I see there is another recent thread on moving a VM16 and this is probably similar. I need to get this through 52" wide door (concrete and brick building so enlarging the door isn't going to happen) so I am looking at some serious disassembly. Of course the cabinet has to come off. Looks like it is held together with rivets that can be drilled out. Plan to remove the tool changer. Not sure what the width will be then and may have to remove more. Thinking an engine hoist to lift the tool changer for removal. Used a roll back wrecker to move a lathe but it was much less weight. Not sure yet if we may tackle this or hire someone to move the main piece. Any suggestions are welcome.
