585,759 active members*
4,083 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Good Place to Order Timing Belts and Pulleys?
Results 1 to 9 of 9
    Mar 2005
    10
    I am building an approximately 30"x30" CNC Router with two 1610 ballscrews on the Y-Axis.
    Attachment 386152
    I want to drive the 2 ballscrews with a single NEMA34 motor via a timing belt.
    Where do most of you get your timing belts and pulleys here in the U.S.?
    Wallace
    Re: Good Place to Order Timing Belts and Pulleys?
    bbman.com
    24220
    Local Bearing supply house.
    Or Misumi USA.
    Al.
    Albert E.
    Mar 2008
    683
    Good Ol' McMaster Carr. They carry just about everything. mcmaster.com
    Dec 2013
    5717
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2003
    540
    I use this place. Best prices I can find and have never been disappointed with belts.
    Polytech Design Inc. Industrial Timing Belts & Pulleys Polytech Design Inc Clifton NJ 07011
    Mar 2005
    10
    Thanks for the info!
    I'm going to start out by trying some of our Chinese friends on eBay:
    http://stores.ebay.com/fivefive-co-l...ub=13520880017
    I'll have to wait for Chinese New Year, but I have plenty of other stuff to do. If that doesn't work out I have saved a handful of good links from above.
    Thanks again,
    Wallace
    Oct 2004
    178
    you might also try Automation Direct. I know they have timing pulleys and belts, I just aren't sure of the selection. Got CRS ( can't remember ****!) Sorry
    May 2005
    3920
    There are many options here.
    Try Amazon, a few years ago they bought out an industrial supplier so they do have a range of automation hardware
    Next these guys are specialist in small parts: Small Mechanical Components: Precision Gears, Gear Assemblies, Timing Belts, Timing Belt Pulleys, Couplings, Bearings and much more - SDP/SI
    Mc Master - Carr
    MSC
    www,grainger.com
    Your local bearing supply house such as Kaman Industrial Technologies, https://www.applied.com/categories/c/0, Industrial Bearing Distributors - Addison, Illinois - Bearings & Industrial Supply Co., Inc. and others.
  1. Timing belts and pulleys suppliers that I can order online from?
    By v0idnull in forum Linear and Rotary Motion
    Last Post: 01-07-2019, 05:34 PM
  2. Where are you getting your timing belts/pulleys?
    By Wallybanger in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2014, 09:54 PM
  3. Where is a good place to get pulleys and belts for servos
    By Ed Williams in forum Servo Motors / Drives
    Last Post: 04-17-2006, 02:42 PM
  4. Timing Belts and Pulleys
    By Gorillakilla in forum Mechanical Calculations/Engineering Design
    Last Post: 03-12-2006, 06:19 PM
  5. What pulleys and timing belts do I buy from sdp-si???
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 12-05-2005, 12:06 PM
