mills
    Last Post: 09-29-2016, 05:55 PM
  3. Unable to boot Arrow 500 A2100
    By AccuMillGuy in forum Cincinnati CNC
    Last Post: 03-30-2014, 06:38 PM
  4. 2000 Arrow 500 boot problems
    By Ihauer in forum Cincinnati CNC
    Last Post: 10-25-2013, 03:12 PM
  5. Arrow 750 boot then freeze problem
    By Labguy in forum Cincinnati CNC
    Last Post: 12-05-2012, 07:36 PM
