585,933 active members*
3,947 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Dec 2017
    22
    Mach4+ESS or Acorn?
    I'm still in the process of designing and building the new machine. Ive decided to lower my expectations on its scope of work to not include steel of any kind, so I'm using 8020 extrusions for the whole frame and gantry. X and Y will both be 1300mm working area, with 1700mm 25mm rails, leaving room for a tool change fixture on one side, and fixtures/vice on one end.
    Anyway, while reading and watching videos about my DMM servos, I came across the Acorn CNC controller. I'm used to Mach 3/4, but I'm not that attached to it yet to not be willing to switch. Cost wise, the Acorn seems like it might be a bit cheaper, though that isnt a factor, than a Mach 4 license and an ESS.
    What I really want to know is if anyone has used both products, if you would recommend one over the other? I'm a little on the disappointed side on how long its taking for plugins and updates for mach 4, and more than a little worried that it might get dropped like Mach3 was since its not being widely adopted.
    Re: Mach4+ESS or Acorn?
    Not sure what you mean by "dropped"? Mach4 is the replacement for Mach3. Mach3 became too complex to develop further, so Mach4 needed to be written from scratch.
    OEM customers are keeping Artsoft in business, from what I understand. My guess is that they still sell more Mach3 licenses than Mach4 licenses.
    As for the Acorn, do your research, and make sure it'll do what you need. I know a few people using them, and have heard that it still needs some work to be a good fit for router users, but they are working on it.
    I'm building a router using DMM servos, and am running UCCNC with a UC300ETH and UB1 breakout board. I've had a Mach4 license for 3 years, but have no plans on using it.
    Dec 2017
    22
    This is absolutely true, and the fact that it isn't even being updated anymore bothers me. I started with mach 3 when I bought my machine, but it was glitching and not running properly and I couldn't get anywhere with troubleshooting it so I bought mach 4. It's run fine for me, though I still have a lot of issues I havent managed to figure out. (like while auto Z touch plate macro will randomly go UP instead of down after its initial touch off... no idea why)
    And by "dropped" I mean, they still sell the software, but dont support it any longer. its stagnating. people still use it, new hardware and plugins are being made around it still, but they aren't updating it to fix issues. Plugins are extremely slow to come for mach 4, and anything like that is far outside of my skillset to make myself.
    To what I want it to do, simply a 4 axis wood router. and in a year I plan on switching the spindle for an ATC setup, which from what ive read is a whole new can of worms with Mach 4, though I haven't gone so far as to start doing any work on that yet, as the new machine is just parts in my garage right now. Im reading up on acorn on these forums right now, and the reviews are mixed so far. It looks like it would probably be perfect for my needs on paper, but so far what ive seen is mostly customer support issues rather than actual usage reviews.
    Sep 2012
    228
    I will tell you this..
    I am running a machine with an ATC Spindle...
    So for me ACORN is out of the questions...
    I was considering it for a simpler machine, but I noticed on major drawback...
    I might be wrong.. but the ACORN board has limited inputs and outputs...
    Thought the CNC Ver12 software may be the same/similar across all controllers, it seems like you have to buy upgrade "plug-ins" for certain functions.
    With there being no way to expand on the inputs/outputs.. the Acorn will work great on simpler machines.. but be limited on a more developed one.
    Mach 3 was limited too.. but if you added a second BOB you increased your inputs/outputs.
    Centroid seems like a very solid company.. but the OAK board is like $1800 to implement more features.
    I feel like they need an ACORN 2.. with expansion ability.
    and the fact that it isn't even being updated anymore bothers me....................new hardware and plugins are being made around it still, but they aren't updating it to fix issues
    Because many of the features in Mach3 were not taken into account when it was originally developed, many of them affected other features. So when a bug in one feature was fixed, it usually broke some other feature. THere was no way to move forward with Mach3, without a complete re-write, which is Mach4.
    Centroid has there own Acorn forum, where you can follow it's development, and see the questions that users are asking.
    Dec 2017
    22
    I understand Why they moved to the new software, that is not my point. the point is that it was dropped, and not without reason. I didn't really think I was going to get an argument on a forum like this.. from a moderator no less? You're absolutely right, I should start my research somewhere else.
    Jun 2005
    1730
    I have Mach4+ESS and the Centroid Acorn on two identical machines.
    They both work fine, but I have run Mach3 for 15+ years or more, started when it came out
    The Mach4 screen set is very nice and motion with ESS is smooth. Have not cut large project on it yet so I am not positive if any of the bugs from Mach3 followed.
    Acorn is a nice package and I have cut several aluminum parts and it works great. What I like is it never does something unexpected. It is currently I/O limited to 8 inputs and 8 outputs + 4 drive outputs. They are working on an option to add addition digital and analog I/O expected in a couple months. They are also adding router user features to make many tasks easier.
    Price has gone up to $325 +. $125 for their professional software upgrade, but bottom line is it is a nice package with touch screen support
    Russ
    Jun 2015
    943
    You can get a UC300ETH with lots of I/Os and can use it with Mach3, Mach4 or UCCNC but my recommendation is UCCNC, because it is superior to Mach3 but i don't know much about mach4.
    I'm using UCCNC on 2 machines without issues for around 1.5-2 years
    Jun 2017
    11
    I used Mach4, switched to Acorn and I’m glad I did. Since switching to acorn I haven’t had a single crash. With Mach4/hicon sometimes it would do weird things like not wait for a manual tool change one time and other times it would. Adding external controls like a cycle start button in Mach4 required some programming in LUA (which I’m not familiar with) but not the case with the acorn. You are limited to 4 axis with acorn which works fine for my mill. I’m not sure how acorn will work on a router table but has worked well for my mill. My biggest compliment for the acorn board is that I can trust it. The conversational programming on the acorn is nice too if you’re into that.
    Jun 2015
    943
    I did similar, I switched from Mach3 to UCCNC and I'm glad I did it. No crashes since then.
    It works nicely on my plasma and also on my router.
    I'm not arguing, just pointing out why Mach3 is unsupported. They simply can't, because they can't fix the problems with it.
    Imo, they really shouldn't be selling it at all, but they have to to stay in business.
    Not good for a company when your discontinued product is far more popular than your current one.
    I was a big Mach3 supporter for a long time, but there were enough issues with mach4 to force me to move in a different direction. In it's current state, I just don't see Mach4 ever becoming very popular in the hobby market.
    By all accounts, the Acorn is possibly the best "hobby" control available, but I think it's a bit too limited for a lot of router users.
    Good luck in your decision.
    Dec 2017
    22
    Thanks for your input everyone. Those were the types of answers I was looking for. I dont need it right away, so I'll wait and see what they come out with for the extra I/O, since I would like to run a 5 and 6 axis (Y is dual motor, so 4 and 5 actually) in the future. Even if they dont upgrade its capabilities I will likely go with it anyway, but positive reviews were what I was looking for
    May 2005
    3920
    Just to be clear these are personal opinions not arguments!!!
    First off i wouldn't go with either Mach option right now, in part for some of the reasons you point out. From all appearances Mach 4 isn't stable and Mach 3 well being left adrift isn't good.
    As for the Acorn it is an extremely good value from Centroid a company that has been doing CNC for decades! Do consider though if a proprietary package that only runs on Windows 10 is acceptable. The reports from actual users though are glowing so i see that as a sign of well debugged and stable software. Also consider that this product is sold with limited support vs what you might get with a full blown CNC from Centroid.
    Now if you are considering controllers and have the time why not look at all of the low cost options? LinuxCNC, GRBL and many others exist that might be worth considering. You can even buy Chinese CNC solutions that emulate FANUC type controllers.
    Do realize that once you go beyond four axises complexity goes up significantly. Some controllers simply cant handle more than 4 and your CAM software gets far more complex and expensive.
    Quote Originally Posted by HoY View Post
    Dec 2017
    22
    All very good points, thank you! I only started considering something other than Mach+ESS while watching a setup video for Acorn+DMM servo's yesterday, and it looked like it was a very good looking and all in one alternative.
    CAD+CAM, all of my normal 2D+2.5D and third axis turning should be easy enough to handle in Aspire, while the 5 axis stuff would all be done in Fusion 360, which is more than capable of handling it. That extra axis is just a plan for the future however, so I have lots of time to learn to use F360 before I will need it. By then I might actually have the Tormach 770, and would likely just do that type of work on it instead.
    Oct 2011
    33
    mycnc_price_list [myCNC Online Documentation]
    I have four machines with different control systems. Linuxcnc, mach3, UCCNC and MyCNC , MyCNC is the best for me...
    Mar 2017
    926
    I keep looking at those Acorn boards because someone on a composites forum recommended them to me but I am finding it hard to see the advantage over using a pure software solution with a high spec pc. I can see that they have built in relays to control peripheral functions which is nice but what else do they offer above and beyond Linux CNC and a good desktop pc with fast solid states drives and plenty of ram?
    Can't you just add your own relay outputs with a PCI express relay control card instead?
    Is it that the Acorn control software is just superior to Mach 3 and Linux CNC and the only way to access it is with a dedicated control board as they don't sell it as a software only solution? Or is there more to it?
    Jun 2005
    1730
    Goemon,
    The big advantage with the Acorn board is it uses the same software that their more expensive controls and even their own 5 axis CNC machines use. So what? Well this tells the user base the software has been tested for many years and has been refined over many years. Mach3 was a great hobby platform which actually did an amazing job of introducing CNC software to hobby guys. The Mach3 developer sold off the product and it was redeveloped as Mach4. This is probably better but still have many bugs and lacks drivers. The advantage of the Acorn is it uses their Hardware and their Software. The analogy I would use is the Windows PC platform had to support many different kinds of hardware and often has many bugs due to this issue. Compare that to the Apple PC platform which used their hardware, their peripherals, and their software, so it was extremely solid.
    The Acorn takes the bulk of intensive calculations on their Acorn controller, Windows us just doing the screen, not the pulsing work.
    Russ
    Quote Originally Posted by Goemon View Post
    Oct 2018
    20
    So it takes 3 programs to actually make it all work? My cabinet solutions to design and send the cut list to the next program (v-carve recommended by Avidand, enroute recommended by cabinet solutions, then mach 4 or similar to run the machine?
    Depends on the programs. There are cabinet programs that can generate g-code themselves.
    But you'll still need a machine control program.
    15362
    You don't need an extra axes port to run ( 2 ) motors for your Y axes you can use ( 1 ) axes port if you need one motor to run in reverse to the other then you wire it to do that, it is very simple look at the Dmm Breakout Board they have this all ready set up, there's is built into the board, have conveniently added ( 2 ) X axes Plugs which is supplied with ( 1 ) step / Dir signal, with the Acorn you can do the same just does not have the extra convent axes plug
    Mactec54
Page 1 of 2 12
  1. My Experience with Centroid Acorn
    By SCzEngrgGroup in forum Centroid CNC Control Products
    Last Post: 05-04-2018, 02:15 AM
  2. Centroid Acorn interview
    By bgriggs in forum Centroid CNC Control Products
    Last Post: 01-18-2018, 08:19 PM
  3. Acorn on a D&M4 Benchtop CNC Mill
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 08-09-2017, 02:26 PM
  4. Those interested in ACORN
    Last Post: 08-09-2017, 02:23 PM
  5. Acorn Thread Dies
    By chelclock in forum Want To Buy...Need help!
    Last Post: 07-26-2010, 05:49 PM
