Re: DM2400 Power Switch
Eaton makes decent switches rocker switches, see attached link
http://www.newark.com/eaton/2600hr11...ecSingleItem_2
SpecificationsType:Rocker Switch
Circuit Configuration:DPST
Circuit Operation:On-Off (maintained)
Amps/12-125Vac:22A/125VAC
Amps/250V:16A/250V AC
Horsepower:1 Hp/125-250Vac
Voltage:250V AC
Terminals:Quick Connect Tab .25 in.
Finish:Red
Mounting Type:Snap-In
Mounting Dimensions:Nominal LxW: 1.075x0.876 in (27.3x22.2 mm), Panel Thickness: 0.030-0.118 in (0.75-3 mm)
Temperature Range:32° to 185°F (0° to 85°C)
Manufacturer Series:2600 Series
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
