585,568 active members*
3,208 visitors online*
Results 1 to 6 of 6
    Jan 2018
    6
    spindle encoder for lathe
    hi all
    i want to make lathe as cnc conversion
    i see a lots of thing about encoder or about spindle encoder for rpm and thread cut
    but i dont know what is the best thing
    my question is... what is the spindle encoder i should to use for that
    something good .cheap and easy to setup
    Oct 2006
    24
    Re: spindle encoder for lathe
    It all depends on which software and motion control vendor you are going to use. Some software (Mach3) only uses/reads one signal per revolution so all you need is a disk with one slot while others will read many signals/pulses per revolution.
    7xCNC - Minilathe CNC :: Spindle Encoder
    A simple photo interupter will give you an accurate spindle speed and the ability to cut threads.
    https://www.robotshop.com/en/wavesha...RoCbwUQAvD_BwE
    24220
    If you want a motor 'geared' off of an encoder as the way as it is done on professional systems.
    You need a Galil based, Linux, or dynomotion system.
    Al.
    Albert E.
    Jan 2018
    6
    Quote Originally Posted by RHT View Post
    thank you for yours helping me
    i saw in YouTube using Incremental Encoders
    do you thing is good for thread
    result
    Oct 2006
    24
    Yes it would. But, as I said, it depends on which software and motion controller you choose. Not all hardware and/or software combinations can utilize the information.
    24220
    Quote Originally Posted by anowrosh View Post
    do you thing is good for thread result
    That is what is used in the post #3 description.
    Al.
    Albert E.
  1. Techno CNC Lathe encoder
    By Blakea1790 in forum Benchtop Machines
    Last Post: 10-10-2014, 03:29 PM
  2. New Spindle Encoder Twice the Resolution of Old Encoder - What to do?
    By ecnels in forum Vertical Mill, Lathe Project Log
    Last Post: 10-12-2013, 11:39 PM
  3. Spindle encoder Haas Mini lathe delivery
    By marto74 in forum Haas Mills
    Last Post: 05-25-2012, 02:53 PM
  4. spindle dc servo / encoder, lathe
    By hutchison in forum Machines running Mach Software
    Last Post: 04-05-2009, 03:48 PM
  5. Need an encoder for my C3 lathe spindle.
    By alexccmeister in forum Shopmaster/Shoptask
    Last Post: 08-07-2008, 04:56 AM
