585,927 active members*
3,894 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Separate nc file for each operation
    Jan 2017
    4
    Hi guys
    Is it possible to automatically generate separate nc file for each operation?
    As you can see on the screen there is a couple of operations on each sheet.
    Please help.
    Re: Separate nc file for each operation
    Just turn off all but the ones you want, and export the .nc files.
    Jan 2017
    4
    Hi ger21
    Thx for fast reply. Your right. But for me it's difficult because sometimes I have 20-30 operations on each sheet. For now i'm generating one file witch all ops and then manually separating them to each file. It's realy time consuming.
    May 2011
    108
    Hi, Not sure what You are trying to do? Can You please explain a little bit clearer?
    Apr 2015
    327
    Quote Originally Posted by HotAndCold View Post
    Hi guys
    Please help.
    Yes,
    you can create some simple VBA macro for this. Or if you want output only sheet by sheet it is possible by using Alphacam function split nested sheet, but this need some postprocessor changes (if you have not it).
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. Replies: 2
    Last Post: 10-17-2017, 02:36 PM
  2. Replies: 2
    Last Post: 10-07-2014, 06:16 AM
  3. Sprutcam drilling operation on a DXF file
    By CNC-Dude in forum SprutCAM
    Last Post: 10-04-2012, 04:15 AM
  4. Separate GCode
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-07-2010, 06:16 PM
  5. Separate 24V DC supplies
    By interflexo in forum CNC Machine Related Electronics
    Last Post: 09-03-2006, 09:48 PM
