585,973 active members*
4,145 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Glass Cutting Engraving CNC machine
    Jan 2017
    84
    hi there
    I have some questions on Glass cutting engraving cnc machine:
    what is the better or common choice of Table material, Knowing that they use a lot of water, I prefer the ones that have some sort of pool filled with water
    and the work piece is in the water. The size of the table I am looking is about 2000 mm * 3300 mm. Off course I am open to all your recommendations or suggestions.
    From the videos that i have seen some of them have Rotating spindle head, Is it a Must or can we treat it like a traditional wood Cutting Router with movement in all 3 axis?
    Please provide any links or readings on these issues.
    regards
    jhonansaro
    Apr 2004
    5737
    Re: Glass Cutting Engraving CNC machine
    If you just want to cut glass, you can use a diamond drag engraving tool to score the cut lines, and break it along them. It doesn't have to happen under water, although a little oil helps.
    Engraving would be a better excuse to do all that, but most people are engraving glass with lasers these days. (Yes, I know it's a different look.)
    Andrew Werby
    Website
    Hi
    I have a Question for You
    What are the advantage of glass cutting engraving Machines ?
  1. Searching for a laser engraving machine for Wine glass and beer mugs.
    By guevara_123 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-20-2016, 05:16 AM
  2. New 6x8ft Jinan Senfang 100W machine for engraving glass
    By petersglassshop in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2016, 05:34 PM
  3. Water jet cutting machine for cutting glass stone metal
    By sinowaterjet in forum News Announcements
    Last Post: 07-16-2014, 07:48 AM
  4. laser machine engraving glass with plotter
    By wyl6362708 in forum Videos
    Last Post: 03-28-2012, 02:35 AM
  5. Replies: 0
    Last Post: 04-15-2011, 03:45 AM
