585,973 active members*
4,182 visitors online*
Results 1 to 2 of 2
    Oct 2008
    Question iTNC530 QR Values
    I use Q values a good bit for my programming routines, however if the machine is powered down I loose the Q values and have to reload them.
    I was reading the manual and seen that QR values are supposed to be non-volatile in a machine shut down situation.
    I take it this means, that if I use QR values instead of regular Q values that this will fix the issues.
    How do you view the QR values to see what they are set to?
    Thanks in advanced.
    Jan 2015
    3
    Re: iTNC530 QR Values
    Press Q button on single/auto side like you normally view Q-parameters and press the "Q,QL,QS,QR" soft key to toggle the list
    E: didn't notice this topic was three years old, sry
