I'm a new owner of a router table, with all axes set up with paired limit switches. Using just one example, the X axis "home" is found using the limit switch at the -X side. There's another limit switch at the other (+X) end, wired in parallel. The other axes are similar.
Homing works fine, and if I jog into the home switch, after a reset, I can drive in the + direction. The problem is if I run into the + limit switch... it still allows only driving farther into the + direction, no matter what I have tried so far. The only good way to get off the + switch has been to disconnect the switch wire temporarily. Unless there is some setting I've missed, I would put in a pushbutton to temporarily disconnect the limit switch circuit.
Anyone know a Mach3 setting that fixes this? (The override box doesn't help, as far as I can tell).
