585,978 active members*
4,297 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > Diamond Drag simulation barely shows up.
    Dec 2015
    37
    I am attempting to use the Diamond Drag tool for an engraving toolpath in Cut2D but when I run the simulation it barely shows up in the material. I have tried different depths and still does not improve.
    Can anyone tell me how to get this to work better. Would really appreciate it.
    Apr 2003
    540
    Re: Diamond Drag simulation barely shows up.
    It depends on your drag cutter. Does it have a spring that provides the downward tension on the tip to metal? Some have a adjustment, others you change the spring. In any event your engraving tip should be below zero or negative an amount that allows the required spring pressure at the engraving tip when it's dragging.
    Mar 2004
    413
    Quote Originally Posted by nodott View Post
    Are you setting any depth in the tool path ? Usually, when using a spring loaded spindle, one would not set any depth, and allow the depth or pressure to be put down based on your Z zero location.
    In this case however, Cut2d will not show the tool actually touching anything. So, what I do is set all the drag tool paths to be .001" depth, then set a color to the tool path. This way, it will show up in the preview.
    You can also play with the tool diameters, as this will also affect how the preview will look in comparison to the actual finished product. For drag work, I will set the tool to be .002" regardless of what the actual width will be, simply because the pressure will dictate depth on the machine.
    Chris L
    Dec 2015
    37
    Quote Originally Posted by datac View Post
    Yes I have been setting the depth. I even tried a ridiculous depth of .125 and even changed the color but it still barely shows up in the simulation. I do not have this problem when I change it to an engraving bit.
    on a side note I even tried the feature Use Nose Cone and that still did not improve the simulation results.
    I will play with the widths as you suggested and see if that improves the simulation results.
  1. Diamond drag engraving
    By nutzilla in forum Tormach Personal CNC Mill
    Last Post: 08-03-2016, 05:41 PM
  2. A Little 4th Axis Diamond Drag Engraving
    By pickled in forum Tormach Personal CNC Mill
    Last Post: 06-29-2015, 02:01 AM
  3. In simulation it shows round but on machine it shows polyline please help
    By amritsingh in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-18-2015, 10:28 PM
  4. Tormach diamond drag engraver
    By zaebis in forum Tormach Personal CNC Mill
    Last Post: 09-14-2013, 10:14 PM
  5. Diamond Drag info needed. Looking to buy.
    By ibuildstuff4u in forum Benchtop Machines
    Last Post: 11-02-2009, 06:45 AM
