585,981 active members*
4,288 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Stepper motor makes chirp noise after jog, then g540 faults
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Re: Stepper motor makes chirp noise after jog, then g540 faults
    Perhaps some bad ground loop in your electrical system?
    Try plugging everything in to a different electrical circuit.
  2. #22
    Nov 2017
    591
    Do you mean a different ac source? The 2 different computers I tried are in different rooms on different circuits. In both cases the computer and power supply were on the same circuit. Should I try putting them on separate circuits? That just creates a ground loop right?
    As for the dc wiring, all I had hooked up was a single positive and negative from power supply to g540 and 1 to 4 motors plugged in. Tried with just a loop from 10 to 12 for e stop, also tried putting g540 and power supply into its sheet metal enclosure with actual e stop wired up, also tried with motors bolted to machine.
    I don't fully understand how ground loops work, but what if I use a power inverter hooked to a battery to power my computer, then power the g540 power supply from the wall? Would that eliminate a ground loop that I may or may not have? I have an inverter if you think that's worth trying
  3. #23
    Nov 2017
    591
    Well, whether or not it's relevant, I tried plugging the power supply into my inverter/battery so that the computer and g540 are only grounded together through the usb. Made no difference.
  4. #24
    Mar 2006
    233
    Are there any updates to this problem? I bought my G540 about 3 years ago (REV 8) and just today got it plugged in testing. I have the EXACT same chirping issue and white noise. I have tried all of the settings described above including speeds and trim pot. I have even plugged the stepper straight into the g540 and there is zero change.
    My setup is identical with a genuine UC100 (not a knockoff). Ideas?
Page 2 of 2 12
  1. Z-Axis Motor Makes Clunking Noise
    By CH33 in forum Gecko Drives
    Last Post: 12-14-2017, 01:05 PM
  2. Stepper Motor doesn't spin but makes noise
    By Finder in forum Stepper Motors / Drives
    Last Post: 07-21-2016, 03:23 AM
  3. MACH 3/Gecko G540 Stepper motor hesitation - VFD Noise?
    By GeoffDuniam in forum Gecko Drives
    Last Post: 02-27-2015, 05:49 PM
  4. What company makes great but cheap stepper motor?
    By aaronwelder in forum Stepper Motors / Drives
    Last Post: 01-25-2009, 12:53 AM
