585,758 active members*
4,323 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 2004 Haas Super Mini Mill Problems
Results 1 to 6 of 6
    Feb 2018
    Hello, I bought a used super mini mill that looked in great shape. I connected it to a roto-phase in my shop and took off running. Everything worked fine for a while. Then it completely stopped in the middle of a program. Everything quit and the screen locked up. I had to power off to and power back on to get anything to happen. When I power it back on I get the errors shown in the picture. After on for a few seconds it starts counting down from 15 seconds and then powers off. The incoming voltage and phase are correct. A local friend who has worked on these machines looked at it and thought it was a spindle drive. Instead of spending $1500 to get the local HFO out I decided to send the spindle drive out to be rebuilt by the company below.
    93-69-1000 by HAAS - Buy or Repair at Radwell - Radwell.com
    After getting the drive back and reinstalled I still get the same errors. Someone else suggested the battery may be a problem but I checked it and it is at 3 volts.
    Does anyone have any thoughts?
    Oct 2010
    171
    Re: 2004 Haas Super Mini Mill Problems
    This is a long-shot, but to me it sounds more like there's a problem with your incoming power -- phasing or voltage.
    Jan 2004
    539
    I would do a complete backup of everything (from the usb)
    If it is not too late. Then install a new battery or that new dual batt kit from haas. (don't shut it off) 3v is not enough
    The only time I had the countdown was when my battery was completely dead and I had Maaaaany more faluts than you have
    Do not shut it off until you do a backup (2cents)
    Gary
    May 2016
    526
    Do the battery change as 3v is not enough as someone has already said
    if alarms persist check the monitoring board
    Oct 2010
    121
    Did you manage to overcome this? I have the same issue with my mini mill
    May 2016
    526
    I thought you had another problem Gary
    Quote Originally Posted by garylb View Post
  1. HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP
    By CCF_CUSTOMS in forum Canadian Club House
    Last Post: 02-14-2018, 10:47 PM
  2. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  3. HELP!! Haas Super Mini Mill
    By CountBraden in forum Haas Mills
    Last Post: 07-07-2008, 12:20 AM
  4. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
