585,973 active members*
4,108 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Upgraded USBContoller Mk3/4 firmware via TNG now cannot use old software
Results 1 to 8 of 8
    Jan 2018
    5
    Angry Upgraded USBContoller Mk3/4 firmware via TNG now cannot use old software
    I downloaded the TNG software and followed the instructions to install. After I upgraded the controller firmware and drivers, I cannot use the old software. I do not have my license key yet (hopefully in tomorrow’s email) so I tried to do some work with the old software. Now nothing is working. ;-(
    Is the new firmware backwards compatible with the old software?
    Mar 2017
    1311
    Re: Upgraded USBContoller Mk3/4 firmware via TNG now cannot use old software
    If you want to use CNC USB controller software once your controller is updated with PlanetCNC TNG software:
    -In PlanetCNC TNG click: Machine/Controller/Advanced/Revert to V1
    -Close TNG
    -Open CNC USB controller software and update firmware: Machine/Update Firmware
    Oct 2017
    40
    Hi
    As I was advised to use for threading TNG
    I installed it, updated the firmware of my card.
    Now CNC USB Controller does not work (In PlanetCNC TNG click: Machine/Controller/Advanced/Revert to V1 - inactive)
    In PlanetCNC TNG : connecting i see my board but I can’t go to her simulation remains selected.
    Motors no longer spin.
    Oct 2017
    40
    I also noticed that activation code "LUxx-xxxx-xxxx-ALER" changed to CU5xx-xxxxx--xxxxx--xxxxx--xxxxx-XV5J
    I can’t activate my license.
    I looked at the post about license problems and installed the files (the dialog was different but I had messages about the successful installation) https://planet-cnc.com/certificate-import/
    Mar 2017
    1311
    LUxx code is for CNC USB software. TNG uses different CUxx codes.
    If you have valid LUxx license then you can get free CUxx license. Contact our support.
    Oct 2017
    40
    did the engines stop working due to the simulation mode?
    Oct 2017
    40
    I understood why the engines do not work.
    I will write it for beginners like me.
    In the Connection menu, you need to select the device, double-click the device to change the value in Primary Controller, then click OK.
    I just selected the device and clicked OK, this method does not work, so my engines did not spin.
    But now everything works.
    Mar 2017
    1311
    Here is described all the info needed for quick migration to PlanetCNC TNG sw:
    https://planet-cnc.com/list-essentia...tng-tutorials/
  1. Replies: 0
    Last Post: 07-26-2017, 04:10 PM
  2. G.Weike Lasercut Software / Firmware mismatch?
    By daviddavid in forum G.Weike Laser
    Last Post: 05-09-2017, 03:15 AM
  3. Running a FADAL CNC on Hyrel3D Circuitry, Firmware and Software
    By Davo3 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-01-2016, 12:30 PM
  4. EnRoute Software Now Upgraded to Version 5!
    By MultiCam Canada in forum News Announcements
    Last Post: 11-30-2012, 06:35 PM
  5. Just upgraded software,
    By gixxergary in forum Mastercam
    Last Post: 12-27-2011, 09:01 PM
