585,758 active members*
4,317 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > USA Club House > I bought a 6560 board and motors getting burning hot
    Oct 2012
    I bought this board, a 6560 3 Axis board.
    I put 12 volt supply and tested it with only 1 nema17 motor on the X axis.
    the jumpers on the board are set to the lowest current, 20%, which say its for giving out 25% of current, which shuold be about 1.5A per motor,suitable for nema17 motors. The range of current being 1.3 to 3Amps.
    I left the motor connected. In about 5 minutes, I could not touch the motor without getting scalded. A little more and perhaps I was about to see smoke.
    Immediately i disconnected all power and put the motor on a cool metal object to take out as much heat as possible, hoping i did not do any damage to my motor.
    Can someone tell me why my motor got so hot, nearing burning temperatures?
    Also has anyone used Mach3 to control this board and what settings they are using or recommend?
    Mar 2007
    2083
    Re: I bought a 6560 board and motors getting burning hot
    depending on which manufactures data sheet you look at
    stepper motors run at 70 to 80 centigrade !! too hot to touch for long
    this is why many stepper drivers reduce the motor current when the axis is idle
    Do you have the specifications for your motors ?
    Usually you should have the motor current , the coil resistance , inductance and voltage
    (the voltage is the DC voltage to get the rated current to flow through the coil)
    ideally the inductance should be about 2 to 3 mH , to work when using a 24V to 34V supply for the TB6560 board
    the 36V power supply found in some kits is over the maximum voltage for the TB6560
Name:	part of TB6560 data page 6.jpg
    To achieve a reasonable motor speed
    the TB6560 supply voltage will be several times the motors rated voltage , the current being limited by the stepper driver
    the supply voltage required is related the motors inductance
    the higher the inductance, the higher the stepper drivers supply voltage will be required to force the current through the coils as motor speed is increased
    john
  1. chineese 6560 4 axis cnc control board issues
    By Warhawk in forum Stepper Motors / Drives
    Last Post: 02-13-2018, 06:25 PM
  2. TB 6560 sending voltage to all 3 motors on all 4 pins at once
    By Sin984 in forum Stepper Motors / Drives
    Last Post: 10-03-2015, 01:19 AM
  3. Driver Board 6560 no free inputs!???/
    By TheProCreator in forum DIY CNC Router Table Machines
    Last Post: 11-15-2010, 03:54 PM
  4. Burning Out Motors?
    By kylecroft in forum Linear and Rotary Motion
    Last Post: 06-01-2007, 08:49 PM
