585,573 active members*
3,402 visitors online*
    Oct 2014
    33
    DM2400 Power Switch
    I am working on the electronics cabinet on my Dyna and found an issue with the power switch. It is barely held in by a small brass screw that will not last very long under use. The switch is an EAO 704.960.0 with a 704.900.3 module. This type of unit is usually mounted in a round hole (22MM or 30MM don't remember) but the hole in the Dyna is rectangular 22mm X 28MM. I think this was a replacement switch with parts available on the shelf. Can any one tell me what switches are on their machines so I can get a replacement that fits. I would like to know brand, model and whether it is lighted? The ones I have found on line look like they are light duty and only 2 or 3 lugs.
    Thanks.
    Feb 2007
    4553
    Re: DM2400 Power Switch
    Eaton makes decent switches rocker switches, see attached link
    http://www.newark.com/eaton/2600hr11...ecSingleItem_2
    SpecificationsType:Rocker Switch
    Circuit Configuration:DPST
    Circuit Operation:On-Off (maintained)
    Amps/12-125Vac:22A/125VAC
    Amps/250V:16A/250V AC
    Horsepower:1 Hp/125-250Vac
    Voltage:250V AC
    Terminals:Quick Connect Tab .25 in.
    Finish:Red
    Mounting Type:Snap-In
    Mounting Dimensions:Nominal LxW: 1.075x0.876 in (27.3x22.2 mm), Panel Thickness: 0.030-0.118 in (0.75-3 mm)
    Temperature Range:32° to 185°F (0° to 85°C)
    Manufacturer Series:2600 Series
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. power trip when switch on servo
    By Syphonics in forum Servo Motors / Drives
    Last Post: 03-24-2016, 01:49 PM
  2. Wiring power and e-stop switch
    By henrikm in forum CNC Machine Related Electronics
    Last Post: 03-04-2012, 08:59 PM
  3. Power supply switch
    By ellasaro in forum CNC Machine Related Electronics
    Last Post: 07-20-2011, 12:37 PM
  4. G201X power switch
    By crochambeau in forum Gecko Drives
    Last Post: 04-18-2010, 04:22 PM
  5. Power switch
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2005, 02:39 PM
