585,933 active members*
3,837 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Sieg C2A mini lathe - gearbox making squeaking/ grinding noise
    Oct 2010
    62
    Hello, I've got a SIeg C2A mini lathe which I've been using on and off for a few years. Today she started making a horrid grinding/ squeaking noise every few seconds or so at irregular intervals.
    Here's a link to a video I took of the problem - link
    I took off the gearbox cover so that I could see the gears moving. Everything seemed to look okay, plenty of grease, the gears didnt look worn out and all the bolts are tight.
    The smallest gear that is in the middle of the gear arrangement had a little bit of play back and forth along its axle, I am not sure if this is normal or not.
    Any help resolving this issue would be much appreciated.
    Jack
    Sep 2006
    509
    Re: Sieg C2A mini lathe - gearbox making squeaking/ grinding noise
    video link not working for me
    Feb 2008
    521
    As they don't have a 'gearbox' to speak of - just a gear array, each of which is either fixed to a shaft or idles around one, any noise should be obvious with machine running and case door open.
    But I suspect it is more likely a bearing on the spindle has gone bad / broken.............upgrade time!
    Oct 2010
    62
    Whoops, okay, try this link to Vimeo -
    Sep 2006
    509
    I'd try the divide and conquer approach. take out a gear in the middle of the drive train, is there still a noise? Yes, take out gears further up until it goes away, No, put it back in and move further down the gear train and take out another gear, check. repeat until problem is found.
    Also, hard to tell but seems from the video its once per rev of the output to the lead screw. Any loads on it?
    Mike
  1. Replies: 7
    Last Post: 08-14-2020, 02:13 PM
  2. Replies: 3
    Last Post: 05-24-2019, 07:43 PM
  3. Spindle making grinding/humming noise
    By machinisto in forum Haas Mills
    Last Post: 10-21-2014, 09:05 PM
  4. Mini Lathe quick change gearbox
    By trixter in forum Mini Lathe
    Last Post: 02-19-2009, 11:23 PM
