585,949 active members*
4,129 visitors online*
    Mar 2005
    137
    linuxcnc kinematics design
    Hi guys,
    i'm beginning with linuxcnc kinematics, and i was wondering what CAD was compatible/people use/recommend ?
    thank you
    Oct 2010
    156
    Re: linuxcnc kinematics design
    I use QCAD. QCAD.org
    I'm sure others have their favorites...
    Mar 2005
    137
    Quote Originally Posted by urbnsr View Post
    thanks for the reply,
    from my understanding this qcad works with 2d/3d axis, kinematic uses 3 axis + 3 joint (robot arm). it unclear to me how it works. could you clarify ?
    May 2015
    686
    My understanding is that the Kinematics converts normal 3D moves to the motion required to move the robot arm to a given XYZ coordinate so its not so much of a problem. Granted additional joints allow angles to be selected. Some info here
    http://alvarestech.com/temp/RoboAsea...al-robot-2.pdf
    The Linuxcnc forum would be the place to ask for help on this topic.
    https://forum.linuxcnc.org/
    Rod Webster
    www.vehiclemods.net.au
    Mar 2005
    137
    Quote Originally Posted by rodw View Post
    So I could take a 3d cad and just plug and play as usual with cool thanks
  1. kinematics
    By Hailman in forum Hardinge Lathes
    Last Post: 02-23-2015, 03:10 PM
  2. Parallel kinematics CNC Project
    By Mikee3man in forum Linear and Rotary Motion
    Last Post: 03-13-2014, 06:27 AM
  3. Paralle Kinematics
    By chuckknigh in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-24-2006, 09:43 PM
  4. Kinematics in EMC
    By fer_mayrl in forum LinuxCNC (formerly EMC2)
    Last Post: 03-10-2006, 06:54 PM
  5. More on Toolpath Kinematics Consipracy
    By CNCMP in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-30-2004, 05:31 PM
