585,749 active members*
3,830 visitors online*
    Oct 2014
    33
    DM2400 motor gears
    Tonight I removed the motor cover off the Z Axis to pull the drive card off and put new JTS connectors on in prep for the Gecko drive. Here is what I found, When I turned the motor shaft it turned freely no resistance and no up and down. I pulled the motor and found the small 10 tooth gear was loose on the shaft. I got an allen wrench and could not tighten the set screw. I ran a M4 tap down the hole and cleared some burrs off the treads and the set screw will now engage.My question is: Would the set screw be restricted to tighten all the way to the shaft in order to prevent a stripped plastic gear in the event of a crash? I wonder if it was manufactured like that and I have now caused a bigger problem.
    Oct 2014
    33
    Re: DM2400 motor gears
    I reread this and it wasn't clear. Obviously the set screw would have to be tight enough to engage the shaft. What I meant was the set screw would contact shaft only enough to allow it to shear in the event of a crash, thus saving the plastic 100 tooth gear.
    Nov 2009
    4415
    No the gear would need to be tight to the steppers shaft. If the gears breaks, so be it.
    A lazy man does it twice.
  1. DM2400 Spindle Motor
    By Go65 in forum Dyna Mechtronics
    Last Post: 12-30-2017, 08:42 PM
  2. DM2400 won't run
    By dustin033 in forum Benchtop Machines
    Last Post: 07-01-2013, 04:19 AM
  3. Connectiong Bob-Cad/CAM to a DM2400?
    By tomcat in forum BobCad-Cam
    Last Post: 10-02-2010, 10:16 PM
  4. dm2400 / dm3000
    By willyh in forum Benchtop Machines
    Last Post: 09-18-2010, 09:44 PM
  5. need to size motor, gears etc.
    By Timbersmith in forum Mechanical Calculations/Engineering Design
    Last Post: 01-06-2009, 07:27 AM
