585,973 active members*
4,104 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > A few VFD wiring questions....
Page 1 of 3 123
Results 1 to 20 of 41
    Mar 2017
    926
    Believe it or not, the instructions manual for PDS spindles is even worse than the ones for Chinese VFDs. They are literally useless. So... I will be eternally greatful if someone could answer these 4 questions for me (seriously, if you need one of my kidneys, it's yours if you help me out on this!):
    - Where do you connect the neutral wire from a 3 pin plug on a Huanyang VFD? The video I saw just showed two hot wires connected with no visible neutral. Do you just leave the middle wire from the plug not connected to anything?
    - What does the ground wire connect to? There is a ground wire connected to the left of the two 220v in wires in the video I saw. The guy said it was connected to his "cabinet ground". WTF is that? Is this another part I need to purchase? I've wired up tons of electronics and have never once had to connect a ground wire to a seperate device. There was always a ground pin on the thing I was wiring if it was required... There is no exposed metal on my frame and I wasn't planning on using a metal cabinet.
    There is no obvious place to attach a ground wire on my spindle either. There is just screw terminals for the 3 power legs:
    The red and blue wire is for the 24v fan. There is nothing there lablled ground.... everyone acts as though this requires no explanation. maybe some of you were born with this knowledge but I wasn't so lucky. I need it spelled out in plain English.
    - What (if anything) do I connect to "U2, V2 and W2" in my spindle connection box? I can see the U, V, M pins on the VFD but there is one set of power pins on the VFD and 2 sets on the spindle (I.e. There is U1, U2, V1, V2, W1 and W2). Do I connect U on the VFD to both U1 and U2 on the spindle or just to U1?
    - Assuming I plan to control the spindle from the VFD to start with (I just want to test it for now), are there any other essential wires I need to connect aside from the 220v in, the U, V, W to U, V, W VFD to spindle power and the 24v for the fan?
    Connecting a few wires from screw terminal to screw terminal should be a 5 minute job once I can answer these questions.... out of a 50 page instruction manual, all PDS provided on wiring was this image which means nothing to me:
    There is a computer graphic of this image in the manual without a single word of explanation. Now... you might look at that and find that everything becomes clear but I literally felt like crying when I saw that this was all there was and I haven't cried since 1984.... please help!
    15362
    Re: A few VFD wiring questions....
    Quote Originally Posted by Goemon View Post
    Look at the first photo, it clearly shows you where the Ground connection is, left hand top corner, silver screw with a Ground symbol next to it, you sure you should be doing this
    It looks like it is connected for 220v Delta connection
    Mactec54
    24221
    It looks to me as though it is already connected in Delta, (lower voltage), Star is for the higher voltage rating.
    Star = L.H. in the pic and Delta = R.H.. Picture as shown.
    I see Someone changed his mind to 220v Delta !!!
    Al.
    Albert E.
    15362
    Al.
    Yes that is correct it is in Delta ready for 220v
    Mactec54
    There is no neutral wire used. Neutral in the US if only for 120V.
    The two sets are tied together, so you can connect it to either one. I'd connect them to the side where the wire enters the box.
    These products are meant to be installed by professionals. Anyone requiring step by step instructions should hire someone that knows what they are doing.
    ericks Guest
    U1 and U2 are not tied together
    ericks Guest
    I agree with you Gerry...he should get someone to help him!
    Quote Originally Posted by ericks View Post
    I fixed my post. I should actually look at the pics before posting.
    ericks Guest
    Markings on that terminal block are not very clear. Gerry, do you know the make of this motor?
    15362
    It is a PDS Spindle 220v /380v
    Mactec54
    ericks Guest
    Thank you.....do you have any experience with these spindles? Are they any good?
    PDS I think?
    15362
    I have never repaired one, have installed similar spindles, there are a lot of different manufactures of this style spindle, they all seem to have a good life and the quality in general is pretty good, that goes with the price as well, most Hobby users won't be buying an $1800 dollar spindle, that could have a life, just the same as a $300 spindle
    Mactec54
    ericks Guest
    Yes that price is a bit high
    Mar 2017
    926
    Al.
    PDS asked me if I wanted it set up for 220v or 380v before they sent it as it's a dual voltage spindle. I said 220v.
    ericks Guest
    What drive are you using with this motor?
    Mar 2017
    926
    "Clearly" if you know that symbol means ground.... I assume you weren't born with that knowledge so at some point, someone helped you. I've had to wire ground pins before but I have never seen that symbol before. I have always just followed instructions like "pin 1 on this board connects to pin 11 on that one" etc.
    Believe me, I don't want to be doing this. I hate wiring things and I don't think they should make it so you have to. They should agree a standard and this should be as simple as connected a cable like it is for computers, TV's and a whole lot of other appliances but it is what it is. My electrician has no more insight into how to wire a VFD than I do. He would be stuck with those same Chinese instructions....
    So... it's either wire it myself or give up and I have no intention of giving up.
    Does the ground pin on the spindle connect directly to the ground pin on the far left of of the Huanyang VFD?
    What about my other questions? I.e. Which of the 6 power connection screws on my spindle are connected to the 3 on the VFD?
    I need all these answers if you want that kidney.
    Mar 2017
    926
    I'm using a Huanyang VFD (until I can get a better one).
    ericks Guest
    You seem to have a good quality spindle....if possible you should match it with a descent drive
Page 1 of 3 123
  1. is this wiring correct? + have 2 questions...
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-31-2012, 12:32 AM
  2. Encoder Wiring Questions
    By bill south in forum Servo Motors / Drives
    Last Post: 07-16-2009, 07:29 PM
  3. More questions on wiring. :)
    By bkboggy in forum DIY CNC Router Table Machines
    Last Post: 04-10-2009, 05:12 AM
  4. Questions about wiring
    By Phife in forum CNC Machine Related Electronics
    Last Post: 04-05-2009, 07:40 AM
  5. Wiring Questions
    By cnc2k in forum CNC Machine Related Electronics
    Last Post: 11-28-2004, 12:45 AM
