Hi!
Can any help me how to set 1850 parameter for each axis?
The value of this parameter is in range from -99999 to 99999.
This parameter show the initial axis offset.
I have V axis (magazin). After the switch on the machine servo motor trys to tune and "8" error code in drive appears.
Current value of 1850 parameter for this axis (V) is 0.
The U axis (pallete) is in the same servo drive (L-type 2 axis drive) and there value in 1850 parameter is 400.
I need to set the initial value for V axis but don't know how to do it.
X, Y, Z axis in 1850 parameters are not 0.
V axis (magazin) not search zero after the switch on procedure (parameter 1815 bit #5 APCx is 1 (absolute encoder).
HELP!!!!
