585,581 active members*
3,657 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Variation in material thickness and how to overcome...
    Feb 2009
    Material tolerance variation in thickness and how to overcome...
    Hey folks - this is driving me to distraction so hopefully someone can help out.
    I'm trying to 'photo engrave' a piece of granite. The main issue is that it requires a very shallow cut - say 0.1mm or less. If there's variance of 0.5-1mm over the entire piece there's some obvious problems arising.
    There's a few simple - and some quite old - machines that seem to handle this with no problems. Two machines are a GALEKS and GRANITOGRAV - the ones with the angled Z axis. I'm guessing that the angle just makes it a cheaper machine to make as there's no z screw involved.
    The Z zero of these machines is set at 1mm. They have a tolerance of 1 to 2 mm in machining depth.
    So - two questions I suppose...
    1. How do I overcome the tolerance issue?
    2. How do the angled Zaxis machine get such good results?
    Cheers.
    Paolo
    Sep 2006
    245
    Re: Variation in material thickness and how to overcome...
    Do a search for "auto leveling" and see if the same tricks used for cutting PCB boards would help in your case. It starts with a surface map generated by a touch probe.
    Here is an example http://www.cnczone.com/forums/linuxc...are-forum.html
    Steve
    Feb 2009
    That does look interesting but will have to file it in the library for later.
    I'm using a Roland/Techsoft machine so kind of locked into the proprietary control software - no Gcode or Mach3 for me
  1. Material thickness you cut
    By Klbhammond in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-02-2018, 05:43 PM
  2. Thickness of MDF to use as Building Material?
    By iamadude in forum DIY CNC Router Table Machines
    Last Post: 03-01-2015, 09:52 PM
  3. *HELP* Variation of board thickness across pcb *HELP*
    By chunsiang in forum PCB milling
    Last Post: 07-21-2013, 09:51 PM
  4. Arc Voltage and Material Thickness
    By Stout in forum Hypertherm Plasma
    Last Post: 02-21-2012, 07:24 PM
  5. Help with material thickness
    By Bubba906 in forum Vacuum forming, Thermoforming etc
    Last Post: 10-25-2011, 04:11 AM
