585,728 active members*
4,120 visitors online*
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Oct 2005
    1145
    Re: Slave axis all of sudden not working
    Mach3 is FAMOUS for corrupting teh XML file. Load a KNOWN good copy of the XML and see if that does not correct your problem.
    (;-) TP
  2. #22
    Mar 2012
    54
    After checking the step and dir pins....all other pins switched between 0-5v on the dir and com pins. When checking the dir and com pins for 9 it was switching between 3.5v - 5v. Unlike the other pins it never went from 0-5v. Any idea why it would do this?
  3. #23
    Mar 2012
    54
    also when I swap pins 8 & 9 neither function works....up or down? Would this help narrow the problem down?
  4. #24
    Mar 2012
    54
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    What is the XML file? I started using a new computer where I downloaded a whole new file of Mach3....would that have uploaded a new XML
  5. #25
    Mar 2012
    54
    I am concidering just connecting a gecko g540 to rule out all the electronics I currently use. Would this be a bad idea? Just pretty desperate to figure it out.
  6. #26
    Mar 2007
    2083
    going back to posts 22 & 23
    did you disconnect the stepper driver from the common & pin 9 BOB connections ?
    with the pin 9 output only switching between 3.5 V and 5v instead of 0 to 5V
    its possible that a short circuit in the wiring between the C10 and stepper driver input could of damaged one of the 74ACT245 IC's
    one bonus with the old style C10 is the IC's are all in sockets and can easily be replaced
    as the C10 has four 74ACT245 IC's you could swap the IC for pins 6 to 9 with the one for pins 2 to 5
    if the fault moves to pins 4 & 5 you will know you have a damaged 74ACT245
    are you using pins 1 , 14 ,16 & 17 ?
    John
    PS
    IC location & and function
Name:	C10 rev10 IC location.jpg
    PPS
    before you buy the G540
    I would replace the gender changer on the printer cable or buy a printer cable with 25 plugs at both ends
    as it appears to be the only thing you have not changed
  7. #27
    Oct 2005
    1145
    The XML is Mach3's configuration file. A corrupt file can easily disconnect your slaving settings in mach3. I used to fight this all teh time with a plasma machine.
    Did this happen one day you shut down Mach3 and all was working correctly and the next day started Mach3 and you lost slaving ? (;-)
    (;-) TP
  8. #28
    Mar 2012
    54
    Yes, one day was working fine and the next day would not work? If I downloaded a new version should that have fixed it?
  9. #29
    Mar 2007
    2083
    when you downloaded & installed a new copy of mach did you manually enter the printer port address and assign pins 2 to 9
    or did you copy & paste what may of been a corrupt of your XMLfile ???
    John
  10. #30
    Mar 2012
    54
    Yes I assigned the pins numbers.
  11. #31
    Mar 2012
    54
    Hi John,
    I only swapped the placement of the wires at pins 8&9 on the board and on the system. Should I have just disconnected one or the other? Also should I make the changes in Mach 3 inputs/outputs when I swap them around on the board? Sorry if this is confusing.
  12. #32
    Mar 2007
    2083
    from post 22
    "After checking the step and dir pins....all other pins switched between 0-5v on the dir and com pins. When checking the dir and com pins for 9 it was switching between 3.5v - 5v. Unlike the other pins it never went from 0-5v. Any idea why it would do this? "
    Did you measure the voltage between com & pin 9 with the BOB still connected to the stepper driver input ??
    the abnormal voltage indicates the 74ACT245 on the BOB could be damaged
    but a fault with the stepper driver wiring over loading the BOB is another possibility
    disconnecting the common , pin 8 & 9 and re testing will help to narrow down the fault
    depending on the result
    swapping the 74ACT245 IC that is connected to printer port pins 6 to 9 is another test - see post 26
    John
Page 2 of 2 12
  1. CNC3040T-DJ X axis sudden drift
    By erdabyz in forum Chinese Machines
    Last Post: 09-22-2017, 09:13 PM
  2. Sudden Y axis problem
    By tcorder in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-04-2017, 12:43 AM
  3. Z axis problem all of a sudden
    By SplintersWood in forum DIY CNC Router Table Machines
    Last Post: 12-03-2015, 10:20 PM
  4. X Axis loosing steps all of a sudden
    By Wdwkr53 in forum Mach Mill
    Last Post: 07-12-2014, 12:40 AM
  5. Strange problem with moving X axis all of a sudden
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-27-2013, 10:24 PM
