Greetings,
i have a set of FALDIC RYS201S3-LPS Servo Drive and GYS201DC1-SA Motor.
powered by 220VAC at L1 and L2
motor cables are as follows:
red = U
white = V
blue = W
green/yellow = drive ground
encoder usb is plugged into the servo drive
the problem is i am unable to make the motor jog from the drive. i want to use this drive with mach 3 for an project. when drive turned on it says = boF and motor spindle is free all the time.
when i try to jog by going into Fn001 - JOG - keep pressing enter again for command confirmation, and when i press up/down arrow, it shows negative and positive moments but motor does not engages at all and also spindle does not move.
another thing is when i turn on the drive and after few moments when i rotate the shaft of the motor, i see a dot blinks on the left top side which indicates that the encoder is working.
i have tried to search online about this model and i couldn't found anything other than the manual. i am just a beginner about the CNC stuff and dont know much about the electronics. HELP PLEASE!
